Replacing My HU-803 in My Volvo S60R
    Results 1 to 19 of 19
      Hey Everyone,
      I want to replace my stock Volvo HU-803 with an aftermarket double dim nav unit. The car is a 2004 Volvo S60R. I was able to find the double dim adapter for the new stereo but I still have a few questions.
      1: Does the 04 S60R have an external amp?
      2: Do they make a plug and play wire harness?
      3: Will the center channel work?
      4: Do they make a controller so I can still use the steering wheel controls?
      I think that is it for now. Any help would be greatly appreciated.
      Member MrTippy's Avatar
      Aug 2004
      chicagoland
      Blog Entries
      1
      Quote Originally Posted by fcpgroton View Post
      Hey Everyone,
      1. The HU-803 has an external amp, 4-channel for LF/RF/LR/RR, the center channel amp is in the HU.
      2. You can find a plug and play harness on Ebay. google volvo amp cable
      3. The center channel will not work unless you get a Dolby PL or 5.1 (or better) capable HU--of which there are very few if any.
      4. Yes, it is a Dietz controller; $$, call Persan (or Perzan) Auto Sound in Philly. There may be on or two others, but no one has actually tested them, yet.
      All this information is available many times over in the old swedespeed content, unfortunately most of it is not yet back online (it's coming). Try googling, some of it is their cache and do try searching here, too. There was a thread discussing a lot of this that is available since the Great Swedespeed Software Conversion.
      '04 V70 NA -- gone
      Thanks for the info. I normally just search for everything and find it but since the conversion of the board, the search has become useless.
      One last question, will the harness bypass the amp? If not, how would I connect my aftermarket unit?
      Senior Member Chilled Man's Avatar
      Jan 2007
      20 min from Carlisle
      The wife from headunit to amp is some 6 pin or so din cable.
      That din cable doesnt plug into a stock headunit
      I would ditch the stock headunit and go with a Apline Pdx.5
      that will do 75 watt per channel and give you a 300 watt for a sub channel also
      2016 Ford Fusion Titanium 1998 C70 GT
      Unquestionable faith is the Epitome of Ignorance - me
      R Bumper, HID, RICA Dropin Intercooler, ABM Headlights, EST Intake, Samco Hoses, IPD Wires, Porsche Calipers, KSport Coilovers, LED Lighting, 35% Tint, Moda Wheels, Speedtunning, Custom Water Printed Items, OBX Exhaust, IPD Engine Mounts, SNABB Pipe.
    7. #5
      Nevermind, answered my own question.
    8. #6
      Quote Originally Posted by Chilled Man View Post
      Thanks Justin, I found the 6 pin cable online so I am going to try it first. If it does not work, then I will get an new amp.
    9. #7
      Member tuscani66's Avatar
      Oct 2007
      Pittsburgh, PA // Ft. Bragg, NC // Woodstock, GA
      Where did you find a double din dash kit that fits the 2004 s60r?? -I need one...
      Or I'll have to hack a single din and MAKE it a double.
      Keoni - 2004 SR Saphakap MT||VolvoTista: BOV Kit // IPD: Strut Bar Conv, Upper Polly Mount, Trans Polly Mount // Elevate: Track Sways, SS Brake Lines, AMS // Phuzzy: FMIC, HD TCV // WothRline: Custom Tune // Custom 3" DP w/Magnaflow Cat w/ 3" Cut-Out // Custom 3" Exhaust w/Borla XR-1 muffler to dual exit 2.5" (quad tips) & Magnaflow resonator // Custom 3" CAI // SNAAB: Intake // UR: Pulley // (My Diffuser)
    10. #8
      Aug 2004
      chicagoland
      Blog Entries
      1
      Call John at Boston Volvo and order one. The OE unit provides the best match.
      '04 V70 NA -- gone
    11. #9
      I did, he said he will have it shipped out tomorrow or Thursday because he needs to order it first. Should have everything I need by friday..... *fingers crossed*
    12. #10
      Ok, I got everything I need to do the install and will be starting it tonight. I have one quick question about the 6 PIN DIN cable I got off eBay for the amp. Besides the RCA connectors that are attached, it has a second wire that is black and red. I am assuming the black is ground but what is the red wire for? Is this a signal line to the amp to tell the amp that HU is on?
    13. #11
      Oct 2007
      correct
    14. #12
      Ok, the Pioneer AVIC-X920BT is in and working great. The Volvo Double DIN I got from the dealer was a little to big. Basically, there is a 1/2 inch gap on the bottom and a 1/4 gap on the right side of the HU. Other then that, loving the unit.
      I do have one question though. When I was installing the HU with the harness I got off ebay, it did not have the pins setup for the car speed signal and the illumination signal for the parking switch. I am able to add pins to the green connector but I do not know which color the wires are on the stock harness.
      Does anyone have a wire diagram for the radio in the 2004 S60R or could at least tell me what color the dimmer wire is and the car speed wire?
    15. #13
      Member Avboden's Avatar
      Apr 2010
      Spokane, Wa.
      Pictures needed
    16. #14
      Aug 2004
      chicagoland
      Blog Entries
      1
      The VSS (speed), illumination and steering wheels controls are all digital signals over the canbus. You will need a Dietz adapter to get an analog signal for the aftermarket HU.
      '04 V70 NA -- gone
    17. #15
      @MrTippy: I see. I guess I will have to just get the signal to dim the display directly of the parking light switch. Easy enough.
      @Avboden: It was to dark last night to get any good pictures so I will take some today and post them up.
    18. #16
      Ok, here are the pictures of the unit installed.
    19. #17
      Jan 2007
      wheres the trim ring for that ?
      I used doulbe sided tape on the bottom to space it out correctly .
      PM ghoastshadow he will be able to get you the cage and trim peice to finish it up
    20. #18
      Believe it or not, it did not have a trim ring. As for the cage, I will PM him now.
      EDIT: System is saying ghostshadow/ ghoastshadow does not exist.
    21. #19
      FCP, in another thread (may not have been on Swedespeed), someone pointed me to this:
      http://www.crutchfield.com/S-NYxPDjs...ADT-VA133.html
      This might take care of the gapping/spacing that goes on w/this unit, but I've seen Chilled Man with another product that he used on a different HU.
    22. Remove Advertisements
