So...the code says that the "System is too lean at idle speeds." My engine is making a terrible whistling noise at idle but goes away at regular speeds. Any idea what the problem might be??? Help!
You need to go into the dealer and have your oil seperator/upper pcv hose inspected. If when you remove the dipstick or the oil cap the noise goes away and you have excessive crankcase vacuum you need your oil seperator service done with the update style upper hose.
Its an extended warranty now and you should be fully covered even if not under your factory warranty http://********************/smile/emthup.gif
No problem, its extended warranty number 205 http://********************/smile/emthup.gif
