Diagnosing A/C system, How do I test/bypass high pressure switch?
    Results 1 to 18 of 18
      Sep 2009
      Glenside, Pa.
      A/c system currently has no refridgerant in it. The system has a leak which is most likely the evaporator, but will put dye in and check for leaks before tearing everything apart. There is another issue however, jumping the low pressure cut off switch by the firewall should allow the compressor to run as if there is refridgerant in it, but it's not running when I jump the switch, leading me to believe that there is another issue. I checked the compressor and clutch, relays and fuses, and the ECC module, all are working properly. When I pull the connector off of the high pressure switch(located between the ECU box and rad support) then put it back on, the compressor kicks in for about 5 seconds and then shuts off, but doesn't kick on every time. I'm thinking that the HP switch is bad. There are three wires out of the connector, numbered 1,2,3. Does anyone know which pins to jump to temporarily bypass? Or how to test the HP switch?
      Vehicle is 2000 V70R
      2001 V70 XC, Black/Beige, 59,000 miles, Snaab intake, Hilton Stage 1 tune, Rear V70R sway, Chrome 18" Atlantis wheels, rear spoiler
      2000 V70R, Emerald(Olive) Green/Graphite, 143,000 miles, Sons wheels, 2002 2.4T, 19T, Greens, Delco TCV, Snaab intake pipe, VDO boost gauge
      1992 245 M47, Propus wheels
      Member burnout8488's Avatar
      Jun 2011
      Endwell, NY
      I have *never* heard of a failed HP switch, but that's not to say it isn't impossible. I think the issue may be that there is absolutely zero refrigerant in the system.
      Wish I could help, no clue what the pins do or why it's a 3 pin instead of a 2 pin like the LP switch.
      Want me to drop a spare HP switch in the mail for testing purposes if you can't figure it out? Pretty sure I have one laying around. (Known working)
      '13 BMW X1 35i M-Sport
      '99 S70 AWD - 15G - ARD Green
      Sep 2009
      Glenside, Pa.
      Quote Originally Posted by burnout8488 View Post
      Thanks, I may take you up on that if i can't figure how to temporarily bypass it. I do have the schematic for the system, and all three wires go into the ECU so I don't want to just start jumping wires for fear of burning up something. I may just take the switch off and try to figure out how it works.
      Edit: Actually, I'll check the switch pins first to see if there's continuity between any 2 of the three pins.
      Member b2fkb0's Avatar
      Oct 2010
      Kalamazoo, MI
      I'm in the same boat as you! I tried to jumper the low pressure cutoff switch with the same result (nothing, compressor clutch won't lock in). I found my two leaks, repaired them and added new refrigerant. The compressor began to cycle on/off and seemed to be in business. Next day I went to run it and had the same result. I bought a gauge set yesterday so I'll see what that shows me. Possibly the same evaporator issue (hopefully not!) as I haven't checked that yet...
      00 V70R Emerald, 98 v70R saffron, 98 v70r black, 04 v70xc nautic, , 06 xc90 v8 gunmetal, 83 242 Group A med blue metallic, 82 242 DL, 2006 s40 t5a, s40t5m awd RED, s40t5m awd Black, 04 s60r silver.
      Sold-98V70Rm silver, 93 245 silver, 98v70xc sandstone, 96 855r black totaled/parted, 96 855r white, 98 xc70 olive, 99 s70r, 05 s40 t5m (x2) silver, 94 854 na turquoise:
    7. #5
      Sep 2009
      Glenside, Pa.
      Quote Originally Posted by b2fkb0 View Post
      Could very well be your evap. I did put refridgerant in mine at one point and still no compressor kick in, so besides my leak, there is something else going on.
    8. #6
      Sep 2009
      Glenside, Pa.
      Checked the HP switch with an ohm meter today with no refridgerant in the system and the connector off. Here are the readings between the pins on the switch:
      Pin 1-2 = 1120 ohms
      Pin 2-3 = open
      Pin 1-3 = open
      None are grounded.
      I also checked the HP switch in my daughters 2000 S70 with a working, charged A/C system:
      Pin 1-2 = 14,600 ohms
      Pin 2-3 = 12,200 ohms
      Pin 1-3 = 8,500 ohms.
      None are grounded.
      Interesting that this switch is not designed just for on/off. I was surprised to see these ohm values, unless they were caused by corrosion in the switch.
      Burnout8488, do you have an ohm meter? If so, would it be possible for you to check the readings on the extra HP switch that you have? It would be much appreciated if you could do this for me!
    9. #7
      Jun 2011
      Endwell, NY
      Sure!
      Switch off the car:
      1-2: 17.7 ohms
      2-3: 17.7 ohms
      1-3: 23.5 ohms
      On my '99 S70 properly charged (by weight) with no leaks:
      1-2: 50.4 ohms
      2-3: open
      1-3: open
      Is there a chance one of us is using the wrong scale? (tens hundreds thousands?) It's odd though that the switch on your car mimics the open circuits that the switch on my car's *charged* system does. Maybe your switch is stuck in a high pressure state despite not being charged? But your daughter's car doesn't show any opens, which is confusing since mine does on the same car.
    10. #8
      why dont you just check the voltage? it should be 1V per 100 psi so about 1v with system off approx.
      i have had plenty of those fail.
      there is a bulletin about them from volvo.
    11. #9
      Sep 2009
      Glenside, Pa.
      Great! Thank you for taking the time to do this! I havn't used my ohm meter for a while but the symbol on the meter reads K- ohms, so if I put the switch on the "20", I'm assuming it will read up to 20,000 ohms, am I correct? I used this scale on my daughters car, and had readings of 14.6, 12.2, and 8.5, so 14,600, 12,200, 8,500 ? For the 2000 Vr, I used a 2000 ohm scale, which came out the same as direct @ 1,120. ohms. I'm more interested in your charged system showing similar readings as far as what's open as my non charged system. Maybe I'll check the HP switch in my wifes 2001 XC, although it is a P2, not P80. Still would like to figure out which wires in the connector to jump, although if the system uses resistance values, jumping the connector may not work.
    12. #10
      Sep 2009
      Glenside, Pa.
      Quote Originally Posted by garbergtsi View Post
      Thanks. Where would I check the voltage? And how about if there is no pressure in the system?
    13. #11
      jumping the connector wont work but i have done it with a old TPS and got it to work
      if there is no pressure it will be close to 0V. the P2 sensor is the same as well
    14. #12
      Sep 2009
      Glenside, Pa.
      So I keep the connector plugged in, and check for voltage on which wire? Car/ignition on?
    15. #13
      Jun 2011
      Endwell, NY
      For testing, you can always just borrow the switches off of your daughter's or wife's cars. There is a Schrader valve underneath them so the system won't discharge if you remove the switch.
      No idea on the ohm readings, I wasn't able to get a proper reading unless I used the "20" on my multimeter, which scales everything down so the number is actually readable. When I used the "2000," I just got abbreviated numbers since the scale was too high for the application. I think the resistances (at least on my meter and HP switch) are simply 17, not 1700. But yeah, the voltages will tell a different story. I'm no electrician though.
    16. #14
      Sep 2009
      Glenside, Pa.
      I found out that the HP switch is actually a sensor, hence the ohm readings and not just on/off. I'm going to try a few things first before revisiting the HP sensor, one being am I getting voltage at the LP switch. Also, I didn't realize that the system would stay sealed if I removed the sensors, that's good to know.
    17. #15
      so there are 3 wires, it works just like a TPS or any other sensor that alters resistance.... one wire has 5V, one wire is ground and the third is your signal. signal is 1v per 100 PSI of high side pressure.
      just take a DVOM and check the 3 wires....
    18. #16
      Sep 2009
      Glenside, Pa.
      Thanks, looked at the schematic and can see which wire is which.
    19. #17
      Sep 2009
      Glenside, Pa.
      Update, tested voltage going into and out of the sensors, all seems fine. Replaced the evap today and all is well, COLD air! It seems that the R-134 was leaking out so fast, that the sensors would not allow the compressor to kick on, even if I tried putting refridgerant in. I did need to jump the low pressure switch to help suck refridgerant in quicker after I replaced the evap.
    20. #18
      Jun 2011
      Endwell, NY
      Awesome! Perfect result.
    21. Remove Advertisements
