Crankshaft Position Sensor Location 2004
07-13-2011 06:16 PM
#1
Can someone point to where the Crankshaft Position Sensor is on the 04 S60/V70 Turbo engine?
Link to larger image: http://imageonthefly.autodatadirect....OC171C3104.jpg
it's on top of the transmission where it (the transmission) mates to the engine. a 10mm nut secures it to its bracket.
When changing mine, the two wires pulled out of the connector - what is the color code for the plug? Thanks!
Posting Permissions
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
