What did you do with your XC90 today? - Page 21
    Page 21 of 22 FirstFirst ... 11 17 18 19 20 21 22 LastLast
    Results 701 to 735 of 744
    1. #701
      Junior Member V50R's Avatar
      Nov 2014
      Rochester Hills MI
      Point taken
      2006 V50 T5 AWD AW55, 320mm FR Brake upgrade, Elevate Intake, OBX Exhaust.
      2010 XC90 V8 Executive Latest Addition.
      2008 XC90 V8 Executive Edition, w/Muffler Delete.
      2005 XC90 V8 Black, VB replaced, S60R Brake Swaped
      2013 Jetta Sportwagen TDI 6spd. Malone S2 tuned 200hp/350tq.
      Well talking about wildlife. Skippy decided to kamakazi the '90 on the way to work today. Came like a bouncing cruise missile from the bush into the side of my car......
      Took out the drivers mirror (right side?) and left a small dent under the door handle. He also got a shave from the rear wheel guard leave a good chunk of fur on the arch.!
      Not sure how smart the wildlife is on your side of the pond but these Kangaroos are some of the dumbest going around.
      Mind you I'm impressed with how well the body work held up. These things can weigh as much as a deer and if it wasn't for the fact the paint was cracked around the small dent I wouldn't? be so fussed about it. (Apart from the destroyed mirror of course)
    4. #703
      I'd leave a photo but it's saying I don't have permission...
      Global Moderator R-Pow3R3d's Avatar
      Apr 2015
      Pittsburgh, PA
      Quote Originally Posted by Kyril View Post
      You've got to host them externally and refer to their URL in the forum.
      http://forums.swedespeed.com/showthr...es-in-a-thread
      2004 Volvo V70R MT TiGray/Nordkap - Replica 18" Pegs - Handbrake Mod
      2006 Volvo S60R GT TiGray/Gobi - '06-'07 Transmission Valve Body Info
      2007 Volvo XC90 V8 Sport Passion Red/Off-Black - Serpentine Belt, Tensioner & Idler Pulleys - Spark Plug Replacement
      VIDA/DICE Owner - SS Lurker Since 2009
    7. #705
      Member oneofakind's Avatar
      Mar 2015
      West Yellowstone, MT
      It's not just the deer over here. Last year I had a grizzly bear nearly peg my left side going full speed, I'm pretty sure I brushed it's nose.
      Sent from my SM-N920V using Tapatalk
      2007 XC90 V8 Sport (R-Design), Passion Red, Large Iron Mark Grille, Satin Black Metallic Powder Coated Rims, 2013 Smoked Tail Lights, Lighted Upper Tail Lights, Chrome Executive Inlets, 32" Light Bar, Full Roof Rack w/ 36" Tri-Row Bar, 20" Light Bar, 4 7" Side Light Bars, 2 6" Back Up Light Bars, Full Sized Shovel, Full Sized Axe, Hi-Lift. S60R Brembo Brakes Front+Rear, 25mm Spacers, EBC Rotors+Pads.
    8. #706
      Mar 2017
      Marquette, Michigan
      Quote Originally Posted by V50R View Post
      I installed the Volvo OEM AUX Light Kit. Wanted to try it out so I hooked up some old LED work lights I had to see how it will look. Next up I'm getting 9" dual LED spot lights with 225w combined output. 45w per light 3w LEDs should put out around 10k lumens per side.
      That kit is pretty neat especially with the integrated switch. It remembers the position so every time you pull the high beam it turns them on. They can also be disabled if the switch is turned off while the lights are on.
      Here are some pics. Install took about 30min.
      Where did you get that Volvo license plate holder kit for holding lights? Would it work for a 2005 XC70 and what is the part #? Thank you
    9. #707
      Apr 2015
      Pittsburgh, PA
      Quote Originally Posted by seantcbike View Post
      Gotta check out the sticky!
      http://forums.swedespeed.com/showthr...to-quot-Thread
      Here's the part #:
      30772053
      (It's actually the kit for the XC70, so yes, it will work)
      Here's the install thread:
      http://forums.swedespeed.com/showthr...rt-Numbers-Etc
    10. #708
      Nov 2014
      Rochester Hills MI
      Yes the kit still exists at the local dealers, mine took 1 day to get delivered to the dealer. Cost me 143$ out the door with tax and everything.
    11. #709
      Junior Member brettborders's Avatar
      Aug 2007
      Denver, Colorado
      installed some ebay halo rings in my headlamps....and LED low beam conversion..
      2006 S60R, ELECTACAMA original owner, 6 SPD AUTO, BODYKIT, FULL SUSPENSION, JZW TUNE, 20G..B5244T5, EXHAUST DUMP
      2006 XC90 5 pot project...NOW HAS B5244T5/16T, SOON K24...OR CAVALLI...
    12. #710
      Apr 2015
      Pittsburgh, PA
      Those look pretty sharp!
    13. #711
      Nov 2014
      Rochester Hills MI
      How hard is it to open the lights? Sealed with BYTIL rubber id imagine?
    14. #712
      Mar 2015
      Bake in an oven at 250 degrees for an hour to 2 hours, then pry super gently with a flathead screwdriver.
    15. #713
      Aug 2007
      Denver, Colorado
      They are new aftermarket ones and I just used a heat gun to get them apart..
    16. #714
      Aug 2015
      Bellevue, WA
      I baked by XC60 headlights for 10-20 minutes at a time at 220 degrees and got some scorching in one small spot on the interior chromed plastic. I would definitely not recommend 250* for 2hrs!!!
      2014 XC60 T6 - P* Tune, DO88 FMIC, Ferrita DP, TSW Bathurst w/ Conti DWS06, R-Design Suspension, IPD Rear Sway, Custom Exhaust, Morimoto D2S 4.0 HID Projectors, Skeletonized Airbox, Powerflex Bushings, Colder NGK Plugs
      2007 XC90 V8 Sport - IPD Sways/Subframe Inserts/Strut Bar Conversion, Stoptech Rotors
      For Sale: CHEAP! 2007 XC90 V8 Sport Sway Bars / XC60 T6 parts as replaced above
    17. #715
      Nov 2014
      Rochester Hills MI
      Quote Originally Posted by NorthwestMoose View Post
      I am used to doing 180F by about 5min and that has always worked for me. The higher temps just scare me!
    18. #716
      Member Oceans60R's Avatar
      May 2008
      Charlotte, NC
      Quote Originally Posted by brettborders View Post
      What halo rings did you use?
      Btw, they look fantastic.
      2006 S60 T5 Mystic Silver/Off Black Sport, Factory Body Kit, 18" BBS's, Hilton Stage 2.5, 11 Blade, IPD Intercooler, Green Injectors, OBX 3" DP, Elevate 3" Exhaust, IPD Sways, H&R Springs, R Gauges, Burnouts @45mph
      2008 V8 Sport Passion/Off Black Thai Leather
    19. #717
      Mar 2015
      Good to know! The Ford headlights I did would not come apart, that's why I said 1-2 hours. Really good to know it won't take nearly as long for the XC90!
    20. #718
      Aug 2007
      Denver, Colorado
    21. #719
      Aug 2007
      Denver, Colorado
      My son and I also lowered the front skid plate on them too...
    22. #720
      Mar 2015
      Looking good! It's cool to see you and your son tinkering with basically the same car and what your styles are! Question though, when you resealed the headlights, did you reuse the factory gunk or scrape it off and use new stuff? If so, what brand?
    23. #721
      Xwelder, could you share the wheel size details (front and rear, width, offset), I was looking at those exact TSW wheels, and wanted to go wider than stock and at 20", something like your rear size on all 4 corners. Do you know if the rears will fit on the fronts, did you every try? Im guessing they might be close to the front strut both above the tire and to the inside of the sidewall/upper shoulder, but with the right offset, they shoulder work, just don't want the tires sticking out past the flares, but there is plenty of room.
      They look great on the white, I would be doing on silver.
      Quote Originally Posted by Xwelder View Post
      I have Pirelli Scorpions in 245/50R20 front and 275/45R20 rear.
      Should not be enough of a difference to adversely affect the system, especially when you consider manufacturing tolerance variations. If I had used the same tire and stretched it over the rear rims, I'd have more of a difference as that would have decreased the effective OD due to the angle of the sidewall. It took some time to find the tire sizes that would work for this set up.
    24. #722
      oneofakind,
      from this pic, it looks like even though you are running the stock wheels, that they are sitting out a bit further out, are you running spacers, or is it that the tires are just wider (can you share your size)?
      Looks really good, a wider stance, but maybe its just deceiving from the picture.
      Quote Originally Posted by oneofakind View Post
      Had some fun testing out my dad's new toy! Brand new 20', 14k pound, tilt bed trailer. Just driving the car on and off, but it was pretty neat!
    25. #723
      Sep 2010
      Edmonds,WA
      The links are a dead end now, and what does lowering the skid plate do?
      2007 XC90 3.2 AWD
      2006 XC70 Ocean Race
    26. #724
      Member ggleavitt's Avatar
      Jun 2005
      Seattle
      Bought the Dueler H/L Alenza tires and Neptune wheels noted in an earlier post for my '05. Super nice guy who sold them, tires have 75% plus tread and wheels have but a few curb rashes. I'll take them in for a balance check, swap them out a little later in the year on the current set (also Dueler H/L Alenza, 2 years old), and get my old wheels mounted with dedicated snows on them in time for winter.
      Any suggestions for reasonable cost good longevity 235/65 R17 dedicated snows?
      2005 XC90 B5254T2 175k
      2008 XC90 B8444S Sport 110k
    27. #725
      Sep 2010
      Edmonds,WA
      Quote Originally Posted by ggleavitt View Post
      We don't need snow tires here in Seattle!
      2007 XC90 3.2 AWD
    28. #726
      Mar 2015
      Quote Originally Posted by wa_xc90 View Post
      Just looks. It might increase airflow, but I'm not sure.
    29. #727
      Mar 2015
      Quote Originally Posted by Corvetteboy6988 View Post
      oneofakind,
      Hey sorry about that, it didn't notify me and I totally missed your post! They're the stock Vulcanis rim with a spacer. I changed my brakes over to the S60R brembo ones, so without a spacer they wouldn't fit. It's a 25mm spacer I ordered from ebay. They're quite nice, but you need to either grind down your stock wheel lugs or buy shorter headed ones. Otherwise the lugs leave a small gap between the rim and spacer.
      For tire size, currently my winters are 255/50R19, and my summers are 245/55R19. The only reason my summers are different is because I wanted a taller tire to fill the whole wheel well, and any other widths were special order and $80-120 in freight.
      Winter and summer comparison. Ignore the snow with my summer tires😑
    30. #728
      Apr 2015
      Pittsburgh, PA
      Well, not "today" per se, but the 90 is at The Swede Shop in Hadley, PA getting new struts, spring seats, strut bearings, bump stops and bellows. If you, too, would like to forgo the foolishness of Bobby Rahal Volvo in Pittsburgh (that's a story for another day), let me know and I'll put you in contact with a Volvo master tech who can help.
    31. #729
      Junior Member robtr8's Avatar
      Jan 2009
      Nellyville
      Time for new summer tires for the Ronal RT's. Went with Verde summer's. They are N0 and the Macan owners seem happy with them.
      2006 XC90 V8, AVH-4000NEX, PDX-F4 & M12, L1v2, GZUF60SQ, GB12D4, PWK designed box, custom exhaust, Scorpion Verde summer/Ronal RT's, IPD bars.
      2008 328xi, AVH-X7800BT, GM-D8604 & D9605, MT-230, GB40, XE 200, Primo 12", Musicar NW box, Sottozero 3/185's, S-04/Ventoso's.
      2011 XC60 T6 RD, DWS 06, 1980 TR8​, NT05
    32. #730
      May 2008
      Charlotte, NC
      Gave the brake calipers a little freshening up.
    33. #731
      Jan 2009
      Nellyville
      Been chasing a rattle in the passenger door forever. Most of it is in the outside door handle but there were other bits that buzzed a bit too. Thought I had it tamed with an MLV layer I built myself from shower pan and open cell foam but then I discovered a fantastic song that I just had to turn up. Really found the sweet spot for resonating anything not 100% tight.
      https://youtu.be/Zu8B4UeR4Pk
      Second Skin had some B stock Luxury Liner Pro at a huge discount so I figured I'd give it a try. Popped the door card off (for like the 1000'th time), drilled out the rivets and installed 5mm Nutserts.
      I wanted to remove the capacitor bucket and the midrange driver from the bracket so I could just cut a circle in the new MLV, discovered they are only screwed on so that was easy.
      Installed industrial strength outdoor velcro, trimmed and hung the sheet of MLV on the door. Stuff is heavy!
      Put the door card back on. Killed 90% of the rattles trying to get inside.
    34. #732
      Aug 2012
      Edmonton, AB, Canada
      I fixed the leak in my power steering system.
      I couldn't find it until i bought some multipurpose dye oil and a UV flashlight. Turns out it was leaking out the back side of the pump's return hose, so it was impossible to observe without the dye.
      Turns out you can't get the O-ring from volvo because it is, to them, a part of the power steering pump. You have to take off the plastic engine covers and the serpentine belt cover to access the connection. There is a metal elbow that bolts onto the pump with a single bolt.
      I drained the PS reservoir by unclipping it from the coolant reservoir and disconnected the return hose at the reservoir. After removing the elbow and cleaning everything I used a new regular O-ring and put "right stuff" (from permatex) around the flange and replaced it.
      No more leak!
      Through the winter I had been using ordinary PS fluid to top it up. I now flushed the bad fluid by chasing it with the proper CHF compatible fluid. That made a huge difference. Steering is much quieter and lighter than before.
      2006 XC90 V8
    35. #733
      Junior Member jeffwynkoop's Avatar
      Mar 2016
      San Luis Obispo. CA
      I vinyl wrapped the cupholder cover, gear shift surround, and glove box trim in simulation brushed aluminum. It looks alright but kinda tacky because I still have my wood steering wheel and wood gear shift. I think the combination would look better if I had the off-black interior as the bright silver will stand out against the dark leather, but that's not my case... I'll give it a few weeks and see if the silver/tan combo grows on me.
      2008 XC90 V8 Exec - Ice White - Soft Beige leather - 121K
    36. #734
      i have 20x8.5, et40 front an 20x10 et40 rear. the front is close to the strut, but i think a 10" wide could fit. i wanted the staggered look, so i never checked if a 10"
      would work.
    37. #735
      Nov 2014
      Rochester Hills MI
      I got a cheap set of OEM wheels for snow tire set up!
      Paid 150$ for a set of 4 OEM 6spoke 18x7.5 wheels.
      4 OEM sensors 45$
      And 4 Nokian Norseman 5 tires for 200$
      All and all total 400$ which is not bad for OEM set up.
    38. Remove Advertisements
