AOC Oil Pump Failure Check-In
    Results 1 to 4 of 4
      Jun 2014
      Summerlin
      I just got mine replaced. "Active Ondemand Coupling" Oil Pump for the AWD.
      I was in FWD mode for more miles than I'd like to discuss, but this seems to specifically be an issue with R-Design S60's and I want to discuss that..
      Who else is in this boat? It's not something that needs to be immediately repaired as the AWD will be fine disabled for thousands of miles, but annoying none the less when you have 350 ft-lbs+ of turbo torque to put down
      - Symptoms show in the signs of excessive wheel spin, usually before any warning messages
      You should not have any, the AWD and DTSC system is instantly fast at redirecting torque from the front to the back or any of the 4 wheels with braking
      - Eventually, the AWD Disabled message will show
      - Much better MPG
      - Feeling of more power as AWD is not contributing to parasitic load anymore
      Independent shop repair cost $550 (labor/part was half and half nearly)
      Only mechanical problem in 84k mi/2yrs with a lead foot? Priceless
      Sep 2015
      Jacksonville, Fl
      Just had mine replaced under warranty.
      Junior Member Denton's Avatar
      May 2006
      Atlanta, GA
      Bad in my 2006 XC70, there is a filter that clogs
      2016 Passion Red/Off-black S60 T5 R-Design
      2006 Ice White/Oak XC70
      1996 Polar White/Charcoal 854R
      Former: 1996 Bright Red 855R, 2003 Silver V70 T5, 2012 Black Sapphire C30 T5 R-Design 6MT P*
      My friend's 2013 XC60 T6 had the same failure at a relatively young mileage (20-30K).
      2013 XC60 T6 AWD
    7. Remove Advertisements
