Sounds like I知 dragging a chain??
    Results 1 to 16 of 16
      Jul 2008
      NH
      Any time I hit a bump it sound like a chain rattling from the front right wheel. Anyone have this?
      Moderator DevolvR's Avatar
      Jan 2010
      Toronto, ON
      Quote Originally Posted by Dubfound View Post
      Axle Ping
      Get XC90 axle bolts..
      04 S60 R MT Titanium Grey/Nordcap thread | pictures DP & Custom Quad Tip Exhaust | 05+ Conversion Exterior & Interior | Sport Kit
      12 XC60 Ice White 3.2 AWD | Heico Kit | Fast 19" FC04A | Running Boards
      Apr 2007
      Bay Area, CA
      I had this happen about 2 months ago, it was a loose bolt on the axle.. sounds like a clinking/dragging chain going over bumps, so same symptoms I had
    7. #5
      Junior Member aharres's Avatar
      Jul 2010
      Allen, TX
      For front and rear? Are axle bolts the bolts right in the middle of the wheel hubs?
      2006 S60 R [Sonic Blue / Nordkap] Killed by italian
      1999 V70 T5 [Mystic Silver Metallic / Grey]
    8. #6
      Quote Originally Posted by staufinc View Post
      Yup, could be lose center caps on the wheels too. Mine used to clink a little on bumps.
    9. #7
      Jul 2010
      Allen, TX
      I thought axle ping was that popping sound when i let off the gas after downshifting going into wot (not the cbv) or when i downshift to first or put it in reverse from drive and vice versa.
    10. #8
      Yeah, ping is an accel/decel problem which is why I initially dismissed the idea, but if the bolt has falen out it could possibly be rattlign around in there.
      Any way you cut it, this guy needs to jack that side of the car up and start grabbing and shaking things to see if he can track it down, could be lots of things over there causing a metallic rattle.
    11. #9
      Jul 2008
      NH
      Quote Originally Posted by Oz60R View Post
      Must be a NH thing? haha. Bringing it to Lovering on Thursday for them to take a look. Its driving me nuts!! I use my car for work all day and this sound is so annoying. Something is def loose.
      It could be
      Could be a worn end link, control arm bushing, strut or spring seats. Only a closer inspection will tell.
      I will update once I find out.
    12. #10
      Jan 2010
      Toronto, ON
      It could be
      Pull out your center cap on the problem side of the car and see if there is a loose bolt rolling around in there.
    13. #11
      I thought I had loose axle bolts this week and checked them-they were fine. What I did find was that the sound I thought was coming from the front over bumps/irregularities was actually separated E-brake shoes. Pull a rear caliper and rotor to check. If a piece of the shoe/pad material lets go it could lock up a rear wheel or take out the whole hub!
    14. #12
      Jul 2008
      NH
      So my axle was out of alignment. Whatever that means??
    15. #13
      Jul 2008
      NH
      You hit the nail on the head!!!! THats what it was. And I think I past you yesterday downtown Concord. I was heading back from the park with my dog.
    16. #14
      Apr 2007
      Bay Area, CA
      I think you did then, on Washington St?
    17. #15
      Jul 2008
      NH
      Yup. Your yellow calipers cought my eye and I almost drove into traffic.
    18. #16
      the only reason I created an account on this forum was to add this response. I can wholeheartedly tell you that it's the carrier bearing that marries your two driveshaft halves. There's a metal cover/cap that conceals the bearing that will seperate from the unit and "skip" around the half shalf as it rotates...I heard this sound under any amount of braking coming from my front right side, i felt vibrations on my gear shifter, my passengers would hear the sound from front left- before I found the real culprit, I replaced my front brakes, front spring/shocks- I thought there was a worn out spring or something making the noise but didnt know where save yourself $260 in rougue maintenance..the take away--> feel on either side of your carrier bearing for that free floating metal cap....$35 to replace by yourself....free to jam the cap back on and drive it till it's time to replace all of your u-joints...
    19. Remove Advertisements
