Gear indication- service required
    Results 1 to 9 of 9
      Member d3box1's Avatar
      Mar 2010
      Barrington, RI
      hey, im getting a wierd warning on my s40- Just like the title of the thread "gear indication- service required"
      I drive a 2005 t5 (automatic) and i just got the car so its still under warrenty so i would like to check it out -
      some problems ive noticed include but are not limited to getting stuck in N aswell as when using the triptronic feature when i downshift (say im in gear 3 going 20mph) there is a lag in switching then a clunking noise.
      Is the tranny failing here? anybody else having these problems? J.w im going to take it to a shop in the mean time but a headsup would be nice-
      Thanks
      BLACK 13' HYUNDAI GENESIS 2.0T - CURRENT 05' S40T5A BLACK BLISTEN/ EIBACH/ OBX/ ELEVATE/ K&N/ EST/ BSR SOLD- 98' S70T5A STOCK BLUE "A luxury car should drive itself"
      Re: Gear indication- service required (d3box1)
      Did you ever find out the answer to this one. Mine just started doing the same thing. I have 46,000 miles on the car.
      Dec 2009
      edmonds, wa
      I don't know why Volvo does not call for a fluid flush on their AT's, just because it's a closed system doesn't mean you forgo a fluid flush every 30K, by 30K it's gonna be pretty dark if not black, it's the heat that kills it. I'm not an expert on AT's, but I've rebuilts lot's of motorcycle front ends (another closed system) and and I change the oil out in those every 10K and it's nasty by then.
      v60P 44/80 Ferritta DP, DO88 FMIC, Snabb turbo intake, ram air intake, more to come
      Well, I changed out the GSM and all is well.
    7. #5
      Junior Member ion's Avatar
      Jul 2009
      MD
      Re: Gear indication- service required (rayrayb)
      GSM being?
      So you don't have the "Gear indication - service required" warning anymore? What about the downshifting from 3rd to 2nd clunking noise, did you have that? And did replacing the GSM, whatever that is, fix the clucking noise?
    8. #6
      Mar 2010
      Barrington, RI
      Re: Gear indication- service required (ion)
      i know what you mean about the clunking- the way to avoid it is on the gtec just switch back to d then to ----> gtec. I no longer have that (info) message and i didnt do anything, it just went away, weird.
      and i have no idea what GSM is lol
    9. #7
      Jul 2009
      MD
      I found a related thread when searching for the clunking issue: http://forums.swedespeed.com/zerothread?id=74333
      Apparently there was a software update that fixes the problem.
    10. #8
      The GSM - Gear Selector Module.
    11. #9
      I never had the clunking noise. I did however have my shifter lock into position twice.
    12. Remove Advertisements
