+ Reply to Thread
Page 7 of 9 FirstFirst ... 3 4 5 6 7 8 9 LastLast
Results 211 to 245 of 289
Thread: 66 Volvo P1800 Custom Build ( Pro-Touring Ls1 V8, Body Mods, and Flush Mount Glass)
  1. 06-08-2011 12:40 PM #211
    Here are some pictures of the 14 inch Wilwood Drilled/Slotted Rotor and 6 Piston Caliper kit.. The other 11 inch Drilled/Slotted Rotor is an upgrade also, which will be considerably less. The kit comes standard with the 11 Smooth Rotors.
    I will have some updated pictures of the complete Front end kit later this weekd.
  2. 06-08-2011 05:13 PM #212
    Here are some pictures of the Crossmember/Suspension components.. I will Post some more pictures when it if fully assembled.
    This is a DIRECT BOLT IN KIT....
  3. 06-08-2011 08:53 PM #213
    I have been getting emails about some more pics of the Crossmember, here are a few more.. I am waiting on the tie rod ends and another ball joint for the bottom, so I can complete the other side.
    Before I get comments on ball joint and geometry questions, keep in mind there is no LOAD on the suspension.. Once the load is on, there geometry and ball joint position is just right..
  4. 06-09-2011 11:58 AM #214
    Here are a few pictures with both sides together and a wheel installed.. I am getting ready to put it in place today, and double check the motor mounts..
  5. Junior Member 64pvolvo1800's Avatar
    May 2006
    Atlanta
    06-09-2011 12:18 PM #215
    The only question I have is how much would you charge if I brought my 64 1800 to you for restoration and updating? I'm dead serious. I'm not looking for a corvette engine but a V6 or I4 would be fine. Are you interested and could you do it by the end of the year?
  6. 06-09-2011 01:10 PM #216
    Quote Originally Posted by 64pvolvo1800 View Post
    Feel free to give me a call anytime... This is the exact reason I am building the front and rear units as direct bolt in's... I am planning on offering a Re-Badged Volvo Amazon and P1800 with the best of everything possible.. They will be sold as completely redone and revamped cars. On motor options, I would still recommend the LS series V8, you dong have to be at 500 horse.. There is a great 350 Horse LS1, and the fuel economy is better than the orignal Volvo.. ha ha
    Robert Jackson
    Diversified Auto Group
    Classic Auto Glass Innovations
    580-263-0454
    Classicautoglassinnovations.com
  7. 06-09-2011 09:39 PM #217
    Here are some pictures of the crossmember installed.. I am taking for alignment tomorrow.... The used wheels I got a deal on, arent quite the correct offset.. Damn it.. I am thinking I am going to drop to 18's...
  8. 06-10-2011 09:57 PM #218
    The car pictured above has the 2 inch drop spindles, which shows the extreme it can be set up at.. There is enough suspension travel and alignment capability to set the car on the ground.. With the Standard Spindles, you can get back to factory ride height...
  9. 06-25-2011 01:16 PM #219
    Ok here is an announcement.. I have had too many people asking me what is going on, and why I am working on these Early Model Volvo Components, so here it is.. This is the reason for the components I am working on...
    As you all know I have moved forward with the front suspension kits, and they
    are on the Market now.. The interest has been high, and the interested have
    stepped up for purchase. We have a few Major Volvo Parts Dealer's (You may be
    Surprised Who) that have picked up the suspension lines. The rear kits will be
    available in about the next 30-60 days, I will post info and picks later.
    There has been alot of interest in other products that we are working on, and if
    the same interest is there, I will put them on the market also. I would also
    like to know what else you guys may like to have available.. I am not looking to
    do reproduction parts, I am looking for updated parts or features.
    Here is what we are working on at this time.
    UNIQUE SUSPENSION SOLUTIONS Will Offer...
    Front Suspension kit: is done, and on the Market
    Rear Suspension kit: will be on the market shortly, and will include 3
    variations.
    First: A rear Coil over conversion kit, that will bolt to the Volvo Body and
    rear end, and it remove the original Coil Springs and shocks.. This kit will
    give you more ride dampening control, along with ride height control. It will
    also eliminate the typical rear suspension sag.
    Second: A complete new Rear End Assembly.. This is a Mod Light Ford 9in rear
    end that is a direct bolt in.. It can use the factory coil spring and shocks,
    but will give Gear Ratio Options, Traction Options, Brake Options, and be alot
    more durable with plenty of parts support.
    Third: A bundle of both packages for the best of durability and Adjustability.
    The coil over kit is made to work with both the Original Volvo Rear end and the
    New Design rear end we will offer.
    CLASSIC AUTO GLASS INNOVATIONS Will Offer....
    This company will be offering Flush Mount Windshields and Back Glass's. These
    kits will remove the need for the Rubber seal that leaks and causes rust out.
    Plus it gives the car alot cleaner look, with less bulk from the rubber.
    SWEDISH SKUNK WERKS Will Offer....
    This is a new company that is working on new products on several fronts..
    Swedish Skunk Werks will be offering Restorations and Restored Vehicles for
    sale. These vehicles are not Original, they will only be built with the
    products stated above and below. We will have two levels of car:
    A Resto-Mod version.. This car will appear original in appearance parked or
    going down the road. However, it will not be original in
    drivetrain/Suspension/Comforts. They will be a General Motors LS Series Based 350 Fuel Injected Horsepower with a Performanced Based and Durable 5-Speed,
    and higher fuel economy than the original Volvo Platform.
    A Pro-Touring Version.. This car will appear to be a bit different, with some
    slight body mod's and clean ups. Flush Mount Glass Kits, A General Motors LS6 Series Engine at 500+ Managable (Daily Driver and Economic)
    Horsepower, A performance Based and Durable 5-Speed, the best of the Adjustable Suspension and Large 14 inch brakes all
    the way around. They will only come in certain colors with certain badgework.
    They will have some Unique Options in Performance and Comfort, that the
    Resto-Mod version will not offer.
    SWEDISH SKUNK WERKS is working on these items as we speak..
    A working direct bolt in AC/Heat unit.. Swedish Skunk Werks has joined with
    Vintage Air to offer a quality package. This unit will be compact and more
    efficient than the original add on.. If you are running the original motor, it
    will take less effort to operate it.
    New Updated Gauges. These guages will now be electronic, but they will be a
    direct replacement to the original. The speedo will use a GPS signal, so there
    will be no need for calibrations for tires, gears, ect. They will be original
    in appearance, but we will also offer some classic Resto-Mod look guages as an
    alternative.
    Direct Bolt Power Windows.. These kits will eliminate the cable regulators that
    the cars currently have, and replace it with a quality power window regulator.
    New Interior Panels... We will have direct replacement door panels and other
    interior panels.. These will be retro, but they will be updated in materials and
    appearance. They will also offer the Power Window option and the standard crank
    option. Also working on direct replacment seats with Headrest.
    So there is what is in the works, and just like the Suspension Kits and other
    products I have done for other vehicles, these products will happen for my
    builds.. Now the only thing is, is there enough interest in these products to
    set them up for Mass Production? Let me know if you are interested, and do let
    me know if there is something out there you would like me to see if we can get
    it done..
    Thanks
    Robert Jackson
    DIVERSIFIED AUTO GROUP
    Unique Suspension Solutions
    Swedish Skunk Werks
    580-263-0454
  10. Junior Member
    May 2011
    Vancouver, WA
    06-25-2011 07:34 PM #220
    Congrats, and thanks for the update.
    Currently in the market for 122, so glad to see that these types of quality products are available.
    Good luck in your endeavors!
    '63 122 2dr, Daily Driver
    '74 142, Project
  11. Global Moderator
    Aug 2004
    Temple, Texas, USA
    06-25-2011 09:12 PM #221
    Quote Originally Posted by John Douglas View Post
    ...Currently in the market for 122...
    Good show!
    Consider starting a thread here...
    http://forums.swedespeed.com/forumdi...220-(1956-1970)
    ...or here...
    http://forums.swedespeed.com/forumdi...hp?39-Want-Ads
    ...and we will go shopping for your Amazon!
    George Dill
  12. 06-25-2011 09:18 PM #222
    Quote Originally Posted by gdill2 View Post
    Good show!
    ...or here...
    George Dill
    Working on the Logo and Website as we speak... I sponsor other forums (Not Volvo at this time), so I will sponsor this one also... My retailers that are signing the contracts, already sponsor this website, but I will do the same for sure. I really dont have to have you point these things out, and if the Moderator or Mangagment of this forum has an issue with it, I havent heard. I am sure they are monitoring my threads and what I am trying to do, and that it is something that is in the works and being refined. I have contacted them also, and dont need you cluttering up something you are not even interested in.. You dont have to read the threads, and trust that I have my affairs in order...
  13. 06-25-2011 11:03 PM #223
    Quote Originally Posted by Iamtheonlyreal1 View Post
    Huh? Seems like the response doesn't match the quote. Maybe I misread something? Not trying to add drama just curious. Liking the build. Adding Volvo products is great!
  14. 06-25-2011 11:45 PM #224
    Quote Originally Posted by nonhog View Post
    Oh, that is because there is a bit of history with this with the same person. He was jabbing at a discussion we already had to make his presence known.. My first post on here was to promote my Project Changling build, to get feedback on it from the Volvo Community. I was then contacted by members here and elsewhere to make mulitiples of parts like the front suspension and other things, so I tried to find resources for them.. It turned out that I couldnt get the company's to support it as necessary, so I decided to take it to the next level, because the interest and demand was there. So, now that I have been phishing for Ideas and feedback on the products, because I am trying to make sure they work for everyone, without hurting myself financially, he wants to chime in like I am doing something wrong.. Once I have my business model up, and my advertising in affect, I will promote and advertise properly.. Right before this point, I didnt have a viable product at all, so there was no need for .com's or advertising..
  15. Moderator R Salesman's Avatar
    Jan 2005
    Fayetteville, NC
    06-27-2011 10:25 AM #225
    I really like what you're doing, and I think it's brilliant. I've been saving money to purchase a CTS-V wagon in about a year and a half -- but I'd rather stay Volvo if I could.
    I think I'll wait and see your final product, and the final price. If I could get a Pro-Touring 1800 (I'd prefer a 6-speed manual) for my jollies, and a used V70R to haul the kids in, for less than the cost of a CTS-V . . . then I think I'd much rather do that, and you could be hearing from me.
    Have you looked into what you'd need to do as a auto "resto-manufacturer" in order to allow banks to be willing to finance your cars? I don't have tens of thousands laying around, so financing would be a necessity for me to purchase a complete car from you.
    Lee,
    2013 Jetta Sportwagen TDI 6MT, Platinum Gray/Titan Black (his)
    2013 Jetta Sportwagen TDI DSG, Tempest Blue/Cornsilk Beige (hers)
    1974 164E
  16. 06-27-2011 12:05 PM #226
    Quote Originally Posted by R Salesman View Post
    I will definitely cross that road when I get there... I have a few guys that can get that done for me. It is a bit of a chore, since the value of the cars arent as high as what I will need to get. I will have to set some kind of precedenct with prior sales or restorations to show what the potential value is, along with detailed appraisal and parts break down. My 68 Camaro I had appraised and sold did 125,000 dollars, eventhough the Classic NADA Value wasnt there. When you start playing in this area as the consumer, it really just matters what relationship you have with your personal bank.. There are other Classic Car finance Groups like Hagerty's that will do it at a bit of a higher rate, but they offer something like 20 year financing.. LOL
  17. 07-05-2011 04:11 PM #227
    Here are some pictures of the first round of the Rear End works.. It is a very
    solid and heavy duty housing, but weighs less than 80 pounds minus the gear
    set.. It looks larger, but the actual pumpkin housing is about an inch bigger,
    which translates to a 1/2 lower clearance position...
    I am still working on the final mounting plates, but this will give you the idea
    of the quality that is going into it... It will accept the General motors
    Calipers with the Emergency Brake feature with a 11 inch brake rotor...
    These rears are also the largeer 31 spline quick change axles, and the gear set
    will offer any gear ratio and traction option you could need.
  18. Member
    Mar 2008
    Sarsfield, ON
    07-05-2011 09:02 PM #228
    Nice work. Given that the cars for which you are making these modifications are liable to be driven "enthusiastically," did you put baffles at the inboard ends of the axle tubes?
    '88 244 auto (parts car), '89 244 5 spd. (daily driver), '92 245 5 spd. (my car) '80 Holiday Rambler/Ford E350 (tow vehicle and track crash pad), '95 GMC K2500 (local hauler/back-up tow vehicle), '83 Mazda RX7 (race car when I have the funds), '99 Miska 20' car hauler.
    The man's prayer: "I'm a man, but I can change, ... if I have to, ... I guess."
  19. 07-05-2011 09:19 PM #229
    Quote Originally Posted by John2x240 View Post
    There are inner axle seals that press in right at the axle openings of the 3rd member that will keep the gear oil from running up the axle tubes.. It will keep all the gear oil in the pumpkin area during manueuvers.. The Hub bearing are lubricated with wheel bearing grease, and does not depend on the gear oil in any fashion... So yes, that issue is addressed.. ha ha
  20. Member Avboden's Avatar
    Apr 2010
    Pullman, Wa.
    07-05-2011 09:20 PM #230
    As always, let us know when it's ready and been tested a bit! Very interested/excited.
  21. 07-06-2011 10:03 AM #231
    Just wondering why your using the quick change style axle / hub and not the standard "flange" type. Is it a weight issue? I would think the standard type would be less expensive but maybe not Just curious I see absolutely nothing wrong with it.
  22. 07-06-2011 10:54 AM #232
    Quote Originally Posted by nonracer View Post
    I am using this style for a couple of reason... Weight, the hubs are aluminum. And ease of service down the road or track.. With this set up, I can take my track cars out, and if I have any issues at all, I can swap parts with ease and or change my gear ratio for what ever reason I see fit... Sure it is a bit more, but from my experience it is always best to just go all the way at the beginning, that way you are less likely to say "why didnt I step up on that option" ha ha
  23. Member
    Mar 2008
    Sarsfield, ON
    07-06-2011 09:08 PM #233
    Hmm. Inner seals ... nice fix.
  24. 07-06-2011 09:42 PM #234
    Tested and approved for years.. LOL
  25. Member
    Mar 2008
    Sarsfield, ON
    07-07-2011 06:13 PM #235
    No doubt, but not on any of the old used cars that I could afford.
  26. 07-17-2011 07:26 PM #236
    Here is an update of the rear end mocked up in the Amazon body.. I have some New Design Adjustable Aluminum Rear End Links and Panhard Bar being manufactured for this application, and for a stock arm replacement package. The custom link kit will directly bolt to the body and factory rear end assemblies also, which will help with replacement bushing issues for the factory links. This will also allow for all the possible adjustment I need, and allow this rear end assembly to go in all the models of Amazons and P1800's. This is mock up mountint is with the factory springs and shocks, to show that it is a direct replacement for the factory rear, but we also have a Coil Over Spring Conversion kit to eliminate the original coil springs and shocks. This will allow for better vehicle set up, and will also eliminate the pesky suspension sag these cars are plagued with.
    These rear end assemblies will be offered in several packages.. Just the Floater rear end assembly that you can install any 9in ford carrier you may have.. A complete unit with carrier assembly already installed, and with your gear ratio and traction specs. With or with out the Coil over conversion. The links will be offered seperately for people that want to use them with the factory rear ends, but will have to be purchased with the New Design rear end assembly for ease of install.
    Along with the gear ratio and traction options, these assemblie have numerous brake options up to 14 inch brakes. The pictures below, show the base level kit with general motor calipers. These calipers do have an emergency brake application, so nothing is lost there.
  27. 07-21-2011 06:20 PM #237
    Hello
    I would like to ask you some questions about your build and one I am planning. I have always loved the style of the P1800, and you are right they were underappreciated. I saw you wanted to do the 2JZ swap but decided against it due to room and fitment issues. I was wondering if you knew the wheelbase and track of the P1800. I want to fit the P1800 with a Mitsubishi Evo 8 drivetrain and suspension. My other project is a 1963 Austin Mini Cooper converted to a rear wheel drive with a 1994 Mazda RX7 rotary Eng. I wanted your opinion on the all-wheel drive conversion and I would really like a little more details on your body mods. Thanks for your time
  28. 07-21-2011 10:16 PM #238
    I would be happy to answer any quesitons you may have.. I dont know the wheel base off the top of my head, but the track width is 54 inches... I am actually changing my track width to 56 inches with the the optional rear end we offer. We have the 54 and 56 inch track width rear end kit, for these applications. I couldnt advise about the transplant you are considering, but I dont like to cut the whole body structure out of the car to transplant it on another completly new platform. That is why I am offering direct bolt on supsension and transplant kits.
    As far as the body mods, just let me know what details you need to know.
  29. Junior Member
    Aug 2011
    Northern Virginia, USA
    08-19-2011 02:01 PM #239
    It's been almost a month! That's a long time to sit here salivating.....
  30. 08-19-2011 03:20 PM #240
    Quote Originally Posted by junglejimbo View Post
    Ha Ha... Alot of work going on behind the scenes... Which will cause another full and rapid update process.. We have a custoemr build that we are getting ready to start a build thread on . Project Saint Marie will be showcasing all of our components and options, but will appear to be factory, a true sleeper project, but is bieng build for the Better Half of the couple for a normal driver.
  31. 09-17-2011 07:32 AM #241
    have just discovered your amazing work and artistic talent. i must have one of your front crossmember setups and will work towards that. a couple of questions if i may and i apologise if you have answered this before. what car does the rack come from and what is the steering ratio compared to the original box . i have read of others going down this road and have had issues with the ratio being too slow with too many turns lock to lock and on the other hand of the ratio being too fast with the resulting steering being too twitchy. have you driven your car yet and how has the handling changed? i have put 1800e rear ends in both my 1800 and amazon and am hanging out to see your coil over kits for the rear. great work, cant wait to see what comes next
  32. 09-17-2011 10:35 AM #242
    Quote Originally Posted by qf021345 View Post
    Yes I have driven a Amazon with the kit installed. The steering racks are Mustang II 20 to 1 , and a Later Model Mustang GT Rack that is 15 to 1. Twichy steering doest not come from the steering ration necessarily, it comes from poorly setup suspension geometry. The feel of the suspension is more of a later model car, it isnt boat like aor swaying anymore. If I had to compare to a type of car, it would be between a later model corvette and bmw. The ease of steering effort comes from removing additional components and joints, and these kits steer with 8.5 wide front wheel with easy one handed steering in parking lot manuevers.
  33. 09-18-2011 04:10 AM #243
    thanks for your quick reply. sounds good. my cars are right hand drive and what specs would you have to change to suit me? also keen to see your vintageair setup as well.
  34. 09-18-2011 09:06 AM #244
    We have right hand drive setup, so no issue.... I am also set up for international shipping...
  35. 09-28-2011 12:34 PM #245
    First of all. Amazing build! On probably the best looking Swedish car ever produced! And probably the Only Volvo I could ever see myself owning (Said by a swede who actually doesn't like Volvo at all! except the P1800 )
    Nice to see more people taking the P1800 to where it should be! The B18 engine was perhaps not the best thing they put into that car... Something alot sportier would prob. have made it more popular!
    Anyways, I don't know if you have seen Leif Tufvesson's P1800ES? Somewhere in the back of my head I think that the vox rendering were created as inspiration for his build, and the interior in that car, especially the dash, might give you some inspiration aswell! I.m.o. Tufvesson's dash looks perfect!
    Here's a build thread of that car: http://www.gatbilar.se/forum/viewtopic.php?id=10116&p=1
    And here's a pic of the dash: http://www.gatbilar.se/galleries/805...ddac54e716.jpg
+ Reply to Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
