Motorola Atrix Bluetooth Pairing/connection problem
    Results 1 to 6 of 6
      Sep 2011
      Emerald Beach, NSW Australia
      HI
      I have recently changed from an Iphone to a Motorola Atrix but am having difficulty getting it to connect.
      The Iphone worked flawlessly.
      The Motorola not so. it shows as "paired but not connected" If I manually select the connect button on the phone it will sometimes connect but often drops out.
      for what it is worth I believe the the problem is with the phone and not the XC60.
      Anyone else had this problem and know of a fix?
      thanks
      Junior Member kevinG's Avatar
      Jul 2003
      Northern California
      I work for a gateway company that provides a product that handheld devices connect to. There seems to be more than the usual interop issues with this device. It also behaves different than other Android devices. However, this is not the only Android device that we are seeing major issues with. The only suggestion I have right now is to monitor for Atrix software updates. Or, return the Atrix and get another device to show vendors early release of products is not acceptable. Good luck on your Alpha testing
      2015.5 V60 Drive-E T5, crystal pearl, platinum/tech/BLIS, July 2015
      2012 XC60 R Design, electric silver, off-black, platinum/climate/tech/BLIS, OSD in Nov 2011
      2013 Jaguar XJ
      Dunno about the Atrix, but I have had some success with "problem" phones by reversing the standard pairing procedure. Delete the phone, then initiate pairing from the phone and put the car Bluetooth Hands-Free in discoverable mode. No guarantee, but it might be worth a shot.
      Current: 2015.5 V60 Drive-E T5 FWD, Seashell/Beige, Platinum, BLIS/CTA, Front Seat Heat, 18" Titania Rims, Urbane Wood Trim
      Current: 2015.5 V60 Drive-E T5 FWD, Power Blue/Off-Black, Platinum, BLIS/CTA, Front Seat Heat
      Past: 2012 XC70 T6 AWD; 2012 S60 T5; 2010 V70 3.2; 2008 S40 T5; 2007 V50 T5; 1981 245 DL
      Mar 2011
      RI
      Quote Originally Posted by volvobuff View Post
      Concur, this is how I got my phone to work
      2011.5 XC60 3.2 AWD/Saville Grey Metallic/Anthracite Black Leather/Premium/Climate/BLIS/Rear Cam/HID6k
    7. #5
      Feb 2011
      SF Bay Area
      I have a Motorola Photon which is a sibling to the ATRIX. I had a similar problem until I realized that there was a secondary pairing that I was missing. A request was being made to access the phonebook. Once I saw this notification and answered in the affirmative my problems disappeared.
    8. #6
      Sep 2011
      HI
      thanks for the advice. I tried all of the above with no luck...so I "politely" took my Atrix back to the phone dealer and "asked nicely" for a different phone.
      I now have an iphone4s and so far so good.
      Once again thanks.
    9. Remove Advertisements
