O1 V70 XC VVT issue
    Results 1 to 10 of 10
      O1 V70 XC VVT issue
      Hi. My car has had code P1332 for a while. I have been running it on synthetic for the last 10k miles in hopes that it was a lubrication issue that would resolve itself.
      Now I also have code P0013. Maybe I just have something wrong with the VVT solenoid wiring? It looked a little crimped when I removed the cover over the coil packs.
      Any ideas are appreciated
      Thanks,
      Alex
      You can try removing the solenoid and cleaning it out with Brakleen then re-attach (get a new gasket!). Could be sludged up beyond help though. Worth a shot before you buy a new one.
      07 VR 6MT, Elec. Silver/Nordkap. Pwr mirrors, Do88 IC, OBX DP, iPd oval exhaust, Elevate bumper grilles, SNABB short shift w/ Abrahms M1 knob, tint, 18" Odysseus reps...
      Update. It has been a while, but I finally replaced the VVT solenoid with a new one from the dealership. Worked fine for about 80 miles but today threw the code 1655.
      Any ideas?
      what is the code 1655??? still cvvt type code??? if it is posible timing issue like the t-belt jumped a tooth or the cvvt hub is sludged up.. or u pinched the wire under the spark plug cover...
    7. #5
      Member XC70XC's Avatar
      Dec 2010
      Melbourne, Australia
      Quote Originally Posted by vlvo-tech View Post
      Maybe need to have it check by the dealership or your local Volvo specialist.
      DC
      V70XC - Cross Country Par Excellence!
      2002 V70XC-R Cross Country - Polarartic/Oak, ESR, 5AT Geartronic, leather package, factory towing kit, tinted windows and screens, tracker, sunglass holder, center console cup holder, nylon cargo barrier, Thule roof racks, R instruments cluster gauges.
    8. #6
      Global Moderator GrecianVolvo's Avatar
      Nov 2001
      Southern California
      What are the symptoms (other than the codes)? Does the car drive hard? Less power? Sounds strange?
      2001 Volvo V70 T5 M SR, Classic Red/Graphite Lthr, TME Stage II ECU, 3" Downpipe w/ Cat-back exhaust from MTE, Volvo Roadholding & Lowering Kit w/ Nivomats, 17" PEGASUS, Rear Spoiler, Dolby Surround Sound
      2017 XC90 T6 AWD Inscription, Crystal White w/ Charcoal Nappa Leather Convenience, Vision, Volvo Trailer Hitch, Polestar
    9. #7
      Dec 2010
      Quote Originally Posted by GrecianVolvo View Post
      Is it possible, the OBD can be in fact be faulty in itself?
      DC
    10. #8
      From VIDA:
      P1655 = ECM-6440 - Camshaft reset valve Signal too low.
      Check resistance of the valve, expect 3.7ohms cold.
      like others said check the wiring really good going to the valve under the cover.
      One wire is 12V whenever the key is on, the other wire goes back to the ECM.
    11. #9
      I was able to solve P1655 by replacing the connector to the new VVT assembly. Actually removing it and connecting directly to the pins. I read on another site that the connection that comes in the kit from dealership can be defective.
      In my case as well, this appears to have solved the problem. I have been about 1000 miles with no CEL.
    12. #10
      Junior Member jda2000's Avatar
      Sep 2003
      Sarasota, FL
      glad you got things fixed, thanks for posting the fix.
      2004 V70 2.5T
      2001 V70 T5
    13. Remove Advertisements
