Outer tie rod end torque setting for 2003 V70?
    Results 1 to 3 of 3
      Junior Member backroadsb's Avatar
      Sep 2008
      Bristow, VA
      I'm getting ready to replace inner/outer tie rod ends on my 2003 V70 2.4i. Anybody know what the torque spec is for the outer tie rod end nut?
      Thanks in advance!
      Re: Outer tie rod end torque setting for 2003 V70? (backroadsb)
      55 ft lbs or 70 Nm
      Sep 2008
      Bristow, VA
      Re: Outer tie rod end torque setting for 2003 V70? (jayvolvo)
      Thanks for the response
      Unfortunately, I'd already done the job, went w/ the old "good n' tight" approach. I'm not thinking its so much of an issue w/ a tie rod end...
