Front axle seal leak
    Results 1 to 5 of 5
      Junior Member VOGZ's Avatar
      Apr 2007
      Illinois
      I've got a leaky angle gear axle seal (passenger side). Anyone replaced this seal?
      11 Audi S4 - stock
      12.83@108mph 1.86 60'
      03 350Z TT
      10.96@127mph 1.58 60'
      Junior Member ari951's Avatar
      Nov 2010
      Florence Kentucky
      So tranny fluid coming out? This seal is behind the sleeve that connects tranny shaft to angle gear. Not too bad to do if u have a lift. Same job as replacing the sleeve. Read posts on bevel gear question.
      Apr 2007
      Illinois
      Quote Originally Posted by ari lisner View Post
      Negative. It's angle gear fluid, it's the axle seal on the other side of the angle gear. Opposite the tranny. Should be much easier than the other side, just wondering if anyone has done it and has tips.
      11 Audi S4 - stock
      03 350Z TT
      Nov 2010
      Florence Kentucky
      http://www.youtube.com/watch?v=DHgwqWEyyOc
      I believe you have to remove the angle gear to do this. Watch videos, there are 3. I know you have to pull out right front axle to do this. It is not difficult, but you might as well replace the sleeve at the same time, you will be right there.
    7. #5
      Apr 2007
      Illinois
      Thanks for the link to the videos. I know I have to pull the axle, I was just wondering how much other stuff I'll have to take off to pull it. I won't be removing the angle gear, I had a new sleeve installed (updated one) in late 2007, and I'm selling the car in 4 months anyway.
      11 Audi S4 - stock
      03 350Z TT
    8. Remove Advertisements
