adam's rotors inc. running 10 years strong! | WE are officially HERE!!!
    Page 1 of 2 1 2 LastLast
    Results 1 to 35 of 52
      A FULL DECADE OF AR AND WE’VE MADE IT TO THE BIG SHOW!
      adam's rotors inc. is now the official BRAKE FORUM SPONSOR of Swedespeed!!!
      many of you may know us and are currently running our rotors, but if not, we just wanted to reach out and introduce ourselves.
      WE CATER TO THE CAR ENTHUSIAST WHO NOT ONLY NEEDS NEW BRAKE ROTORS, BUT WANTS SOMETHING DIFFERENT BEHIND A NICE SET OF WHEELS.
      be it looks or performance, adam's rotors is the only company to bring you over 17+ machine pattern variations (most of which are exclusive to AR), 3 zinc finish offerings, and 5 ceramic-silica hub coating options.
      YOU PICK, WHAT YOU WANT AT AN ALL-INCLUSIVE PRICE | COMPLIMENTARY CORROSION PREVENTION, FREE SHIPPING, CUSTOM DRILLING, SLOTTING, AND/OR DIMPLING, ALL LOADED INTO OUR WEBSTORE.
      we started out small and remain that way...a tight knit, self-owned & operated company established in 2006.
      the small outfit and one-on-one interaction creates only the best service w/quick response & even faster made-to-order set-ups. with top notch products, this lends hand to our success thus far.
      working 24/7 throughout the day, any and all questions are answered within the hour to the best of our ability, if not instantly.
      being an online company we do business direct via email, instant message, PM, and over the web in our ever growing threads...we're always here ready to reply!
      we are a fully made-to-order, replacement disc brake, rotor manufacturer...we offer only factory fit, OE spec, plug n' play discs.
      adam's rotors started out on Audizine.com and took over the VW/Audi market.
      over the years thru word-of-mouth and hard work, the Volvo community really latched onto your business model and supported our concept.
      our quality product & myriad of options pairs perfectly with the OEM brake components on Volvo cars, but keep in mind we also do set-ups for ANY make/models car/truck/van…check to our store!
      WWW.ADAMSROTORS.COM
      WHY ADAM’S ROTORS? WE’RE DIFFERENT!
      because we do what no one else does. AR is a customizable product, having managed to turn a boring replacement product into something different. it's a have-it-your-way, made-to-order modification item ideal for any enthusiast. now, instead of just picking 1 of 1-3 drilled or slotted rotor styles from off-the-shelf inventory, we offer over 17+ patterns for your choice/taste, how YOU want them. after that pick a zinc for corrosion prevention...silver? gold? maybe black? thereafter you can even add one of our coated hub colors in a satin ceramic finish to finalize your set and truly give them polished, unique look. we now even offer upgraded metallurgy, to a stronger premium grade high carbon iron if you so wish. we at AR believe a rotor ISN'T just a plain ol' service part...rather a fun, custom, cool way to not only enhance the look of your car, but add performance, protection, and something different to your build, with a ton of bang for your buck!
      oh yeh...and they actually perform!!!
      track tested, endurance race team approved; check it out HERE.
      WWW.ADAMSROTORS.COM
      AR drift I [triple curve] &
      AR drift II [triple curve/slot]:
      [must be ordered with coated hubs]
      AR drag I [cross-hatch/slot] &
      AR drag II [cross-hatch/double slot]:
      AR speed [multi-slot] & AR track [double slot/dimple]:
      coated hubs]
      AR sport I [over-dimple] &
      AR sport II [over-slot]:
      coated hubs]
      AR race [double slot] &
      AR street [double slot/drill]:
      coated hubs]
      adam | adam's rotors inc. | info@adamsrotors.com | est. 2006
      customizable factory-fit brake rotors, made-to-order | adamsrotors.com
      follow/like/@/tag @adamsrotors on twitter, instagram, & facebook | #adamsrotors
      Junior Member A4Avant's Avatar
      Sep 2010
      NY 10925
      I have your Rotors on both my Audi's and plan to run a set of 330mm R rotors. I have the calipers just no rotors or pads yet.
      Sent from my SM-G900V using Tapatalk
      2002 V70 T5 .....looking for Gobi R seats (F), H&R Lowering Springs
      2003 BTA4Avant
      ..... Built Motor, Comp Turbo CT5147
      IG: avantneil
      do you follow us on social media | @adamsrotors | #adamsrotors
      click each for direct links to our profiles!
    7. #5
      Member
      Aug 2015
      Hudson Valley, NY
      Coming up on pads and rotors for the XC soon. Curious to hear more feedback from anyone running these on our P2 wagons
      2004 XC70 2.5T AWD | 149K | Bad Swede 52mm Lift Kit | Sparco Terras BFG KO2s in 225/70r16 | IPD Strut Brace Conversion | IPD Skid Plate | IPD DEM Cover | AEM Dryflow Air Intake 2015 V60 R-Design | Sapphire Black Metallic | 44K | KPAX GT Performance Exhaust | IPD Rear Sway Bar | Powerflex Race Torque Mount Inserts
    8. #6
      we've done a ton.
      we do a lot of wagons of similar size and weight as well and our double slotting really excels under those loads...
    9. #7
      a solid April has passed with some California showers...bring the May flowers. (and good driving weather)
    10. #8
      we have a limited run of restock on the way in, to replenish our currently SOLD OUT coaster sets!
      these were a huge hit over the holidays/new year. be sure to get your set while you can & support AR!
      these are top quality custom generated, laser cut & etched, wood coasters; designed exactly to spec of 6 of our exclusive patterns. the lug holes & hub bores are cut thru, along with accurate slotting, dimpling, drilling, and AR's chamfered edges. they are sturdy, absorbent, 3/16" thick coasters, in 3.9" diameter Basswood. these are solid wood, not laminated, which can handle water/moisture making them great, usable drink holders. the set of 6 coasters come in a tin w/unique label design and NEW display plate. stack the set upright on the lid piece to showcase the coasters on your desk or coffee table.
      SHOP NOW: www.adamsrotors.com/MERCH
      the 6 patterns included are:
      AR sport I, AR sport II, AR speed, AR drift II, AR drag II, & AR street/track
    11. #9
      I actually need to replace my front and rear rotors very soon and was just reading about you guys. What rotors would you suggest for an N/A V70?
    12. #10
      ^ slotting dissipates heat, helps avoid glazing, and adds bite...
      drilling/dimpling do nothing but look good with new-age pads, as they no longer create the gasses they were once used to help disperse.
      thus, we've focused most of our exclusive patterns around slotting (our double slotting specifically, which we're known for, was designed & tested in many track & endurance race scenarios) to not only keep your brakes cooler when put to the test, but look good with unique, customizable ways of implementing them on factory spec rotors.
      with that said, for a daily driven street car, it really makes no difference when the car isn’t seeing hot brakes & aggressive stopping.
      in this case I always say to pick your favorite; after all, our concept is to have the customer choosing what they like for they’re own custom rotor.
    13. #11
      I am curious if you have done any testing on stopping distance of your rotors vs stock or Brembo??
      Quote Originally Posted by adam's rotors View Post
    14. #12
      no, but a couples things regarding that...
      brand is irrelevant. no ones offers our exclusive patterns. Brembo is a drilled rotor company... slotting dissipates heat, helps avoid glazing, and adds bite...**
      drilling/dimpling do nothing but look good with new-age pads, as they no longer create the gasses they were once used to help disperse.**
      thus, we've focused most of our exclusive patterns around slotting (our double slotting specifically, which we're known for, was designed & tested in many track & endurance race scenarios) to not only keep your brakes cooler when put to the test, but look good with unique, customizable ways of implementing them on factory spec rotors.*so really, it's apples to oranges.
      and stopping distance isn't a thing for comparison. that's much more pad related, all things being equal. rotors are more for endurance and avoiding high temps when pushed to the limits. again it's an attempt avoiding brake fade and warping prevention, in those situations.
    15. #13
      Sep 2010
      NY 10925
      Yes been following you guys for yrs over on Audizine, IG, and FB
      2003 BTA4Avant
      IG: avantneil
    16. #14
      thanks for the support!
    17. #15
      AR pattern-match program | serving BBK owners w/rear rotor solutions | www.adamsrotors.com/PMP
      here's a set of Alcon/Stassis C-hook rears we did for a customer with a Big Brake Kit up front, who's been forced to run un-matched rears in the past...not with a custom F&R set-up!
    18. #16
    19. #17
      over the years, we've collected 90% of the questions most commonly asked and covered them in our very informative info/FAQ section on the website...have a look!
      www.adamsrotors.com/info
    20. #18
    21. #19
      summer is here and it's HOT in California...this looks nice right now!
    22. #20
      Member
      Aug 2015
      Hudson Valley, NY
      Rad shot
    23. #21
      ^ yeh, our customers take some great ones...
      we collect them all by pattern in our customer galleries and highlight many on our facebok page and use best of the best on IG.
      post yours online with @/#adamsrotors!
    24. #22
      would you like to see what other AR customer customer pick/run on their cars?
      we have an ongoing collection, broken down by pattern in the customer gallery of our website, HERE.
      if you are a fan of Facebook, we also have a very active daily wall feed of the like, to help inspire your future order!
    25. #23
    26. #24
      Sep 2010
      NY 10925
      I want a set for both of my wagoons. 345mm for the Audi Avant and 330mm for the R calipers on the V70T5.
      2003 BTA4Avant
      IG: avantneil
    27. #25
      great! shoot us an email if ready: sales@adamsrotors.com
    28. #26
      Sep 2010
      NY 10925
      great! shoot us an email when ready!
      @avantoberfest is coming up and bring both cars with us! they will looking good in next few months.
      2003 BTA4Avant
      IG: avantneil
    29. #27
      volume up!!!
      this is a trailer for an upcoming short film on the '59 we shot over 3 days with Layer Media.
      huge thanks to Sean...he helped with our #Audilove S4 feature and shot the pontiac video as well.
      www.layermedia.com
      www.adamsrotors.com
    30. #28
      opening up your AR shipment is like Christmas no matter what time of year...
      sport II's:
    31. #29
      fall is here and it's cooling off...the rain has started and soon the winter months will be upon us.
      be prepared to weather the storm both on the road and inside & under your car with moisture, road grime, and rust.
      every set of AR leaves the shop silver zinc dipped, at no charge. it's a great way to help prevent corrosion & keep your rotors protected thru the ugly months...gold & black options too.
      we also offer a premium high-carbon metallurgy upgrade w/natural corrosion prevention properties in the iron along with a superior hub & vent coating!
      you can still look good & stop better w/adam's rotors:
    32. #30
      what a month that was...here's to the last one of 2016!!!
      Christmas presents that come in 4...you can't go wrong!
    33. #31
      Member wagonfan00's Avatar
      Jan 2015
      Long Island
      You mention that you haven't compared your rotors to Brembo or any other competitor. Then claim that they stop better all in this thread. Before I commit to something I'd like to see proof in stopping distance over one stop then also when the rotors are heated. It may be my daily but as soon as the roads start twisting it gets thrown around. I understand the science you are using for the slotted versus drilled rotors. Other companies do make slotted rotors as well and I like the idea you guys have behind the company and how adaptable you are and just want to see the difference.
      Current: 2002 V70 Base N/A M56 161k (Straight pipe, short shift kit) 1988 745T AW-71L 249k (BC coilovers, Hydras, eBay MBC @13psi, 2.5" Catless exhaust **for sale**)
      Past: 2008 Mini Cooper S Clubman R55 Getrag 6 Speed (Stock) 1997 855 T5 Auto 300k
      IG: psychocross_v70
    34. #32
      what do you mean compare?
      noone does what we do...we're literally the only branded company in the world with this business model.
      a rotor is a rotor...a cast iron disc. so long as you are using a quality blank, there is only so much variation; but the patterns in which you choose to machine into them is the difference...and how its done, etc.
      we are using the same exact core blanks as any competitor really...the difference being the hands on approach to cutting them in-house, to order...then the other options with zincs, coatings, upgraded metallurgy, and more so our small business customer service.
      but w/that approach to made-to-order, here all machining, dipping, coating, and packaging is done in-house at AR. first, we chamfers each drill hole which adds a beveled edge to each thru hole. secondly we pay extreme attention to how the pattern is laid down when machining. taking meticulous measures to avoid each and every vent rib which are the internal cooling veins (on vented discs) in these rotors, avoids any issue with cracking. AR will not drill a rotor we are unable to do so with and thus cracking is never a concern. this is another reason why unlike many, we also offer dimples and unique slot patterns, ways of avoiding this and offering better, longer lasting, quality products. AR also backs them by a 1 year exchange warranty per rotor on manuf. defects.
    35. #33
      Jan 2015
      Long Island
      Beautiful. I'm waiting on a sale of one of my cars then I'll be asking for some rotors. Passion and knowledge is there of your product and your industry. Things I like to see over the larger companies.
      IG: psychocross_v70
    36. #34
      let us know!
    37. #35
      Jan 2015
      Long Island
      let us know!
      Definitely will do
      IG: psychocross_v70
    38. Remove Advertisements
