FS: 2004 BlackSaph / Gobi SR, 140k, SF Bay Area, Stage 2+, $9k with lots of extras
    Results 1 to 5 of 5
      Jan 2011
      San Francisco, CA
      FS: 2004 BlackSaph / Gobi SR, 145k, SF Bay Area, Stage 2+, $9k OBO with lots of extras
      What started out innocently a few weeks ago as just "cleaning out the garage" has turned into me deciding to sell both of my Volvo projects: this car and a 122s to be listed soon. I loved this car from the moment I bought it in 2010 and even now it's hard to sell. It's still a blast to drive and will be a lot of fun for whoever the next lucky owner is.
      First things first, asking $9,000 OBO (price updated to reflect additional parts/labor put in to resolve known issues) with all spare parts included that are listed below. I want to sell the car + all the parts together so I don't have to deal with them separately. If you have the time to resell / list the parts on swedespeed it just makes this car even cheaper for you. I will not sell parts separately at this point.
      She has just about every bolt on mod except for tuning for water meth and putting in a new turbo.
      Here are more details. Pictures will be posted within a week or two after I get the car detailed. Wanted to get this listing up first with all the information so people could get in touch ahead of time if interested.
      Exterior: Black Sapphire
      Interior: Gobi Sand
      Transmission: 6MT
      Mileage: ~145k
      Bought her back in August 2010 with 36K miles and have put 100k (almost exclusively highway miles) on since.
      Maintenance:
      All service records available from before my purchase
      Oil changes at 5-7k intervals since purchase
      Complete fluid flush and replacement at 60k (courtesy of Swedespeed sticky)
      New timing belt and water pump at 100k (2014)
      Collar gear and all seals along the way replaced in 2011
      All shocks/struts/spring seats (~$1600) replaced in 2013
      New battery installed in 2013 ($150)
      Reverse light (backup sensor) replaced in 2012
      AC condenser replaced ($200) and recharged ($100) in 2012 (AC still blows cold today)
      New radiator fan installed 2013 ($400)
      New power steering pump, lines and reservoir (2005 version)
      New vacuum lines installed in 2013.
      2016:
      New DDM HID headlamps and foglights (installed July 16)
      New iPd pegasus replica 18" machined face wheels (installed 7/7/16) (~$700)
      New Conti DW high perf summer tires (installed July '16) (~$800)
      New Hawk HPS brake pads installed front and rear July 2016 (140k)
      New brake fluid flush and replace July 2016 (140k)
      New electronic throttle module Sep 2016 (~$1000)
      New right and left drip moldings (around doors), replaced due to peeling ($600)
      New radiator expansion tank (Sept 2016)
      New turn signal stalk, old one wasn't working all the time (Sept 2016)
      New high beams, low beam HIDs and fog light HIDs (Oct 16)
      2017:
      New alternator to resolve electrical service light
      New front passenger side U-joint to resolve vibration at speed
      Used angle gear (with ~60k) + hardened collar gear + new seals installed to resolve small leak at transmission (Early 2017)
      Full detailing
      MOD LIST
      Intake:
      - Snabb intake pipe ($160)
      - Phuzzy FMIC with SS throttle body tube ($550)
      - Viva (Forge) CBV ($160)
      - OEM airbox replaced with massive AEM 21-2259DK dry flow filter
      - AEM wideband failsafe water/meth injection with windshield fluid tank tap and UEGO combined AFR/boost gauge (driver vent mounted)
      Engine:
      - iPd (MTE) Stage 2 ECU ($700)
      - Okada Plasma Direct Coils ($1250)
      Suspension:
      - TME lowering springs ($500)
      - iPd Track Spec Front and Rear Sway Bars ($450)
      - TKi adjustable endlinks + TKi adjustable toe bars ($500)
      Exhaust:
      - EST "sport" exhaust kit ($900)
      - EST DP w/ high flow cat, ceramic coated + O2 sensor spacer + 3 O2 bungs (recently passed CA smog, but likely will not pass next time) ($700)
      Brakes:
      - Stainless steel brake lines ($110)
      - Custom G2 painted blue brembos + white vinyl R logos ($200)
      - HardBrakes.com Titanium Brake Shims ($135 for front/rear)
      - Adam's rotors custom slotted front and back brake rotors ($630)
      Other:
      - Eurospec (e-code) front headlamps ($1400)
      - Power folding mirrors with functional button
      - DDM tuning 3k HID foglamps w/ 35W ballast
      - DDM tuning 5k HID low beams w/ 55W ballast
      - All LED interior lighting
      - Takspeed CNC door pin kit
      - All weather mat kit including trunk
      - Takspeed racing flag rear badge
      - 10mm H&R spacers on all corners
      - Full sized spare (curb rashed 18" OEM pegasus)
      - ARD lightweight crankshaft pulley ($119)
      - Fatmat in trunk
      - SW updates: Euro light (no DRL); Allow Hi + low + fog all on at same time; foldable power mirrors
      - Body color matched side moldings (new '05 moldings, painted) (~$1,000)
      - XC90 axle bolts to kill axle ping
      - Studs and lugnut conversion all around
      - OEM DEM heatshield
      - Volvo VIDA diagnostics CDs, DICE hardware dongle (~$260)
      SPARE PARTS
      New in box:
      - Ball joint kit
      - L/R front control arms
      - Accessory belt tensioner
      - (3) 19" iPd pegasus replica machined face wheels
      - Collar gear service kit with seals
      - OEM spark plug set
      - (8) gallons of boost juice for water/meth
      - Delrin subframe bushings (never installed)
      - Viva OTE blowoff valve
      Used:
      - Headlamp wiper motors
      - 1xPhuz DP + EST touring resonator welded to it
      - Lots of lug bolts
      - Strut tower brace
      THE BAD
      Interior is not in great shape (7/10)
      - Passenger side door panel speaker grill is cracked
      - Some stains in interior carpeting
      - Backseat and passenger leather is in good condition, driver's seat is worn.
      - Center console scratched up, should get a repaint or be replaced with an '05
      Exterior:
      - No front winglets.
      - Rear valence has many chips from city parking
      - Front hood paint is in rough condition
      ... Great candidate for a really nice wrap (I was considering myself but figured the buyer would rather see the original paint ...)
      Electrical:
      - Stereo works but input selection is very twitchy
      Transmission:
      - Had a new clutch installed at ~40K, probably coming up on another soon (no specific issues yet though)
      Check Engine Light:
      - Shop diagnosed this as an O2 sensor issue, I'm not surprised given that it is running an EST DP and high flow cat. I'm happy to pull codes / run VIDA to show no other issues.
      Last edited by noeish; 03-08-2017 at 01:42 AM. Reason: Updated with issues resolved, new price
      04 6MT SR BlackSaph/Gobi. iPd Stage2. PhMIC. EST DP, catback. Snabb Intake. Viva CBV. OkadaPlasmaDirects. AdamsRotors. TakSpeed TiShims. SS lines. iPd TrackSpec Sways. TKi front/rear endlinks, toe bars. iPd R Gauge. EST LED kit. GROM iPod+Bluetooth. 19" Peg Reps. DDM 5000K HID Hi/Lo/Fog. E-codes. To do: Winglets. Door pins. FatMat.
      Jan 2011
      San Francisco, CA
      Still haven't made time to get her detailed but took a few pictures of the exterior. Will get some interior pics up soon.
      Jan 2011
      San Francisco, CA
      Finally got a chance to get her cleaned up and detailed. Exterior has held up surprisingly well for a 13 year old daily driver in SF.
      Jan 2011
      San Francisco, CA
    7. #5
      Jan 2011
      San Francisco, CA
      TTT
    8. Remove Advertisements
