+ Reply to Thread
Results 1 to 21 of 21
Thread: Mis That Won't Go Away
  1. Junior Member
    Jul 2008
    Solon, Ohio
    11-06-2009 05:06 PM #1
    I originally wrote about this in the S70 Sweedspeed Forum and recieved a few good responces but I'm looking for a second opinion.
    http://forums.swedespeed.com/zerothread?id=125584
    The car is a 98 S70 T5 with 139K on it, I've done everything you can think of, originally for maintenance and then to try to figure out this mis that shows up at about 30 to 40 mph and stays up to 80-90 never realy goes away just gets less noticable with higher speed. But goes away if you slip it in to nuetral. It feels like a bad plug wire.
    I'Ve had all the work done by a Volvo Master tech who still works at my local dealer and he's stumped at this point. It's all new; ignition, coil, hub assemblies, axles, rotors, motor mounts, timing belt w/pullies , water pump, even did the evap canaster and chacoal filter to eliminate a code for Vacuum leak.
    The last thing we did was a new head and valves. No I don't like throwing money away but we did a compression check and #5 cylinder had almost no compression and #4 was about half what it should have been. So the for sure we thought we found the problem but it has not gotten rid of the mis! When you put your foot in to it sure runs like a bat out of hell now with all the added compression .
    The latest idea was the Torque converter because if you slip it in to nuetral it goes away even at speed. Is there a way to test it or any other ideas???
    Even have new rims and Mich pilot tires, just put the snows back on today and it is still there. If you have any questions about all the parts they either came IPD or Groton and there were many more than I mentioned, cam sensor, boost control valve and on and on.
    Any other ides would be most appreciated.
    Modified by gregory914 at 9:37 AM 11-7-2009
  2. 11-09-2009 04:25 PM #2
    What's your plug gap?
    Misfire will typically throw a CEl, what codes are you getting?
  3. Junior Member
    Jul 2008
    Solon, Ohio
    11-10-2009 10:44 AM #3
    The plugs are gapped to spec and there has not been any codes for about six months. The last code was for a bad cam sensor (replaced) and prior to that was the large vacuum leak code associated with the canister, check valve, charcoal filter ordeal which was all replaced.
    That's what is so troubling, there are no codes. It's sort of like a shutter more obvious under load but still there when you let off. At idle you can sort of feel the miss in the steering wheel, it goes up and down with the RPMs.
    Thanks for input.
  4. Member StarmanDXE's Avatar
    Nov 2008
    Philly Area
    11-10-2009 11:27 AM #4
    Sounds like what I went through with my 850. First thing I found was lost compression. Got that back with some Seafoam. Didn't fix it... (But, yeah, the car drove like a beast compared to what I was used to!)
    Then found out that the connector for the MAF (mass air flow) sensor was corroded and just pulling on it was enough to make it lose connection and kill the engine. Cleaned it off and it stopped stalling over train-tracks (at the least) but still didn't fix it...
    Finally it was determined that the Cam Position Sensor was bad. Replaced that and all was good! (Also did replace a few other things along the way: fuel filter, spark plugs, ignition coil, and maybe a few other small bits...)
    So, perhaps the "new" Cam Sensor is just bad? Or you have a poor connection somewhere important? Can you tell which cylinder(s) misfire(s)?
    Current: 2010 S40 Silver
    Previous: 2002 S60 T5M Gray (For Sale)
    Original: 1993 850 GLT Red
  5. Junior Member
    Jul 2008
    Solon, Ohio
    11-10-2009 12:51 PM #5
    It doesn't seem like any cylinder is misfiring, compression is good and plugs are all in the same condition. Cam sensor left me stranded, had to tow it to get repaired, MAF is new and tech tie wrapped connector to fix the loose problem, that is the fix for it from Volvo, you bend the connector lead back over itself and tie wrap it tight.
    And there are no codes?
    Thanks!
  6. Member StarmanDXE's Avatar
    Nov 2008
    Philly Area
    11-10-2009 01:12 PM #6
    I mean the actual pins were corroded so it was making poor contact, not that the connection was physically loose.
  7. 11-11-2009 11:49 AM #7
    Hard to say for sure without feeling it so at this point you may want to see a qualified tech to get any further diagnosis.
  8. Junior Member
    Jul 2008
    Solon, Ohio
    11-11-2009 12:59 PM #8
    Thanks for the help, a certified Volvo Master Tech is who does the work on it. It's sort of like a shutter or a bad plug wire but not as drastic as a wire. I'm going to try a tranny shop and get there opinion and wait till something breaks or becomes more obvious.
  9. Member StarmanDXE's Avatar
    Nov 2008
    Philly Area
    11-11-2009 01:33 PM #9
    Like you're driving on the highway and it just bucks/stutters along with a CEL (check engine light) flashing on?
  10. Junior Member
    Jul 2008
    Solon, Ohio
    11-11-2009 03:35 PM #10
    No not that severe and no check engine lights. It's constant, more like the feeling of a bent rim or cv joint going bad, but more repetitiuos then a rim. Those items have been ruled out.
    The only time it goes away is when I put the tranny in neutral, but there still is a sensation of it when parked you can feel it in the steering wheel a little. It's most obvious between 35 and 45 MPH.
  11. Member StarmanDXE's Avatar
    Nov 2008
    Philly Area
    11-11-2009 03:45 PM #11
    OIC. Well, then that's a different beast you're tracking down from what I had.
  12. 11-12-2009 01:12 PM #12
    yeah, I'm not sure what to tell you given the items you've already addressed.
    Ignition coil getting weak?
  13. Junior Member
    Jul 2008
    Solon, Ohio
    11-12-2009 02:19 PM #13
    Put an MSD on with new wires cap and rotor, a month before the head.
  14. 11-16-2009 12:00 PM #14
    No CEL?
  15. Junior Member
    Jul 2008
    Solon, Ohio
    11-17-2009 08:56 PM #15
    Sorry, I don't know what a CEL is? No code lights if that's what it means.
  16. Member StarmanDXE's Avatar
    Nov 2008
    Philly Area
    11-17-2009 10:20 PM #16
    Check Engine Light. (I alreadly spelled it out above if you go back and look )
  17. 11-19-2009 12:49 PM #17
    You're certain it's an engine misfire or stumble?
  18. Member StarmanDXE's Avatar
    Nov 2008
    Philly Area
    11-19-2009 12:54 PM #18
    Quote, originally posted by Ipd-Lucky »
    I doubt it. Check out this post from above:
    Quote, originally posted by gregory914 »
    Are you familiar with the term "resonant frequency"? Sounds like something is out of balance...
    Parts of the transmission still spin while in neutral, no?
    If not the transmission, then maybe it's a belt or pulley or something spinning/moving in/on/attached-to the engine?
    Edit: You know, thinking about it a little more, if it's happening most between 35~45 MPH, then it's probably not the engine and most likely something in the drive train at or past the transmission (going away from the engine).
    Modified by StarmanDXE at 1:28 PM 11-19-2009
  19. 11-20-2009 12:23 PM #19
    I tend to agree, but without feeling it... I'm really just guessing
  20. Junior Member
    Jul 2008
    Solon, Ohio
    11-20-2009 03:06 PM #20
    I'm going to try a transmission shop next week. It's gotten colder here in Cleveburg and when I drove it yesterday there is a sound and a vibration that went away after 4 to 5 minutes of running down the road at low RPM. My wife usually drives it first in the day so I don't drive it from stone cold too often.
    What does a torque converter do when it goes bad. Over my years of driving, any time a transmission would shutter a little, it was toast within about 10 miles or less.
    Also talked to my mechanic yesterday about this and he thinks maybe the throttle position sensor, but he's leaning more towards the trans after this cold weather thing stared.
    Thank you for the input, I'll post what the next diagnostic adventure shows.
  21. 11-23-2009 01:39 PM #21
    Keep us posted!
+ Reply to Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
