A ton of heat and noise comes up through the shift boot. That is why it has (lousy) insulation in it and also why it must be installed properly (lip between the two metal flanges).The firewall has many openings and leaks engine bay heat/noise/stink into the cabin.
The wagon's interior at cruise acts like a drum and picks up the harmonics from the engine at various rpms/gears/speeds.
The doors have factory-installed liners behind the interior panels which deteriorate over time and allow much noise/vibration into the interior.
If the seals around the glass are shrunk/dried/cracked the pane will hum like crazy at speed.
The outside rearview mirrors will sing loudly at speed so good-fitting vent window seals are a must.
Where was I - oh, yeah, trans/OD.
Since the engine, trans, OD and short shaft all shake as a unit they must be held in place by the front engine mounts and trans mount. This alignment is critical for smooth operation at all speeds under all conditions. The trans/OD must have space to wiggle in the chassis tunnel without contacting anything but also must be restrained sufficiently to keep the power train in alignment. This is also why the two-piece drive shaft needs to be balanced as a unit.
The speedo cable will hook up to the trans/OD and may need a 90-degree drive adapter. Also, depending on the trans cover used the OD lock-out aparatus may need to be modified. Some folks try to run the OD in all gears which is cool if you are the only driver and NEVER forget to disengage the OD when reversing. Best to use the lock-out where the OD engages in fourth gear only.
This is gonna be one fine ride.
George Dill
Modified by gdill2 at 12:01 PM 4-2-2009
