OFFICIAL: XC90 Part Number & "How to" Thread
    Results 1 to 5 of 5
      Below is a collection of Part numbers to enhance your XC90. Continue to post frequently used part numbers in this thread.
      Thanks to itwontstopsnowin for posting the majority of these with his XC90 project. Here are some of the enhancements he applied to his XC90:
      *Front bumper bar
      *2013+ style LED tail lights
      *2013+ LED Front Running Lights (Replace fog lamps)
      *New style R design grille (R-Design emblem replaced with V8 emblem)
      *Executive crests
      *Ocean Race bumper inserts with chrome
      *Silver roof rail end caps
      *New style rear V O L V O emblem
      *Rubber Mats
      *Aluminum R-Design style Pedals
      *2013+ R-Design Steering Wheel
      *R-Design/Sport Blue Gauges
      *OEM Sirius Radio
      *OEM Premium Sound Amp and Speakers (Sounds amazing!)
      *RTI 2013 Map/Firmware upgrade with 3D maps
      *Wing Profile Cross Bars
      2016 XC90 Wheel Center Caps: ( install thread )
      31414934 - Silver
      31414935 - Tech Black
      R-Design 3-Spoke Sport Steering Wheel: ( install thread ) - Same Process as S80
      With RTI: 30756165
      Without RTI: 30756166
      Chrome Tail Lamp Trim ( install thread )
      Left Trim Piece: 30790284 - $39.23
      Right Trim Piece: 30790285 - $39.23
      2009 R-Design Dual Exhaust ( install thread)
      Note: This kit is designed spefically for facelift cars (2007-2015). It seems as though it would be possible to fit it to an earlier model if you changed over the entire rear bumper. You need to purchase the exhaust kit itself, as well as a replacement exhaust gasket (if you wish). You also need to purchase one of two mounting kits. They are different depending upon whether or not you have the OEM Volvo trailer hitch. If you have an aftermarket hitch, you must get the mounting kit for NO HITCH. This is something that I discovered. The OEM hitch has mounting provisions on it for the exhaust mounting kit, however my aftermarket hitch did not. I ended up simply welding the necessary bracket to the side of my aftermarket hitch, but if I had ordered the non-hitch kit, it would have been a bolt-on installation.
      Full Sport Exhaust Kit for Petrol V8 Models: 30756337 - $972.79 (Volvo Parts MSRP)
      Full Sport Exhaust Kit for Petrol 3.2 Models: 30756338 - $1060.72 (Volvo Parts MSRP) May no longer be available from Volvo.
      Full Sport Exhaust Kit for Diesel D5 Models: 30756339 - $972.79 (Volvo Parts MSRP)
      Installation Kit for Cars Without Hitch, or With Aftermarket Hitch: 30635847 - $28.62 (Volvo Parts MSRP)
      Installation Kit for Cars With OEM Hitch: 30756609 - $52.36 (Volvo Parts MSRP)
      Gasket (Between new exhaust system and converters): 8672278 - $3.32 (Volvo Parts MSRP)
      Nuts (To attach the new exhaust system to the converters): 985921 - $2.36 x2 (Volvo Parts MSRP)
      2013+ "Silk Metal" Roof Rail Footing Caps: ( install thread )
      This updates the look of the older style roof rails to look like the 2013+ XC90s.
      Left Front: 31333099 - $13.91
      Left Center: 31333101 - $11.25
      Left Rear: 31333103 - $13.91
      Right Front: 31333100 - $13.91
      Right Center: 31333102 - $11.25
      Right Rear: 31333104 - $13.91
      If you don't already have the aluminum roof rails, and would like to fit those in order to get this look on your older model XC90, the part numbers for the silver/aluminum roof rails are:
      Left: 31333095 - $281.25
      Right: 31333096 - $281.25
      Auxiliary Lighting Kit: ( install thread )
      Note: The XC90 kit does not appear to be available from Volvo. However, I used the V70/XC70/S60 kit, and it contained all the necessary parts, and everything fit and worked perfectly. There appears to be no discernible difference between the two kits.
      XC90 Kit: NO LONGER AVAILABLE
      V70/XC70/S60 Kit: 30772053 - $144.56 (From Tasca)
      Side Decor Kit: ( install thread )
      Note: Willow Green (along with a few other colors) are no longer available. The kits I've listed in Italics are the ones that have been discontinued by Volvo. They do sell a kit which is just primed that can be painted any color you choose.
      XC90-07- Primed - 30794160
      XC90-07- Black - 019 - 30794013
      XC90-07- Willow Green - 471 - 30794129
      XC90-07- Silver Metallic - 426 - 30794026
      XC90-07- Black Sapphire Metallic - 452 - 30794039
      XC90-07- Ruby Red Pearl Metallic - 454 - 30794057
      XC90-07- Titanium Gray Metallic - 455 - 30794066
      XC90-07- Oyster Gray Pearl - 472 - 31213192
      XC90-07- Shimmer Gold Pearl - 473 - 31213205
      XC90-07- Ember Black Pearl - 487 - 31213218
      XC90-07- Magic Blue Metallic - 467 - 30794102
      XC90-07- Lava Sand Metallic - 468 - 30794111
      XC90-07- Lunar Gold - 469 - 30794120
      XC90-07- Electric Silver - 477 - 30794138
      XC90-07- Shadow Blue - 480 - 30794151
      XC90-07- Ice White - 614 - 30794075
      XC90-07- Savile Gray - 492 - 31265740
      XC90-07- Caper Green - 493 - 31265741
      Primed Version - $2,110.34
      Prepainted Versions - $2,191.17
      The kit comes packaged in a giant box, and inside the box, each individual part is boxed up in a separate box with individual part numbers. This would indicate that the kit can be purchased part by part in case one of the parts is damaged, or improperly installed.
      2013+ LED Tailights: ( install thread )
      Recent Install Thread: http://forums.swedespeed.com/showthr...-Light-Upgrade
      31335506 - lower, driver's side - $298 retail
      30698141 - upper, driver's side - $152 retail
      31335507 - lower, passenger's side - $298 retail
      30698142 - upper, passenger's side - $152 retail
      A small resistor is needed, here is what one user did:
      2x 25W 30ohm resistor between black and white wire of the L and R Position light
      2x 50W 6ohm resistor between black and yellow wire of the L and R Brake light ( example )
      07 XC90 V8: Access the two wire yellow and black behind the rubber seal. I did not cut them but just peeled off the insulation in a very small area to expose the cooper wire on the yellow and black. then attached the resistor's two ends between the 2 exposed areas on the yellow and black and walla all works with NO error message (no brake or position light fault code). I also wanted to say that only adding the register on the driver side (ONE register) solved the error message problem. I did not have to do the passenger side at all.
      2013+ LED Fog/DRL lights:
      31323701
      31323702
      Mirror Covers:
      30756163 - Silk Metal Mirror Covers
      L - 39894340, R - 39894353 - Black Mirror Covers
      chris@swedespeed.com | instagram.com/swedespeed
      2013 C30 Polestar - #141/250 -
      Rebel Blue, 6MT, Climate, RearVision camera
      2016 XC90 R-Design T6 - Passion Red, air suspension, B&W, Vision, Convenience, Polestar
      2015.5 V60 T6 R-Design Platinum - Rebel Blue, snabb intake, do88 FMIC, KPAX exhaust, KW V3 coilovers
      Member oneofakind's Avatar
      Mar 2015
      West Yellowstone, MT
      Bumper Removal & Light Bar Installation; Door Panel Removal
      How-To: Light Bar Installation:
      http://forums.swedespeed.com/showthr...r-Installation
      How-To: Sport/R-Design Door Panel Removal:
      http://forums.swedespeed.com/showthr...-Panel-Removal
      2007 XC90 V8 Sport (R-Design), Passion Red, Large Iron Mark Grille, Satin Black Metallic Powder Coated Rims, 2013 Smoked Tail Lights, Lighted Upper Tail Lights, Chrome Executive Inlets, 32" Light Bar, Full Roof Rack w/ 36" Tri-Row Bar, 20" Light Bar, 4 7" Side Light Bars, 2 6" Back Up Light Bars, Full Sized Shovel, Full Sized Axe, Hi-Lift. S60R Brembo Brakes Front+Rear, 25mm Spacers, EBC Rotors+Pads.
      Apr 2015
      Pittsburgh, PA
      Volvo Manuals:
      http://volvo.custhelp.com/app/homeV3
      How-To's, Breakdowns, Information and Many Other XC90 Related PDF's:
      http://forums.swedespeed.com/showthr...90-Information
      High Mileage XC90 Buying Guide:
      http://forums.swedespeed.com/showthr...33#post4845833
      Mechanical Upgrade/Repair/Maintenance/Info
      Volvo XC90 - Reset “Time for Regular Maintenance” Message with VIDA/DiCE:
      http://www.timthurber.com/tims-volvo...-messagelight/
      Volvo XC90 - Reset “Time for Regular Maintenance” Message (2003-2007):
      1. Insert Key and Turn to Position I
      2. Press and Hold Odometer Button then Turn the Key to Position II
      3. Hold Odometer Button until Hazard Triangle in Center of Dash Flashes and then Release the Button Quickly
      4. The Message Should Now be Reset
      Note: I use the trip meter (T1) to track my mileage per tank. If you also do this, you should first insert and turn the key to POS I, click the odometer button once to move to T2, then turn the key off and remove it from the cylinder before following the above sequence. The process above resets which ever trip meter the car is in when you turn it on, so this protects the mileage in T1.
      Volvo XC90 - Sunroof Drain Repair (Water in Front Foot Wells):
      http://forums.swedespeed.com/showthr...f-drain-repair
      Volvo XC90 - Reset Automatic Window Function (Window Auto-Up Bumps Top and Goes Back Down):
      1. Open the fusebox cover on the driver’s side of the dash facing the door.
      2. Close the affected window. Make sure car is ON (position II) or running. Locate the fuse for the affected door module (either #5 or #6).
      3. Open the affected window, and while the window is moving down, remove the fuse for the door module.
      4. Wait a second and then insert the fuse.
      5. Close the affected window by holding the switch all the way up (as if you were using the auto-up function) and hold the switch in the auto-up position at least 5 seconds after the window closes.
      6. Test the auto-down and auto-up function – it should be working now! If it still does not work, you will need to use a scan tool that can scan the passenger or driver’s side door modules.
      Credit: https://andrewpeng.net/cars/2006-vol...indow-problems
      Volvo XC90 - Repair Intermittent Turn Signal:
      http://forums.swedespeed.com/showthr...Signal-Problem
      http://forums.swedespeed.com/showthr...-signal-repair
      Volvo XC90 - Clock Spring/Steering Angle Sensor Replacement:
      http://forums.swedespeed.com/showthr...Guide-w-photos
      Volvo XC90 - Rear Tailgate Handle Repair Guide:
      http://www.volvoforums.org.uk/showthread.php?t=108023
      Volvo XC90 & S80 V8 - Spark Plug Replacement:
      http://forums.swedespeed.com/showthr...ug-Replacement
      Volvo XC90 & S80 V8 - How-To: Serpentine Belt, Tensioner & Idler Pulleys Replacement:
      http://forums.swedespeed.com/showthr...ys-Replacement
      Volvo XC90 & S80 V8 - DIY Alternator Replacement:
      http://forums.swedespeed.com/showthr...the-alternator
      Volvo XC90 & S80 V8 - Valve Cover Gasket Replacement:
      http://forums.swedespeed.com/showthr...t-Replacement/
      Volvo XC90 V8 - Oil Change Procedure:
      http://volvoforums.com/forum/volvo-x...ocedure-22250/
      Volvo XC90 - Fuel Filter Replacement:
      Same process as on the S60R/V70R:
      http://forums.swedespeed.com/showthr...acement-how-to
      Volvo XC90 - Engine Air Filter Replacement (Non-V8):
      https://www.youtube.com/watch?v=kInoDM6U0dc
      Volvo XC90 V8 - Engine Air Filter Replacement:
      http://forums.swedespeed.com/showthr...er-Replacement
      Volvo XC90 - Cabin Air Filter Replacement:
      https://www.youtube.com/watch?v=_fBWYPsSP7c
      Volvo XC90 – Rear Brake Pad Replacement How-To:
      http://www.timthurber.com/volvo-xc90...d-replacement/
      Volvo XC90 – Parking Brake Pad Replacement and Adjustment:
      http://forums.swedespeed.com/showthr...=1#post1567436
      https://ledge.sparsholt.ac.uk/plugin...adjustment.pdf
      http://www.matthewsvolvosite.com/for...p?f=10&t=73074
      Volvo XC90 – "R" Brembo Brake Caliper Upgrade/Swap How-To:
      http://forums.swedespeed.com/showthr...ke-SWAP-HOW-TO
      Volvo XC90 – CCM Reset to Remedy HVAC Blend Door Noise (Hoot!):
      http://www.timthurber.com/tims-volvo...nd-door-noise/
      Volvo XC90 - VIDEO How-To: Brake Vacuum Pump Reseal:
      http://www.timthurber.com/tims-volvo...-pump-re-seal/
      Volvo XC90 - How To: Replace Front Wheel Hub Assembly:
      http://forums.swedespeed.com/showthr...l-hub-assembly
      Volvo XC90 - How To: Replace Rear Wheel Bearing Assembly:
      http://forums.swedespeed.com/showthr...ge-with-photos
      Volvo XC90 - Haldex AWD Pump Replacement / Oil Change Procedure:
      Volvo XC90 V8 - Angle Gear Oil Change Procedure:
      http://forums.swedespeed.com/showthr...=1#post3757929
      Volvo XC90 - 06-08 Transmission Valve Body Info (Shift Flares, Neutral Condition, Transmission Issues):
      http://forums.swedespeed.com/showthr...al-Number-Info
      Volvo XC90 - How To: XC90 6-Speed Transmission (TF-80SC) Fluid Flush:
      http://forums.swedespeed.com/showthr...on-fluid-flush
      Volvo XC90 - DIY Engine Mount Replacements:
      http://forums.swedespeed.com/showthr...-Engine-Mounts
      Aesthetic Upgrade/Repair/Maintenance/Info
      Volvo XC90 - Personal Car Settings Using VADIS/VIDA:
      http://forums.swedespeed.com/showthread.php?57409
      Settings Include:
      Functions for Unlocking (1 or 2 Stage Unlocking with FOB)
      Functions for Car Confirmation (Indicators Flashing When Locked/Unlocked)
      Function for Automatic Locking (Car Locks Automatically at 7 km/h)
      Function for Alarm Activation/Deactivation (Activate/Deactivate Car Alarm with Interior Lock Switches)
      Function for Seat Temperature (Low 28-35°C, Med 32-38°C, High 36-43°C Seat Heat Setting)
      Volvo XC90 - Aftermarket Double DIN Head Unit Installation:
      http://forums.swedespeed.com/showthr...=1#post2988505
      Volvo XC90 - R-Design/Sport (Blue) Gauges Retrofit:
      http://forums.swedespeed.com/showthr...tro-Fit-Gauges
      Volvo XC90 - Driver's Seat Side Panel Replacement:
      http://forums.swedespeed.com/showthr...el-XC90-Repair
      Volvo XC90 - Broken Center Console Hinge (with RSE):
      30635628 for chassis up to 372596 (~2003-2006) - $241.25
      30790274 for chassis 372597 and up (~2007+) - $83.52
      2007-2014 Volvo XC90 Center Console Lid Bottom - RSE/DVD - http://store.voluparts.com/07-up-vol...le-lid-bottom/
      Volvo XC90 - Taxi Door Washer (Make Rear Doors Open Wider):
      http://forums.swedespeed.com/showthr...rs-open-wider)
      Volvo XC90 - Front Bumper Bar Upgrade: (From Sport & R-Design)
      30763522 - $388.96
      Volvo XC90 – Disabling DRL with CEM Programming:
      http://forums.swedespeed.com/showthr...CE-screenshots
      http://www.timthurber.com/tims-volvo...m-programming/
      Volvo XC90 - 07+ Bi-Xenon Conversion Instructions:
      http://forums.swedespeed.com/showthr...n-Instructions
      Volvo XC90 - Custom LED DRL's & Upper Taillight Modification:
      http://forums.swedespeed.com/showthr...=1#post2190154
      Volvo XC90 - How to Fix Cloudy Chrome Window Trim:
      http://forums.swedespeed.com/showthr...me-window-trim
      Volvo XC90 - R-Design Fender Flare Retrofit:
      http://forums.swedespeed.com/showthr...lares-retrofit
      Volvo XC90 - Replace Executive C-Pillar Covers with Black C-Pillar Covers and Executive Emblem:
      30796197 / 8663890 Applique Black - Exterior Door Rear
      30796198 / 8663891 Applique Black - Exterior Door Rear
      30790487 / 8694807 XC90 Emblem - Exterior Door Rear
      Volvo XC90 R-Design/Dual Exhaust - OE Hitch Install (Minimum Cutting):
      http://forums.swedespeed.com/showthr...haust-R-Design
      2004 Volvo V70R MT TiGray/Nordkap - Replica 18" Pegs - Handbrake Mod
      2006 Volvo S60R GT TiGray/Gobi - '06-'07 Transmission Valve Body Info
      2007 Volvo XC90 V8 Sport Passion Red/Off-Black - Serpentine Belt, Tensioner & Idler Pulleys - Spark Plug Replacement
      VIDA/DICE Owner - SS Lurker Since 2009
      Member ggleavitt's Avatar
      Jun 2005
      Seattle
      Until someone takes it down or changes direct access- http://www.volvoxc.com/0/resources/how-to/pdf/
      2005 XC90 B5254T2 175k
      2008 XC90 B8444S Sport 110k
      Member AMDG's Avatar
      Aug 2004
      NORCAL
      HOW TO REPLACE INTERIOR TRIM PIECES
      http://ftp.clubvolvo.ru/CARS%20DOCS%...8648663_en.pdf
      2005 V70R~Silver~Nordkap~iPd Track Spec Sways~CJ Adj Toe Bars~TME Springs~Race S60R DP and FMIC~TME Exhaust~VST Monoblocks~Black E-Codes
      2008 XC90~Silver~Graphite~4.4~19" HEICO's~Factory Dual Exhaust
    8. Remove Advertisements
