+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 35 of 43
Thread: Cold Misfire Codes P0300 + P0303
  1. 05-26-2010 08:37 AM #1
    For the last 3 Months. Every third cold startup or so, I get a misfire code on Cylinder #3 (P0303), and twice or three times gotten a "Multiple Cyl Misfire" (P0300).
    Some history:
    Car has 144K
    Always gentle warmups, waiting 20 seconds for idle to slow from 1500 before moving.
    Stock Tune, Filters, FMIC, the whole deal.
    Replaced spark plugs when Misfire codes started (Volvo OEM)
    Traded Coilpack #3 and #1 to see if problem "moves" with part, to no avail.
    Car doesn't buck for seem like it's misfiring at all, MIL usually comes up at 15 MPH.
    Could this be a bad knock sensor? Your input is appreciated.
    2004 Sapphire/Nordkap S60R traded in for a 2006 British Racing Green - Mini Cooper S - John Cooper Works
  2. 05-26-2010 08:47 AM #2
    A misfire is determined by the crank sensor realizing that there has been no crank acceleration for a particular power stroke event. Since you have already ruled out the coil and plug its time to move onto other causes.
    It could also be a sticky fuel injector. To rule that out swap the 1 and 3 fuel injectors as well.
    If the problem stays on 3 then its time to start looking at the electrical connectors, wiring and the coil driver assuming the R has one.
  3. 05-26-2010 09:18 AM #3
    Thanks for the input, Tony. I was going to look there next.
  4. 07-11-2010 02:31 AM #4
    Ended up being a soiled air filter. Yeah, flippin' random. Hope everyone's problems are so easily fixed!
  5. Senior Member 850arrrsaylikepirate's Avatar
    Oct 2007
    Bay Area, CA
    07-11-2010 02:47 AM #5
    Quote Originally Posted by Skot53 View Post
    So was the MAF dirty too??
    2006 S60R - Black Sapphire~Nordkap~GT~iPd Track Spec Sways~TME Springs~TME DP-Exhaust~Bell FMIC~iMIV~E-Codes
    2009 XC90 3.2 AWD - aka the kiddo hauler
    1997 4x4 Nissan - Fook mi this thing is slow
  6. 07-11-2010 02:56 AM #6
    Nope. I think it was just non-laminar airflow across the MAF causing misfires during start up. Problem is gone. (OEM filter)
  7. Senior Member 850arrrsaylikepirate's Avatar
    Oct 2007
    Bay Area, CA
    07-11-2010 03:00 AM #7
    Cool and good to know.
  8. Member VolvokidS60R's Avatar
    Dec 2007
    G-Burg MD
    07-12-2010 06:05 AM #8
    ok so...... Yea thats FLIPPING WEIRD!!!!!!!
    In all my years at volvo iv never herd of this, but hay there is a 1st for ever thing right..?
    No more R got a 1995 240sx converted to a Silvia in replacement... Can't say I miss the Volvo
    P.s no more am i Volvo tech... I now am a shop Forman at a high performance shop.
    Quote Originally Posted by Fitzy View Post
    Yeah right, he's all happy you called...then a yellow birdie flys by and oh here's a cupcake, btw what were we talking about...
  9. 07-12-2010 08:41 AM #9
    Could have been involved with the change of the seasons too. Weird electrical and building fitment issues come and go with the heat and freeze of the seasons at my work, too. I'll let you guys know if it comes back.
  10. 09-03-2010 01:43 AM #10
    Yep. Came back. Thinking it may be a fuel issue. Dunno when the last time the fuel filter was changed, so I'll start there, and work my way to injectors. Changed the spark plugs recently when this stuff first started, so that's not it.
    Also, going to check the MAF again to make sure it's clean.
  11. 09-03-2010 08:24 AM #11
    Make sure you do a leakdown test stone COLD!
    it may be time for valves? 04's were bad for those
  12. 09-03-2010 10:56 AM #12
    Thanks for the suggestion, but I think that's pretty far down the list. The car doesn't smoke or do anything else screwy (like a car with bad valves does). I'll start with sensors first.
  13. 09-03-2010 12:21 PM #13
    How many 04's with bad intake valves have you worked on? I have had quite a bit and never have seen one smoke or anything.
    Just a suggestion though...
  14. 09-03-2010 03:15 PM #14
    Again, thanks for the suggestion. I've only has experience with VWs and their valve stem seals that wear out, causing smoke. This is my first Volvo. I'll take it into a shop if I can't get to the root of the trouble. Thanks!
    Bought some LubroMoly fuel system cleaner and MAF cleaner... we'll see how it goes.
  15. 09-06-2010 09:17 AM #15
    After I cleaned the MAF, the car runs much smoother at idle now. I think that may have been the issue. (No CEL yet, either) When I replaced the air filter, I should have cleaned the MAF, I think hat would have taken care of the problem. It was a bit dusty in there (nothing too big, though). I guess there's a good reason to keep the foam sock on the stock air filter.
    Thanks for you help everyone! I'll keep you guys posted if it comes back.
  16. Member 58Ford2's Avatar
    Sep 2009
    Camas WA
    09-06-2010 06:58 PM #16
    Scott, What are you using to read your codes? My cheapy from Harbor Freight wont list them.... PIA!
    12 Dodge Challenger R/T (midlife crisis)
    11 Rav4 Limited V6
    05 SR GT Black Saphire - Gobi and proud of it. Also very proud of my Anthracite 18" Pegs, Blacked out grille, IPD upper mount, JRL mod. TRADED IN 1/21/12
    58 Ford F100 302 C4 9"
  17. Member inteller's Avatar
    Aug 2009
    Tulsa, OK
    09-06-2010 07:00 PM #17
    because to get good codes you need DICE. Those are just generic mandatory codes.
    2006 Passion Red S60R
    Packages: Premium, Climate Options: Sport Appearance Package, 18" Pegs, 6Spd Geartronic, Navigation
    Accessories: Sunglasses holder, Sirius Radio, Volvo Digital Jukebox Mods:SS DEM Mod
    I DO NOT REPLY TO PM's FROM PEOPLE WITH UNDER 10 POSTS SO DON'T WASTE YOUR TIME!
  18. Member VolvokidS60R's Avatar
    Dec 2007
    G-Burg MD
    09-06-2010 07:02 PM #18
    Check all 5 coil packs for cracks. if find any crack of any kind replace. also you should be your head tested. i had a cust car with cold miss fire and come to find out it had a slow cooland leak into cy3.
  19. 09-07-2010 08:18 AM #19
    Quote Originally Posted by 58Ford2 View Post
    Scangauge II. It was $170 from iPd, but it helped me find an evap fault (bad gas cap :rolleyes) within the first week of ownership. If you want me to scan some codes for you, I'm totally willing to pop over after work.
    Quote Originally Posted by VolvokidS60R View Post
    Already checked the coils, they look fine. When the problems started, I swapped #1 for #3 to no avail, and inspected all of the coils closely (funny because I just posted about some cracked coils on VW and Audis). I'll keep an eye on things. Thanks again for the help guys!
  20. Member VolvokidS60R's Avatar
    Dec 2007
    G-Burg MD
    09-07-2010 08:56 AM #20
    well youy know any bernt spots fail coiles also.
    but if no fix id start lookin into a head gasket test like this
    http://www.matcotools.com/ProductImages/AC560000.jpg
    http://www.matcotools.com/Catalog/to...ype=T&cat=2477
    i bet if all else fails check head gasket
  21. 09-07-2010 09:02 AM #21
    Quote Originally Posted by VolvokidS60Redited View Post
    well you know any burned spots indicate failed coils also.
    Yeah, I used to have a VW GTI and and Audi TT, i've heard all of the horror stories about "Coilpacks". Coilpack Failure Log
    Thanks for your help, Nick. I'll keep everyone posted. It's been a long Labor Day weekend with many hours of driving, and may hours of sitting (which tends to trip the code), with NO CODES! So, I think this may be resolved.
  22. 09-07-2010 10:22 AM #22
    Could just be a sticky fuel injector. Try a can or two of fuel injector cleaner. If that doesn't do anything for you and you feel up for it, pull the fuel rail and swap around the injectors to see if that moves the misfire. If it does then replace the bad injector.
    I don't think it has anything to do with your maf or filter since there is no way those items would cause just one cylinder to fail on a power stroke.
  23. 09-07-2010 01:25 PM #23
    Quote Originally Posted by StealthyS60R View Post
    I put in a can of LubroMoly Fuel System Cleaner when I cleaned the MAF, then filled up at Chevron.
    Thanks for the input. I'm getting a variety of codes at the moment, mainly P0303- but also 0300 (multi) and 0301 (#1 misfire) as well.
  24. 09-07-2010 02:51 PM #24
    Does it happen at lower fuel levels? If its not purely electronic I wonder if air is being sucked into the fuel pump intake and sending air bubbles down the fuel rail which could also cause a rash of misfires.
  25. 09-29-2010 06:24 PM #25
    It came back again the other day... Starting to get a bit annoying. It would help if I didn't work so much so I could bring it into a shop.
    You know what... maybe it does!!! It does seem to go away for a few days, then come back when I'm at lower fuel level. Has that happened to you before? I did replace my fuel level sender, but I'm pretty sure I put it together correctly.
    edit: it happens at all fuel levels. Empty, full, half tank, doesn't matter.
  26. 09-29-2010 09:16 PM #26
    Well Skot, that hasn't happened to me on my R, but I have ran another fuel injected car low on fuel before and experienced a flurry of misfires that occur when you start sucking air into the fuel pump.
    Just a scientific wild assed guess based on thinking about all the possible causes could be leading to your particular symptoms, lol.
  27. 10-04-2010 04:04 PM #27
    Drove 80 or so miles this weekend... Still no CEL . Called the local dealership asking about the Fuel Pump Recall. The Service Manager claims that the fuel pump problem will not cause a CEL, and I pretty much agree. All of the internet research that I've seen, it's just the fuel smell. Made an appt for a week from now to check on the fuel pump to make sure it isn't leaking... though I may cancel. I really don't like other people touching my car.
    edit: I did end up canceling. I hate dealerships. At this time, my car is no longer eligible for the recall due to mileage.
  28. 01-10-2011 06:04 PM #28
    It hasn't gotten better or worse, but I figured that I would update.
    I've just been leaving the CEL on, not caring, due to other issues making the CEL come up just about every day. Search my name on these forums for more info.
    I took it into an independent Volvo mechanic to get a software update. I was having troubles with the Fuel Leak Diagnostic Pump, and I figured I'd take it in, since getting to the pump is such a PITA. When they updated the firmware, the service writer informed me that the P0303 code was possibly due to software as well, since I told him that I changed the spark plugs and moved the coil- which didn't help at that time. He did not mention anything about valves, though he WAS just a service writer, the mechanic didn't mention anything either... I'll update this thread in a week or so with a conclusion.
  29. Member Short Circuit's Avatar
    Mar 2005
    Baltimore, MD
    01-10-2011 07:41 PM #29
    With 144K miles, your coils are toasted 2x over. Jeez man, get 5 new coils from IPD in your own back-yard and solve this problem once and for all!
    SOLD!!! 2005 S60R. Mods: IPD (Stage 2 ECU, Trak Spec F&R sways, 3" DP, HD-TCV, HD-coils, HD-endlinks, SS brake lines), HEICO (CATback, 18" Volution wheels), Phuz PhMIC, JRL resonator delete, RKelly CAI, PLX OLED Boost Gauge, VST roof spoiler, 35% 3M window tint, other littler things.
  30. 01-11-2011 09:14 AM #30
    Quote Originally Posted by Short Circuit View Post
    Would you say, perhaps, that they have a Short Circuit?
    BTW, the car now has 152,500 miles. She likes to be driven! I was waiting for the iPd R coil debacle to be over, and for them to be re-released on their website. The P0303 CEL came back on again this morning, shortly after start-up. Swede One Auto Werks treated me really good yesterday, so I may lean to them for further diagnoses. (cold leak down test, et al)
  31. Junior Member ari951's Avatar
    Nov 2010
    Florence Kentucky
    01-11-2011 10:52 AM #31
    +1. Fixed my problem.
    Also, I cannot remember the code (P2303?), IDK, but the recall for replacement of fuel pump fixed this code.
    2004 S60R MT | Black Sapphire/ Gobi | factory aero body kit | painted grill | painted headlight bezels | custom R badge front grill | 18" two tone metallic grey/black pegs | smoked tail light lenses | 20% tint | USA spec ipod interface | integrated subwoofer system | EBD delete | DEM heatsheild |http://picasaweb.google.com/10580646...NevjZSB6N72mgE
  32. 01-11-2011 11:05 AM #32
    Waste of fuel. Just drive gently (low boost and low RPM) until things start to warm up.
    The Car Talk guys got this one correct!
    2002 Volvo S60 T5 5M (SOLD) - ECU, intake, exhaust - 2:05 at BIR long course || 2006 Volvo S60R 6M Sonic Blue (RIP - saved my life) - 2:03.5 at BIR long course - 2:00 at BIR short course - Road Trip Pics - My HD Trackday Videos - Loud enough for ya? || 2007 Volvo S80 V8 (his), Barents Blue, 35% tint, Sport Package (4C), Heated and Cooled Seats || 2011 Volvo XC70 T6 (hers), Oyster Grey, 35% tint, hood liner removed so I can hear the turbo now
  33. 01-11-2011 11:11 AM #33
    20 seconds isn't THAT long... Buckle seat belt, plug in iPod, turn on wipers. it's usually calming down by then. It's not like i let it run outside for half an hour.
  34. 01-25-2011 11:20 AM #34
    The CEL has turned off as of yesterday after work. I've noticed that the car has a very slight stutter when it is doing the 20 second warmup in the morning and after work, which very well could be causing the code. I am waiting for iPd to reissue their HD R coils (due mid-february), and I will replace them all then, and move injector 3 to position 1, just incase that is the root problem. I am really stating to think that it is the coils and not the injectors. The car starts the same regardless of how long it has been sitting. If it WAS a stuck or leaky injector, it would cause rough, longer cold startups, right?
    BTW, the Volvo code that came up when I had my software update was "ECM-3533 (startup)".
  35. 01-25-2011 11:39 AM #35
    Still a small waste. I'd rather "waste" my gas enjoying WOT when the light turns green than sitting in my garage. I plug in my phone (Trapster), buckle up, tune the radio, hit the garage door button, then start the car.
+ Reply to Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
