+ Reply to Thread
Results 1 to 7 of 7
Thread: Modern front seats and belts ideas
  1. 04-15-2012 05:31 PM #1
    Anyone got ideas on comfy front seats with headrests and a seat belt system that will fit PV?
  2. Global Moderator
    Aug 2004
    Temple, Texas, USA
    04-16-2012 11:23 AM #2
    Quote Originally Posted by volvo miester View Post
    Can you weld?
    George Dill
  3. 04-16-2012 01:56 PM #3
    Yes I can
  4. Global Moderator
    Aug 2004
    Temple, Texas, USA
    04-17-2012 10:29 AM #4
    Yes I can
    Plan to install all-new seatbelts - any aftermarket 3-point system with full retract and lock-up will work just remember that your new front seats will need to tilt forward for access to the back seat.
    Any individual-bucket front seat from a two-door car will work. Avoid captain chairs and seats with built-in armrests/seatbelts.
    If you are good at upholstery source salvage seats needing new covers/pads.
    If you stay with manual seat controls (unheated) the install is much more simple.
    Ideally you would want full-recline, adjustable lumbar and adjustable headrests.
    When removing seats from a salvage car be sure to get all brackets, rails, etc. to include any removable mounts.
    For real luxury source a pair of front seats from an early Mazda Miata.
    George Dill
    http://www.volvotips.com/index.php/p...ries-pv-duett/
  5. 04-17-2012 11:29 PM #5
    Quote Originally Posted by gdill2 View Post
    George Dill
    Thanks George...I will go to the salvage yards and use your advise
  6. 05-23-2012 09:46 AM #6
    and whatever you do, if you install an electric seat be sure to fuse it else tall dude will inevitably want to drive your car, will move the seat ALL the way back and cut wire on your newly welded seat bracket thus ensuing *FIRE!* ask me how i know this (p.s. a battery discconect switch inside the cab is not a bad idea if you are not sure everything is fused correctly)
  7. Junior Member 64pvolvo1800's Avatar
    May 2006
    Atlanta
    05-23-2012 10:44 AM #7
    850/S70 seats or Corvette seats will work as well. Gary has used these in his 1800/ES renovations successfully and they look great too.
    12 S60T6 AWD, 98 S70T5M, 98S70M, 64P1800 CorVo
+ Reply to Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
