+ Reply to Thread
Results 1 to 5 of 5
Thread: Tail Gate door won't open
  1. 11-01-2009 07:04 PM #1
    My XC70 wagon tail gate will not open. Have tried relacing fuse, but fuse keeps popping. Also cannot open the door manually. any suggestions?
    Larry in Oak Creek.
  2. Global Moderator
    Aug 2004
    Temple, Texas, USA
    11-01-2009 07:10 PM #2
    Welcome to Swedespeed, Larry.
    This is a tough one - consider starting a new topic here...
    http://forums.swedespeed.com/zeroforum?id=20
    Any problems with the other Volvos?
    George Dill
  3. 11-02-2009 05:52 AM #3
    Larry,
    What year is your XC70?
    Is the problem that the tail gate is not unlocking? Or is it that you can't release the latch?
    Have you tried the inside release?
    SOmetimes if something gets caught in the door when it is closed, it can jam the latch enough that it is hard to open. Try pushing in on the door with some force while you try the latch to see if it will release.
    If none of this works, the latch linkage may have come loose inside the door - that will be a bit of a sticky problem, but my next thought would be to try to get the panel off on the inside so that you can access the latch linkage.
    As for the fuses blowing, it sounds like a problem with a short in the wires to the gate - usually the problem is where the wires are routed through the hinges at the top. Does the fuse blow immediately when you put it in, or does it blow when you operate something - like the lights, electric doog lock?
  4. 11-02-2009 05:07 PM #4
    My XC70 is a 2001. Can't find an inside release to the tail gate. I don't think anything is stuck in the door. The key pad will open all doors but the tail gate. This happened once before and changed the fuse. This time the fuse just pops immediately. I was thinking the "motor" needed to be
    re-placed, but can't get there. I recently had some body work done on the car, on side panels, mabe some wires got messed up. Don't know.
    Larry in Oak Creek
  5. Global Moderator
    Aug 2004
    Temple, Texas, USA
    11-03-2009 10:38 AM #5
    Check your owners manual for the location of the inside tailgate "latch". Also, did the tailgate function correctly before the bodywork?
    George Dill
+ Reply to Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
