IAT Sensor ?
    Results 1 to 12 of 12
    Thread: IAT Sensor ?
      IAT Sensor ?
      The check engine light is on. A quick scan says "IAT sensor malfunction" Any Ideas/ advice ?
      IAT sensors go bad pretty frequently, it attaches to the intercooler piping pre-intake manifold. You can pick one up from Tasca for $80 I think and it's not too hard to replace.
      2004 Volvo S60R M66 - Sapphire/Nordkap - PhMIC, OBX DP, AEM Methanol, RICA Stage II, Powerflex front end, XC90 Spring Seats, ViVA CBV, HD TCV, SRP Pedals, K&N, JRL Mod, IPD R Boost gauge w/ CFWerks Door Pod, UR upper chassis braces, IPD Track Spec sways, IPD urethane subframe/engine/trans bushings, 10mm/15mm Front/Rear spacers, Black 18" Pegs, 245/40R18 Goodyear Eagle F1 Asymmetric 2's, 3000k HID Euro fogs, USA Spec, Parrot Bluetooth
      $25.38 from iPd (though they are out of stock, so you'll have to wait 7 days for it to ship)
      http://www.ipdusa.com/Volvo-S60-P2/E...p-74-395-6208/
      Member TheCastro's Avatar
      Apr 2011
      Maryland
      THRRRRRRRRREEEEAAAAAD RESSSSSSURRRRRRRRECTIIIOOOONN
      Hi all, so I need a new IAT instead of a heated oxygen sensor for my R. It does not appear that IPD sells it for the R anymore (at least when I searched on their site they didn't have an R compatible one). Does anyone know the part number? Tasca's website is down for me right now, but when it comes up I'll need to order one.
      Thanks in advance(d mode)
      My YouTube Channel & My Twitter @TheCastro
      I miss my R, but I don't miss the constant repairs
    7. #5
      Member Our R's Avatar
      Jul 2003
      Minnesota
      Before replacing, I'd reseat the connector. Unplug it and plug it back together. Maybe the connection is just dirty.
      Life's journey is not to arrive at the grave safely in a well preserved body, but rather to slide in sideways, totally worn out, shouting "Holy ****, what a ride!"
    8. #6
      Member jstro's Avatar
      Jan 2008
      Suwanee GA
      Both Range Rover & Ford use the same sensor, do some searching & you will find a thread with the appropriate part numbers, it will cost you less that 1/2 of what the official Volvo part will
      EDIT: I was mistakenly thinking about the FPS, please disregard
      totally stock.. honest
    9. #7
      Apr 2011
      Maryland
      Quote Originally Posted by jstro View Post
      I did some searching using google, the other threads were less helpful than this one, and it's only 3 posts long.
    10. #8
      Apr 2011
      Maryland
      Quote Originally Posted by Our R View Post
      I prefer to just replace things, I mean heck, I already replaced the angle gear, what's another $50?
    11. #9
      Senior Member 850arrrsaylikepirate's Avatar
      Oct 2007
      Bay Area, CA
      Check it ---> Linky
      and for those that are lazy here's the gist of it:
      Quote Originally Posted by 850arrrsaylikepirate View Post
      31303975 is the correct part number for the R
      And to be clear, the IAT (Intake Air Temperature) sensor is also called the MAP sensor which is also called the Boost Pressure sensor. Its all wrapped into one for the R.
      2006 S60R - Black Sapphire~Nordkap~GT~iPd Track Spec Sways~TME Springs~TME DP-Exhaust~Bell FMIC~iMIV~E-Codes
      2009 XC90 3.2 AWD - aka the kiddo hauler
      1997 4x4 Nissan - Fook mi this thing is slow
    12. #10
      Apr 2011
      Maryland
      Check it ---> Linky
      Thanks 850. The only other one I found was with the same pic, but number 4 circled, no part number (would have been wrong anyway). I knew it was the MAP, but didn't know people called it the boost pressure sensor, I just knew it had to do with the boost pressure.
      So do I want to look for the 8677288 that you highlighted or the 31303975 you wrote at the top?
    13. #11
      Oct 2007
      Bay Area, CA
      31303975 is the correct part number for the R.
      Ya, the highlighted number in the pic was from a different thread, and shows the wrong part number hence me bolding the correct number at the top. If one looks closely you'll see that 8677288 excludes the B5254T4 (the R motor).
    14. #12
      Apr 2011
      Maryland
      Cool. I figured that's what you meant and on tascas site it said w r model so I ordered that one. Thanks.
      Sent from the seat of my pants
    15. Remove Advertisements
