| Quote, originally posted by MenardVolvo » |
| I own a 1992 245 with a manual tranmission, but no tachometer. Would it be easier/cheaper to add one in inside the dash cluster, or to put one outside the cluster next to the vents? Is there anywhere I can find either? |
I think is just as easy to install the large tach as it is to mount a tach external to the cluster. The reasoning being that you're going to have to remove the cluster to get to the tach wire, and once it's out, it's just a few screws to get the job done.
I have a matte finish tach with mini-clock if you want it. It's yours for $40 + actual shipping.
