Alarm Siren how to replace?
    Results 1 to 11 of 11
      Sep 2009
      Hi peeps,
      I have a 2004 S60R and have an "Alarm Service Required" message. I took her for a service and they charged me £100 just to tell me the message meant! Apparently I needed to replace my alarm siren, they then wanted to charge me over £400 to replace it, to which I told them no.
      I have managed to buy a siren for just over £100 and wondered if this was something I could replace myself and if so can anyone able to advise how?
      I'm no expert but following instructions on this forum I've been able to do things myself like replace TCV, fit iMIV iPod adaptor and other bits and pieces.
      Thanks in advance.
      P.S. Once it's done I'll still be left with the message. Is there a reader I can buy that will allow me to read and possibly even reset such messages for my car?
      Member VolvokidS60R's Avatar
      Dec 2007
      G-Burg MD
      Re: Alarm Siren how to replace? (iluvs60r)
      remove the inner finder well on pass side right hand. remove it fron the bumper casue the modlue is shoved up in passed the washer resvor, now your going to have to notch the bold cause theres no bolt head and remove it with a stubba flathead
      No more R got a 1995 240sx converted to a Silvia in replacement... Can't say I miss the Volvo
      P.s no more am i Volvo tech... I now am a shop Forman at a high performance shop.
      Quote Originally Posted by Fitzy View Post
      Yeah right, he's all happy you called...then a yellow birdie flys by and oh here's a cupcake, btw what were we talking about...
      Do you have a sunroof and did it quit working at the same time? Do a google search here and you should find a nice writeup w/pics on how to replace it...
      Member StarmanDXE's Avatar
      Nov 2008
      Charlotte, NC
      Replacing alarm module:
      http://www.matthewsvolvosite.c...17479
      Not sure about the actual siren...
      Current: 2014 S60 T5 White
      Previous: 2010 S40 2.4i Silver | 2002 S60 T5M Gray | 1993 850 GLT Red
    7. #5
      Sep 2009
      Re: (StarmanDXE)
      Cheers peeps
      No sunroof. I think it actually happened during a night of lightning and torrential rain.
      When I went in the morning to check on her the alarm lights were flashing, but there was no audible alarm. I don't know if it had ever been audible during the night or if the siren broke sometime after the alarm went off.
      After that I had the "Alarm Service Required" message up.
      Found a pdf on volvo-forum (sorry dunno how to attach files) that includes diagram of where it is under right wheel. However says it must be configured via VIDA even if fit myself
      Maybe need to shop around for another dealer. Poster on volvo-forum said he got it replaced for £141 inc VAT, that's how much they're charging me just for the part! Although his was 2002 S60 not an R, perhaps that's reason for difference?!? Even so maybe another dealer will supply and fit cheaper, if gonna have to pay for configuration anyway
      Also need to check if activating the alarm via keyfob makes lights flash, if lights flash then means it's likely the siren and no the whole alarm module right?
    8. #6
      Sep 2009
      Re: (iluvs60r)
      You know what, I think it's actually the siren module that's goosed as in that link and not the actual 'siren'.
      Mathew says his lights flash but no audible signal, I need to check my girl does the same when I activate the alarm.
      Meant to pick up the part from Volvo tomorrow but now I need to check it's actually the right part.
    9. #7
      Nov 2008
      Charlotte, NC
      Re: (iluvs60r)
      Quote, originally posted by iluvs60r »
      I thought I remembered reading on that other site that this wasn't the case. Maybe I just misremembered...
    10. #8
      In the '02 S80 T6, I've already repaired the siren module's circuit traces that were damaged by electrolyte leaking out of the module's backup batteries--I replaced them as well with a pair of new cordless phone NiMH batteries--and got the siren module to work again just by cycling the door locks 3x. That reset the UEM so there was no need for a dealer visit. BTW the UEM also controls moonroof operation so if the moonroof is acting all wonky, try cycling the door locks 3x as well.
    11. #9
      Just get a used module from a parts car or junkyard. I, fortunately, got mine for free from one of the parts cars here a few months ago. The siren backup battery acid ate through a bunch of the circuit traces.
    12. #10
      Sep 2009
      Re: (SHIFT_S60R)
      Yeah so get this, I went to check if lights flashed. Used the alarm button on the key fob, not only did the lights flash but the siren went.
      That doesn't make sense to me. Alarm Service Required message still up and on the service sheet from service centre it says fault due to alarm siren requiring replacing.
      I'd have thought that if it was goosed it was goosed and I'd no hear a peep out of her?
    13. #11
      Re: (iluvs60r)
      IIRC the remote's panic function honks the car's horn and works completely independently of the siren module.
    14. Remove Advertisements
