Key stuck in ignition on Volvo XC70 AWD 1999
    Results 1 to 9 of 9
      Hi,
      Having trouble with key being stuck in ignition..
      Is there a simple way to fix this or is replacement of key assembly.?
      Thanks
      Former Advertiser Scott Hart's Avatar
      Nov 2001
      Portland OR
      Re: Key stuck in ignition on Volvo XC70 AWD 1999 (luapram)
      Quote, originally posted by luapram »
      Hi,
      Thanks
      The most common cause is failure of th eignition tumbler asembly, but difficutl to know for sure w/o taking a look at it. It could also be something as simple as the shift interlock mechanism needing some attention.
      There should be some mention of it in your owners manual.
      Re: Key stuck in ignition on Volvo XC70 AWD 1999 (Scott Hart)
      Thanks Scott.
      Will persevere a couple more days but will probably have to get my techs to look at it...
      Lu
      Junior Member timxc90's Avatar
      Jan 2007
      florida
      While I was at the dealer for service someone came in with the same problem and they told them it probably needed the new cylinder or what ever its called, but he told them to try that lock button by the shifter as sometimes that can prevent you from getting the key out.
    7. #5
      Re: Key stuck in ignition on Volvo XC70 AWD 1999 (timxc90)
      depending on mileage either can be the culprit.
      The shift interlock can usually be adjusted out and takes only a few minutes to do. If the problem persists then consider a new tumbler.
    8. #6
      Re: Key stuck in ignition on Volvo XC70 AWD 1999 (Ipd-Lucky)
      Thanks.
      Have tried suggestions offered kindly by folks on this board.
      Probably have to go with a new tumbler.
      Lu
    9. #7
      Let us know how it goes
    10. #8
      Will do-?
      Thanks again
    11. #9
      You know a shot of Volvo lock oil might help a bit. I've been amazed how well that stuff works!
      http://www.ipdusa.com/product....rd=21
    12. Remove Advertisements
