what is this?
    Welcome to SwedeSpeed
    You're currently browsing Swedespeed as a guest. Please sign up or sign in and take part in the conversation with other Volvo owners and enthusiasts. With more than 2 million posts our community is one of the most active groups of Volvo owners in the world. Take a moment to sign up and enjoy all of the features our forums have to offer.
    Results 1 to 7 of 7
    Thread: what is this?
      what is this?
      can't figure this one out. looked in manuals and couldn't find it.
      http://imgur.com/g4eQHaQ
    2. Advertisements
    3. #2
      Senior Member
      Aug 2004
      Temple, Texas, USA
      Quote Originally Posted by craig300 View Post
      B20 engine.
      Exhaust manifold.
      Intake manifold.
      Oil filter.
      Battery cable.
      Drain petcock for block coolant.
      Flywheel housing.
      Zip-Tie.
      Firewall for '71 1800E.
      Bracket/nut/retainer for water pipe coolant line.
      Water pipe coolant line (steel).
      Braided cable with brass fitting.
      Black 12g electrical wire.
      Blue shielded conduit for MegaSquirt system...
      and...
      Thermal timer - see pdf pages 9 and 10...
      http://volvo1800pictures.com/documen...lt_tracing.pdf
      George Dill
      thanks George. I guess I'll be more specific on my next post!
      this "restored " 1800 has a number of electrical issues. I'll be posting some more pics. seems the body shop that did the work wasn't the best at electrical. I suspect the previous owner made a number of electrical mods that weren't the best nor corrected on the restore.
      cheers.
    5. #4
      my first thought is that for some reason this wasnt connected at the restore. the Haynes manual I have discusses this part and it's connections, however when I tried to trace the connections, the cold start valve was already connected to the wiring harness. the 71 repair manual does not reference this part, nor show it in the fuel injection system, so I would assume that it's not OEM on a 71. this leads me to believe the motor is not original. I'll get the engine number this weekend and see if I can determine its pedigree.
    6. #5
      Moderator Phil Singher's Avatar
      Jul 2004
      Whidbey Island, WA
      Thermal timer was introduced in the '72 models.
    7. #6
      so should I just ignore it or try to hook it up? thx
    8. #7
      Jul 2004
      Whidbey Island, WA
      I'd ignore it except for maybe removing it.
    9. Advertisements
