New member. Just got an 04 V70 R - Page 8
    Page 8 of 9 FirstFirst ... 4 5 6 7 8 9 LastLast
    Results 246 to 280 of 299
    1. #246
      Quote Originally Posted by RVAE34 View Post
      Bimmer rescue is good only if you are an enthusiast imo. Otherwise you will be reeling from sticker shock on quotes. If you take your car in for an oil change, they will give you an invoice for $10k in work they suggest...
      So are you saying they charge more than the dealership? Or just saying they want the vehicle to be in mint condition? I'm good with Mint condition because its the other halfs vehicle and you know I hear about anything that is off or wrong! I don't enjoy feeling ripped off though.
      Simple example of an oil change. Normally I do all changes on our vehicles but anymore the dealer charges about $90 a change. I can't even order an oil change kit off ECS for less than $105 + Shipping. Now that the dealer is 10 min away its basically a no brainer to drop it with them.
      I did call and talk to Mike and he seemed pretty knowledgeable right off the bat and talked me through their process over at Bimmer Rescue. Probably call back tomorrow and line something up for the following week with them and see how it goes. Never used an indy shop before. See if they can also fix the terrible balance job on a new set of tires the dealership put on.
      Quote Originally Posted by ZZZZZZZ View Post
      You mean the titanium one? m66?
      Yes, know anything about it?
      EDIT: Just found it in the classifieds, found it on eBay originally.
    4. #248
      May 2012
      Richmond, VA
      I just mean that I used to send clients etc to them who didn't know about cars. They would go over the car and find every single possible thing wrong and put it on an invoice. They weren't telling them that none of it was mandatory or a threat to the vehicle's safety/longevity etc. But for a regular person, they might assume all that stuff needs to be done. I even tried to tell the owner not to do that to people I sent over but he continued so I stopped sending them. Patrick is a great guy and they have a great new shop. I refer people in the know to them but not people who are uninformed. But since my buddy Clay started working with Thayer, I have been sending people there because it seems like the labor charge is lower. I have never verified that though. I use Import Autohaus personally simply because it's close for me and they know me so they never try to take advantage. In fact, most bills come in slightly under quote. If Thayer/Bimmer Rescue/Delta V were closer, they would be my go to. I used Import to do all the X5 work, Delta V did cam seals and timing belt on the R and Thayer built the diff in my M7 as well as the BBK install on my old LSx 427 E39 touring. I have a 4 post lift and do a lot of my own work but ever since my son was born, I let shops do the stuff I just don't feel like messing with
      2004 V70R Auto, Black sapphire- gobi l Snabb FMIC & downpipe l IPD 3" cat back exhaust l Evolve CAI l IPD sway bars l Viva rear lower chassis brace l 5/20/35 Tint l IPD grill l Pioneer 4400 HU l JL Audio W3 12" l JL Audio JX5001 digital monoblock amp l Anthracite powdercoated 18" pegs l Morimoto mini D2S bi-xenon projector retrofit
      2001 BMW E38 M7 build with fresh built E39 M5 S62 V8 and ESS supercharger/6 speed/M5 diff
    5. #249
      Mar 2017
      Northeast Florida
      Bumper coater. Medium smoke is the color.
      Thanks....just ordered!
      2004 S60R Ti/Nordkap GT
    6. #250
      May 2012
      Richmond, VA
      Just make sure you prep the console well. Wash it really good and wipe down with some alcohol etc. The SEM stuff says it has plastic adhesion promoter built in but I still sprayed some first.
      I am torn on which direction to go with the car. I am tempted to do some performance mods but not sure what’s the best bang for buck. It is an auto afterall as well…. I was thinking replace the muffler with a Borla XR-1 as those are my favorite aftermarket, my friend has a nice intake for it as well as a new set of door panels. I definitely will be doing the front lower and rear upper arms soon and have thought about doing the rear subframe bushings. Curious how difficult those are to do and if they go bad as often as the ones in the BMW E39 wagons. I would like to do sway bars too but that seems like a pita to do since the subframe has to be dropped IIRC. Would love any advice on some of the better items to start off with on a car with 145k.
    7. #251
      Junior Member Jorge_2825's Avatar
      Mar 2014
      Denver, CO
      Here is my BMW. It's a 1992 525i 5 speed. I replaced the 2.5 non variable timing motor for a 2.8L variable valve timing and added M3 S50 cams. My best friend and I put together the turbo kit using an M3 manifold and universal IC piping. Garret GT3076R with .63 A/R. TRM tuning with 60 lb injectors. 3" turbo back exhaust with a Borla XR-1. Vogtland springs, Koni shocks, Wilwood 6 piston calipers with E38 750il rotors. M5 seats, black headliner, Acura TSX projectors, Euro trim, AC Schnitzer type III wheels, Poly and spherical bushings, poly subframe mounts. The car is currently making 375 RWHP and 360 ft lbs of torque.
      How did you fit the S50 cams on a M52? I thought those were not interchangeable? I use to own a 95 325i, a 97 M3, 95 M3. Great looking E34!
      2005 Volvo S60R: Custom FMIC, OBX Downpipe, Custom Catback, R Kelly Mod
    8. #252
      May 2012
      Richmond, VA
      S50 and s52 cams work in the m52 head. My m52 made 200 rwhp w just the cams and 413 dme.
    9. #253
      Mar 2017
      Northeast Florida
      Thanks....I ordered the adhesion promoter as well. I also plan on cleaning with Dawn and then wiping down with 3M Plastic Prep
    10. #254
      May 2012
      Richmond, VA
      No problem. I just realized I've just passed the 5 year anniversary of having the R 2nd longest I've ever owned a car.
    11. #255
      Member ZZZZZZZ's Avatar
      Aug 2005
      Northern MD
      I do not, but I'm down that way fairly often each month for meetings.
      Quote Originally Posted by epicV70R View Post
      My initials - IPD - ZZZZZZZ's thread
      Now: 2007 vRgt, red & gobi - 2005 s60 2.5t AWD, silver & tan - 2002 xc70, silver & black
      Past: 1999 v70, tropic blue/green & oak and Mom started this in 1975 with a 1974 164e, maroon & maroon
    12. #256
      Aug 2005
      Northern MD
      Wow... really? I'm on my eighth in 35 years of driving, but the first three were Chevy, and lasted about a year to a year and a half each. Had the Toyota for 10+. Damn - did I just count 35 years?!?
    13. #257
      May 2012
      Richmond, VA
      I'm 38 and have had 26 cars. E34 525 I owned for 7 years, R for 5 and I had the e39 touring for 4 years. The rest of all been 2 or less. I owned a 16k mile original 71 datsun 510 for 30 days last year
      Cars in order from first to last purchase
      In order
      1953 Chevy truck
      1987 Nissan Maxima
      1987 Nissan Maxima
      1992 Nissan Maxima
      1967 Datsun 1600
      1987 Nissan Pathfinder
      1998 Lexus GS400
      1995 Nissan 240sx silvia swap
      1993 Nissan Pathfinder
      1994 Volvo 850 estate
      1969 Chevy C10
      1986 Nissan 720 truck
      1972 Datsun 510
      1992 BMW E34 525i
      2001 Nissan Xterra (step-daughters current)
      2004 Volvo V70R (current)
      1986 Toyota truck
      1999 BMW E39 528it
      2003 BMW M5
      2007 Mercedes AMG E63
      1995 Nissan d21 hardbody (current)
      1971 Datsun 510
      2001 BMW E38 740i (current)
      2003 BMW X5 (wife’s current)
      2001 Nissan Frontier
    14. #258
      I had an 86 Maxima and 2 92 Maxima SE's. I loved that platform and the motor in those cars is glorious.
    15. #259
      Mar 2010
      Hinsdale, IL
      If it were me with an '04 auto VR that still pulls family duty, I'd do a hybrid wheel, FMIC, 3" down pipe, 3" exhaust, tune removing torque limiting, then solid delrin subframe mounts front and rear, refresh all bushings with poly in the front LCA position, sways, and coilover sleeves over the 4C shocks (though if this doesn't work out I will dump 4C). I'd also refresh all fluids including ATF.
      In fact that is the basic plan for my '05 which is intended to be a fun family driver. I have not kept track lately but up to about 2-3 years ago no one had experienced AW55 failure due to removal of torque limiting, and most people say it transforms the car. Same comments regarding sway bars, though I can only go by comments as mine wait in the garage. YMMV. I'd like to fully sound insulate mine too, but I'm backed up enough as it is right now so who knows if I will ever get to it (or the hybrid wheel for that matter). Not after any specific power goal personally, just looking for the low hanging fruit without killing reliability.
      On my prior R (2007 S60R automatic) I had full poly LCA's, poly subframe inserts, TME springs with height sensors set to read right in the middle of the range at the new ride height, then SUM calibration with rear weighed down 1/2" lower (this took the edge off the harshness). Had a 3" downpipe but never got around tuning it before selling it. I liked the firmer TME's, but they were still too soft IMO hence my desire for coilover sleeves, so I can pick specific rates and play around with it. And based on how the subframe bushing inserts felt and improved things, I decided to go with delrin this time around, I just have to find some time to install the spare subframe I installed them in.
      2007 XC90 V8 - 2005 V70R M66
      2015 F150 Supercrew 2WD 3.5L
    16. #260
      May 2012
      Richmond, VA
      I appreciate the thorough advice!
    17. #261
      Mar 2010
      Hinsdale, IL
      No problem, but keep in mind much of that stuff I haven't actually done yet, just my plans. Don't follow the blind man...
      I actually forgot to mention one thing, I'd also look into a DIY 'shift kit' for the AW55; I'm not aware it ever being done on an R but I've seen guys with other cars replace the accumulator springs with an aluminum sleeve. This should quicken the shift and reduce the apply time of the clutch packs in the trans, should reduce heat & wear. I wish I tried this on the 5HP I rebuilt in my 7, but just the rebuild took long enough.
    18. #262
      May 2012
      Richmond, VA
      Understood. Interesting on the trans.
      I'm not sure I want to go poly or delrin on the bushings. In the past I have regretted that on other cars. But I know the R is a different animal altogether in regards to suspension.
    19. #263
      May 2012
      Richmond, VA
      In searching my parts cabinet, I found new OE rear bushings and front Powerflex purple bushings along with new OE ball joints for the front control arms. So I should probably save money and go buy a press for the garage instead of paying a shop or buying new complete arms.
      It also looks like the rear lower arms don't wear and instead there is a toe link with two bushings. I assume that's the one to replace. What about the upper arm with the bump stop?
    20. #264
      Mar 2010
      Hinsdale, IL
      You can do the front LCA bushings with a vise. I actually just clamped the center pin of the front bushing with the vise & turned the LCA until the pin tore out. If your bushings don't come with the metal sleeve you can scrape with a chisel then wire brush, or if they have sleeves just collapse them with a chisel and remove.
      ball joints are in the knuckles and come out/go back in pretty easy with an air hammer.
      While youre in there I'd recommend checking your tie rods and end links.
    21. #265
      May 2012
      Richmond, VA
      Thanks for the tips. Don't have an air hammer but should. I'll take a trip to Northern this weekend and might get a press anyway. Always wanted one. Did tie rods and end links not too long ago.
    22. #266
      May 2012
      Richmond, VA
      My front arm power flex bushings are just the bushings. Do I remove the front mount pin from the stock bushing and re-use it? If so, I may just get a complete bushing instead. I don't see the rear toe link with the two bushings on FCP so perhaps they just sell the bushings individually and you re-use the short aluminum housing? Also, when I replace the rear 4c's, is it wise to also replace the upper mounts? In photos, I can't see any rubber so seems silly to replace if just aluminum. But I would imagine there is a rubber mount and if so, I would absolutely replace while doing the shocks. I am basically looking to replace all the main wearable bushings/ball joints etc front and rear and want to order all parts tomorrow.
    23. #267
      Mar 2010
      Hinsdale, IL
      There are rubber spring seats, strut top bearings up there. I knew the spring seats were toast on my car, and I just went ahead and ordered the bearings too.
      Based on how long cars live with you this may not matter but FCP has a lifetime warranty, on everything.. I like to go with OE suppliers from them, and they package kits too. Heres one, I'm not recommonding ( nor not not recommending...) this one, just fyi and to link you to the site:
      https://www.fcpeuro.com/products/vol...FUM2gQodsZYPoA
      Btw, they have complete bushings, but reusing the pin and sleeve with what you have isn't a big deal if you will have a press, but of course your call.
    24. #268
      May 2012
      Richmond, VA
      Yeah, I order most of my parts from them since I have had so many BMW's. I did the entire front strut assembly and am ready to tackle the rear so I want to make sure I do all the "while in there" stuff.
    25. #269
      Mar 2010
      Hinsdale, IL
      Sorry, I'm a dufus, I read right over you stating your doing the rear.
      There is a spring seat that my OCD would force me to change if I was doing a refresh but I dont believe its problematic like the fronts (since the fronts hold the upper shock mount, the rears dont).
      Other than changing springs and tweaking the height sensors (by bending the rods) I haven't yet had the pleasure of redoing anything in the rear suspension, hopefully someone who has will chime in.
    26. #270
      May 2012
      Richmond, VA
      Hadn't read about bending the rods. Wish I wasn't blocked from this site at work. Too hard to research on the phone and I spend most of home time doing other stuff. Just happens to be raining today.. so much to learn now that I've decided to finally go a little nuts on the VR..
      The other auto projects that I work on. Wifeymobile is the 03 X5 4.6is and my usual DD is the 70k mile 95 Nissan D21 but I have an internal oil problem and it's been parked on my lift for a few months while I try and source parts for an engine rebuild. I have done an 87 Nissan pathfinder front end conversion, Bilstein HD shocks, light bar and modified to fit Toyota specific aftermarket wheels.
    27. #271
      Mar 2010
      Hinsdale, IL
      To be clear I only bent the rods so that the sensors would be in the middle of the range at the final ride height, determined using VIDA& a chinese knockoff DICE unit.
      You certainly have a knack for flipping cars. I thought I've had a lot; I'm 41 and have only had ~20, 22 counting the cars I bought Mrs 377Z, though when I add them up I seem to leave some out and past a certain point I'm not sure of the sequence as many tenures with me overlap.
      Since I cold turkeyed bimmerforums I lost track of your escapades too, last I remember you had a Toyota 4X and the green 510.
      PS I too hate searching on a phone, perhaps you could tether in via a tablet, at least over lunch or something. So much easier on a tablet.
    28. #272
      May 2012
      Richmond, VA
      Seems like the Elevate springs are pretty good for lowering the car a tad and not being harsh. Anyone with experience who can confirm?
    29. #273
      Aug 2005
      Northern MD
      That's a good looking Nissan (for a Nissan)! Didn't know there was a mod to do that face change. I guess if adam_nonnis can combine an R and an XC, Nissan pathfinders and pickups can be combined too. I've a bit of a hankering for a clean 'Yota like I had back in the day.
    30. #274
      May 2012
      Richmond, VA
      My old Yota.
    31. #275
      Aug 2005
      Northern MD
      I gotta go back and look at your list. 86?
      Super looking. Really gorgeous. When you're in D.C. (If ever), let's meet up.
      My old Yota.
    32. #276
      Aug 2005
      Northern MD
      Nailed it.
    33. #277
      May 2012
      Richmond, VA
      Bought a 20 ton press and cleaned the garage. Ready to tackle the front control arms.
    34. #278
      Aug 2005
      Northern MD
      I might need to drive to Richmond!
    35. #279
      May 2012
      Richmond, VA
      Haha
      I've been looking at Elevate tuning products on fcp. Leaning towards intake, downpipe, exhaust and tuning. Still undecided on springs but leaning towards Elevate on those as well. Any feedback?
    36. #280
      May 2012
      Richmond, VA
    37. Remove Advertisements
