Brake Fluid Flush
    Page 1 of 2 1 2 LastLast
    Results 1 to 35 of 36
      Junior Member nWoods's Avatar
      Aug 2010
      Ft. Wayne, IN
      Brake Fluid Flush
      It's time to flush my brake fluid and I'm hoping this is something within my abilities. I've never done it before, but it's my first car so I've got to start somewhere right?
      (I'm not going at this as half hazardly as that sounds... hence the questions)
      I was hoping to hear some pointers, shortcuts, techniques, must have tools on the R, etc.
      Currently I was just planning to do the two-person method (one pumping the break while the other bleeds it), but I've seen some other products out there. I'm considering a Power Bleeder based on some good reviews on some other threads, but not sure it's necessary.
      Is there a walkthrough on the site that I haven't been able to find?
      Member Denis's Avatar
      Jul 2008
      CANADA, Ottawa
      if you are doing two person, place a piece of wood under your brake pedal so it would not travel all the way to the floor and damage master cylinder
      there are plenty of walkthroughs on internet and youtube
      Member kmg_S60R's Avatar
      Dec 2008
      Montgomery, AL
      Get a motive brake bleeder... There are two versions a regular and a black label that has better components... Though the cheaper one will work perfectly fine. Then once it is setup bleed farthest from the resivoir to closest, I think it goes, Right rear, left rear, right front, left front, and me personally I would bleed the system using the right rear caliper bleeder until you see clean or new fluid cap it all up actuate the clutch about 10-20 times to get the fluid to blend in and then go through the entire process so that you get it as clean as possible as the clutch uses the same fluid resivoir as the brakes.
      06 Ti Grey SR w/Sport Pkg, Manual, IPD Stage II, Mototec Intake, 3in DP, Track Sway Bars, HD Endlinks, Boost Gauge, Silicone Vac Lines, Upr Engine Mnt, HD Trans Mount. SNABB Intake & Short Shifter,IPD 3" Oval Exhaust, Viva HD TCV, Synchronic CBV, Wg 7psi, Port Matched/Polished Intake Manifold, Victory Performance FMIC w/IMEC. http://www.dragtimes.com/Volvo-S60-Timeslip-19306.html
      If you are going to be flushing the brakes, replace the lines with some SS lines. I ordered a set from TireRack and so far so good and the pedal feel is very noticeable.
      2015 V60 T6 AWD R-Design - Passion Red/Off Black, Platinum/Tech/Climate/BLIS/19" Ixion II, KN Filter, IPD Catback Exhaust, IPD Rear Swaybar {His}
      2016 XC60 T6 AWD - Osmium Grey/Off Black {Hers}
      FS Items: XC60 Cargo Cover
      SOLD:1994 940 Turbo/2004 S40 LSE/2007 S60R/2010 Mazda3 i-touring/2012 S60RD/2013 S60 T5AWD
    7. #5
      Senior Member Warpedcow's Avatar
      Nov 2004
      Apple Valley, MN
      Quote Originally Posted by PureDrive07 View Post
      I respectfully disagree, I think they are a waste of money unless you're doing really serious track stuff with the car. I have Motul 600, TiSpeed Shims, Ferodo race pads, and stock lines, and my pedal feel is fine during hour-long track sessions.
      2002 Volvo S60 T5 5M (SOLD) - ECU, intake, exhaust, 2:05 at BIR long course || 2006 Volvo S60R 6M Sonic Blue (Saved My Life), 2:03.5 at BIR long course, 2:00 at BIR short course, My HD Trackday Videos, Loud enough for ya? || 2007 Volvo S80 V8 (his), 35% tint, Sport Package (4C), Heated and Cooled Seats, IPD Rear Sway Bar || 2011 Volvo XC70 T6 (hers), 35% tint, IPD Rear Sway Bar, IPD Photo Contest Winner in 2015 and 2016, Dragon Slayer
    8. #6
      Aug 2010
      Ft. Wayne, IN
      So, for the flush you're bleeding the brake fluid from the caliper right? If you can access it through your rims should you still remove the wheel? I'm thinking yes because it's so corrosive to paint and a little mistake could ruin your wheels? Is there a mechanical reason also?
    9. #7
      Member inteller's Avatar
      Aug 2009
      Tulsa, OK
      Quote Originally Posted by Warpedcow View Post
      they bump you out of SCCA stock classes too.
      2008 Titanium Grey Metallic C30 R-Design
      2006 Passion Red S60R
      Packages: Premium, Climate Options: Sport Appearance Package, 18" Pegs, 6Spd Geartronic, Navigation
      Accessories: Sunglasses holder, Sirius Radio, Volvo Digital Jukebox Mods:SS DEM Mod
    10. #8
      Member jstro's Avatar
      Jan 2008
      Suwanee GA
      just an FYI - your have 2 bleed valves on each caliper
      totally stock.. honest
    11. #9
      To each his own. I don't feel like it was a waste of money, definitely noticeable on higher highway speeds when I've had to come to an abrupt stop, after stop (gotta love rubber necking in NJ, lol). The guys over at VCNA-Rockleigh were happy I did it and highly recommended it.
      But I respect your choice not to go with them, seems like you have a nice setup. I'm running stock pads and stock brake fluid.
    12. #10
      Junior Member Doogwhan's Avatar
      Nov 2008
      Gretna, Louisiana
      Get the power bleeder.
      Trying to flush fluid manually through the ABS unit will take forever, and as has been mentioned above you risk trashing your master cylinder if you help forgets the block of wood.
      The Motive unit and the fluid will cost you about what the dealership would charge. Spend a little up front, and enjoy cheap painless brake fluid changes from here on out. With two Volvo's and two VW's it has brought my price-per-flush waaaay down.
      +1 to taking the wheels off. Being lazy would actually be more work in this case.
      Brief how for the bleeder from the time I almost drowned my R
      http://www.volvo-forums.com/index.ph...l=motive+power
      All was going well, then it went earth, sky, earth, sky, earth, sky ambulance.
      2004 Volvo S60R- It even has AWD again!
      1992 Volvo 245-
      2003 VW Jetta GL TDI
      1971 VW Transporter DoKa
    13. #11
      Aug 2010
      Ft. Wayne, IN
      Quote Originally Posted by Doogwhan View Post
      That walkthrough is great, thanks for taking the time to do that. I'm definitely going with the power bleeder from Motive that keeps getting mentioned. Now, I just need to figure out where to store 4 jack stands in my apartment.
    14. #12
      Junior Member redalrt's Avatar
      Oct 2006
      Spartanburg County, SC
      Get a power bleeder of some sort. Makes it a one man job. I did it from the furthest caliper to the nearest caliper to the master cylinder. But as I understand it, the actual order is from nearest to furthest (?)
      '04 V70R 6MT, K&N, IPD HD Upper/Lower Engine Mounts, QBM Strut Brace Conversion, XC90 Bolts, Tinted Tails, VST CF Lip, TME Turboback, Wastegate Tweak, IPD Boost Gauge & Pod, Window Tint, Takspeed Safety Cable and Aluminum Pedals, Repainted Center Console, Heico 18" Volution Vs, General G Max AS-03 tires, IPD HD Sways and Endlinks. Removed Engine Bay Wxstripping (for heat dissipation). Zeckhausen Posi-Quiet Low Dust Brake Pads. SOLD!
    15. #13
      Junior Member volvoracer's Avatar
      Feb 2002
      Boston's North Shore
      Don't forget you have 8 bleeder screws, 2 per wheel, 4 outer (visible looking through the wheel) and 4 inner, in same spot on caliper (up high), but inside.
      I spent hours one night getting that information...
      Volvoracer
      *Designer of the SNABB M66 Short Shifter*
      '05 VR Red/Atacama/M66 (1 of 4 in US), many mods, 167k, Brembo, 6-speed
      '05 Ducati 800SuperSport Yellow, Brembo, 6-speed
      '67 1800S S.C.C.A. racecar under restoration
    16. #14
      Dec 2008
      Montgomery, AL
      ^^^^ (All great information and advice) +1
    17. #15
      Member TJM 04S60R's Avatar
      Aug 2010
      Wilmington, DE
      +1 on the above.
      Most important thing is to take your time on any task you haven't done before. Make sure you have a day(or even a weekend) completely free. If you get stuck or something doesn't seem to be going right. STOP!! and figure it out. In the end it will be even more satisfying you fixed it and some Ahole didn't screw something up like Petew mentioned.
      2013 Cadillac ATS 2.0T - Silver, RWD 6MT
      TOTALED 1/10/12 -[/COLOR]2004 S60R Black Sapphire/Gobi, 55K Miles, 6MT
      IPD: R Kelly W/ K&N, Upper Mount, HD Trans Mount, Polly Stabilizer Bushings, Boost Gauge in Bezel Pod. Phuz: HD TCV
      Viva: HD CBV Snabb: Intake Pipe TME: Lowering Springs DEM Heat Sheild Part# 30783129.
    18. #16
      Guys,
      I am planning on doing this also. I just got my 06 S60R acouple months ago. 1 Question, does the clutch need to be bled also? Seeing KMG S60R's earlier post,"cap it all up actuate the clutch about 10-20 times to get the fluid to blend in and then go through the entire process so that you get it as clean as possible as the clutch uses the same fluid resivoir as the brakes. "
      ,it does not appear as if that needs to be done, but wanted to see if some could clarify.
    19. #17
      Jan 2008
      Suwanee GA
      You don't "have" to bleed the clutch, you will just have soem old fluid miked in with your new stuff. It would be optimial to bleed the clutch too but it not like baby seals will be clubbed if you don't
    20. #18
      Aug 2010
      Ft. Wayne, IN
      Is there some reason that the car has to be level to bleed the brakes if I'm using a pressurized system like the power bleeder?
      I've only got two jack stands and am about to move to a place without a garage, so I'm hoping to hold off getting more stuff for car maintenance.
      I was hoping to jack up the back, remove those wheels and bleed the brakes, then move to the front. I know it would be quicker to do all the wheels at once, but I don't mind the extra time. I know I would have to be careful not to let the lowest point of the reservoir get too low since it would be sloped and I definitely don't want air in the lines! But, is there another reason that the car needs to be level that I'm not thinking of?
    21. #19
      Jan 2008
      Suwanee GA
      AFAIK your car does not have to be level to bleed the brakes
    22. #20
      Quote Originally Posted by petew View Post
      Not only were they clueless (4-pot brakes --- they've never seen them or even knew what they were!) ... they stripped a bleeder valve and gave me a car with no brakes !
      I find it funny that the 240's had non sliding calipers and had 3 bleed screws per caliper....so the R brakes should not be anything special to the old timers especially.
      I used to work @ the Volvo dealer and did brake flushes probably once a day...(for maintainence)
      I would like to know how hard it is? or what makes to so hard?
    23. #21
      Junior Member Rues R's Avatar
      Jul 2007
      Fort Carson/Colorado Springs
      So two bleed screws per caliper. So you basically just have to bleed each caliper twice (once from each valve) to make sure the whole caliper gets new fluid?
    24. #22
      Jan 2008
      Suwanee GA
      Quote Originally Posted by Rues R View Post
      You would open the first bleed valve a lot longer to make sure you get the brake line filled with new fluid, the second one you only have to open for a few seconds, you could probably even get by with just doing one, but for the extra 10 seconds it takes you might as well do both
    25. #23
      Jul 2007
      Quote Originally Posted by jstro View Post
      Good knowledge to know! Learn something new everyday.
    26. #24
      Member VTT5's Avatar
      Sep 2003
      Essex Junction, VT
      Quote Originally Posted by nWoods View Post
      Perfectly level, no, but make sure you're not on such an angle that the bleeder screws aren't at the highest point on the caliper -- no good if you can't get all the air out.
      Nautic Blue 2004 V70 T5M (Quaife LSD, IPD Stage 1, IPD sways + end links, Eibach springs + Bilstein HD Sport struts)
    27. #25
      Nov 2004
      Apple Valley, MN
      I've done manual, two person brake fluid flushes many times on both my current R and former T5. It doesn't take long, maybe 15-20 pedal pumps for the longer rear lines. Never used a block of wood either. No problems at all, just don't let your fluid reservoir get low - and even if you do, you'll get a warning on the dash before there is any real problem (ask me how I know).
      Obviously, you do the brake flush with the key in position II (run) but the motor not actually running. That's what the ABS module wants.
    28. #26
      Aug 2009
      Tulsa, OK
      how many bottles of fluid did you end up needing to do this job? I'm getting ready to do my own and really dont feel like overbuying.
    29. #27
      Quote Originally Posted by inteller View Post
      stock class...I wish
      Power bleeders work the best, and they allow you to bleed the clutch as well. I don't feel like reading the entire post, so if someone hasn't mentioned it yet, you want to make sure you bleed the inside of the caliper before you do the outside pots. this gets the cleanest fluid to all chambers by making sure that you are sucking 100% clean fluid to your outer pistons.
      2004 Volvo S60R M66 - Sapphire/Nordkap - PhMIC, OBX DP, AEM Methanol, RICA Stage II, Powerflex front end, XC90 Spring Seats, ViVA CBV, HD TCV, SRP Pedals, K&N, JRL Mod, IPD R Boost gauge w/ CFWerks Door Pod, UR upper chassis braces, IPD Track Spec sways, IPD urethane subframe/engine/trans bushings, 10mm/15mm Front/Rear spacers, Black 18" Pegs, 245/40R18 Goodyear Eagle F1 Asymmetric 2's, 3000k HID Euro fogs, USA Spec, Parrot Bluetooth
    30. #28
      Also, you definitely want to make sure that your wheel is off, there are no "mechanical" disadvantages to leaving it on but that is a great way to destroy your rims ASAP.
    31. #29
      Junior Member FjordMoCo's Avatar
      Sep 2010
      Bainbridge Is, WA
      Can you elaborate on this? I've been trying to get a good bleed for hours- 2-person, power bleeder, different sequences, and I just don't feel like I'm getting a firm enough pedal. Why position II?
    32. #30
      Jan 2008
      Suwanee GA
      car does not need to be on if you use a power bleeder, I am clueless as to why it would need to be on to bleed the brakes manually, probably something to so with the ABS I would guess.
    33. #31
      Aug 2009
      Tulsa, OK
      does anyone know how the Volvo dealers change the fluid? Is standard procedure to bleed from a wheel or take it out the top? I notice VIDA shows both methods but does not advocate one over the other.
    34. #32
      Nov 2009
      Dover, NH
      I read somewhere that the absorbed water in old brake fluid, collects at the lowest point of the system. In the Manual Transmission case, this wold be the Slave cylinder. Any truth to that? It would explain some of the "my clutch went to the floor" events.
      When my clutch dropped to the floor the first time, just by flushing the brakes with new fluid, I got the clutch function back. But I think flushing the clutch would be the preferred way to do it right.
      S60R 2004
      XC90 T6 2003
    35. #33
      Jan 2008
      Suwanee GA
      Yes it woud be best to bleed the as well as you get a more complete fluid replacement. I really cannot comment on the water collecting at the lowest point, as I have not heard that before, I guess it would make sense but I really don't know
    36. #34
      Regarding bleeding the clutch: http://forums.swedespeed.com/showthr...-clutch-system
      Regarding choice of fluid I stuck with DOT 4+ which has the recommend (thinner) viscosity for the ABS 'micro valves'. Not sure how important this is but since I'm not tracking my R I decided that Motul 5.1 (ie DOT 4+) is my preference.
      http://forums.swedespeed.com/showthr...id-questions#3
      LTA
      2006 S60R 6MT BlackSapph/Atacama, Ferrita3"DP/EST-Catback/BMC/CustomCAI/A-Mist/18"PS2/NAV/iMIV/22mmRearSB/TME Springs (installed, finally! )
      2005 XC90 2.5T - Loaded family hauler
      Gone: '02 S60T5 5MT, '96 850T Wagon
    37. #35
      Nov 2004
      Apple Valley, MN
      Quote Originally Posted by FjordMoCo View Post
      Position II (run position) means the ABS and computers are active. I was told by a knowledgeable friend who has done this sort of bleed on dozens of cars that this is the "safest" way to do it.
      If you're not getting a firm pedal, it's probably because you stop pumping the pedal before your friend closes the bleed valve. You need to keep pumping until it's closed. Close it during a PRESS of the pedal, not during the return stroke.
    38. Remove Advertisements
