Any updates on the car? Sorry for the late post...If it's a Canadian Volvo it'll have a small white 'Halifax, Nova Scotia' on the engine bay slam panel. If that is the case, the GLT will be a non-Turbo but still a very durable B23E engine. The Canadian Turbo 240s were titled and badged as just 'Turbo' as far as I'm aware.
The B23E engine is non-interference with approx. 136bhp output. From what I've researched it's a very strong and durable engine which will clock up the miles no problem.
Any 2-doors / GLTs I've come across have all been 4 speed manual transmission with electronic overdrive (M46).
Rust? Make sure to give the rockers, rear arches and rear wheel wells a really good going over. Check the metal lip above the rear bumper and just under the taillights, particularly on the inside. If these areas are good it's likely a good solid body, but do check the underbody and if the interior carpets are wet.
Cosmetically, just check that everything works. Instrument panel, gauges, switches, sunroof cranks correctly, air-con/cruise if it has it and off course the overdrive switch on the shifter.
144KMs is real nice. It's still low mileage though, and for the age will probably need items renewed and a good tune-up especially if you want to use it as a daily driver. This could run into double the selling price so bargain accordingly.
I'm a little East in Edmonton and drive a '81 242 GLT, manual, approx. 335k KMs with no history. Needs a tune-up but pulls strong!
And don't frogot to post some pictures!
