+ Reply to Thread
Results 1 to 3 of 3
Thread: XC90 intercooler questions(s)
  1. Junior Member hfwilkesjr's Avatar
    Nov 2010
    Central Jersey
    04-26-2011 04:50 AM #1
    It's kind of an if/then question.
    Are the intercoolers for the xc90 T6 and the xc90 2.5T the same?
    If they are not, do you see any proplem with using a T6 intercooler in a 2.5T?
    If they are the same, am I safe to assume that the intercooler of the 2.5T can handle a turbo bump (ie., 16T turbo)?
    Thanks!
    05 S40 T5 fwd
    Elevate IC, intake pipe, silicone hoses, CBT, TCV, tune & torque mount
    Spec SMF, Snabb shorth throw shifter & s60r clutch
    Viva cross drilled/slotted rotors, EST DP & cat back
    I definitely need some sticky summer tires. To be continued.....
  2. 04-26-2011 07:19 PM #2
    Quote Originally Posted by hfwilkesjr View Post
    Thanks!
    We haven't tested it, but based on Volvo parts look up information the intercoolers appear to be the same.
  3. Junior Member hfwilkesjr's Avatar
    Nov 2010
    Central Jersey
    04-26-2011 08:09 PM #3
    Thank you Scott
    05 S40 T5 fwd
+ Reply to Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
