Best t5 inlet manifold upgrade - Page 4
    Page 4 of 5 FirstFirst 1 2 3 4 5 LastLast
    Results 106 to 140 of 151
    1. #106
      Member
      Dec 2013
      Northern CA
      You've been pm'd and text'd. Your move.
      2005 V50 T5 AWD M66
      Member EngTech's Avatar
      Jan 2007
      Knight's of the Round Table - TN
      OK - Responded for Discounts
      SS Members
      - which I believe takes about ( 1500 Post Min. ) or a
      Donation of Equal Time of said ; Technical Input . . of . . Valve .
      You have too Read Line starting with SS Members - above - Twice Out Load . .
      Agree , Stage 2 is a little over the Top - unless - You plan down the road K16 or Cams .
      Currently My Stage 1 is Good for Seat of the Pants 12 HP -15 HP and 18 Ft Lbs - My Upper is Not Ported , but is Matched . . and
      I Don't have the 70MM TB , but Usable Rpm Range - Extended - 700 Rpm .
      ps: OR A Monetary Donation of Money to SS = Equal to approx 375 Candle Sticks - as We need to Light This Place Up ..
      Pss: Pretty Sure this Place doesn't Run on Candle Power . .
      ** V50 AWD - Handling & Performance Tweaks = New Stance / VW CC - Handling Tweaks - Testing & Porting - Intake Mods
      A Garden Gate will Last You a Life Time . http://s261.photobucket.com/user/Eng...0Trim%20%20etc
    4. #108
      Jan 2007
      OK - These are OVER THE TOP - Intakes etc.
      Sure I can find some Volvo Intakes , but just to set the Record straight on Over the Top :
      http://forums.vwvortex.com/showthrea...hardware-only!
      Member
      Dec 2013
      Northern CA
      Can you post more pics of your port job?
      2005 V50 T5 AWD M66
    7. #110
      Jan 2007
      Quote Originally Posted by mercdude View Post
      Just for You Man ..
      Porting Everything .. This . . Flows Nice !
      By the Tim - I got the Manifold Cleaned for the 4th Time to Inspect - looking for any thing I could have done a little Better I was
      a Little Hungry .. after all the back and Forth . . back .. and Forth .
      There was some sort of Plastic Crap stuck down in the O-Ring Grooves and - good thing I had a Set - just to get those to stay in and
      then Do a Ink Transfer with all the Weight of the Intakes - Dragged - all in all another 4 Hrs. Later - Not Counting Trip to get some Special Ink .
      Matched Up - OK - 10 Times Better with Gasket to use , but My Volvo is Up on Blocks .
      Wife couldn't Find the Transfer Paper - so - I could make a Gasket . .
      I wonder How much Higher one of these Plums could be Mounted .675 maybe before it Hit the Under side or the Hood ..
      During Throttle & Gear Moves ..
      ( Anyone ever Check ) ?_?
      Maybe It's Time for a Custom Intake - aren't some of those Intakes I posted Pic - Wild . .
      https://youtu.be/uHqHd016hsg
    8. #111
      Jan 2007
      This Not the Final Polish or Clean , but pretty Close .. Tell Me How it Looks - it has a few minor very lite zings
      Nothing that will effect Air Flow ..
      https://youtu.be/O92wmyCQhg4
    9. #112
      Member
      Dec 2013
      Northern CA
      Looks really clean. Is that lower already port matched to the Puma upper?
      2005 V50 T5 AWD M66
    10. #113
      Jan 2007
      No - I did more on the other end and then Cleaned up with more Polish - also did the welds some - U - see in the Top after I took Vid.
      (( By the Time - I got the Manifold Cleaned for the 4th Time to Inspect - looking for any thing I could have done a little Better I was
      a Little Hungry .. after all . . the back and Forth . . back .. and Forth .
      Wife couldn't Find the Transfer Paper - so - I could make a Gasket . . ))
    11. #114
      Jan 2007
      Looking Back at These Plumes - Certainly anyone that has a Generation 1 - Plume ( Has to get that Ported ) re-guarding the Puma .
      The Sec. Generation - supposedly Improved at the Outlets - Still has No special Gasket - all I can say is Wow - how Bad was Generation 1 ?
      Looks to Me Don - spent more Time Designing and Executing His Product .. .. Anyone that Got the Early Version & Paid more to have it
      Power Pumice Ported . . certainly has Very Good Performer .
      Anyone Needing the Top Cleaned Up and Matched , seems all have Enough Material .
      I'd even say there is enough to do ( Velocity Stacks ) = Stage 2 on Top .
      I do slightly Velocity Stack them on Matching & Clean Up . .
      All should get Don's Gasket as it could be Easy Adapted ( Into being Used ) on all these Other Plumes ; with
      ( My Port Matching Upper ) . .
    12. #115
      Member
      Dec 2013
      Northern CA
      I agree - the puma upper is not nearly as polished as the moutune/elevate upper. I chose the Puma upper because it was cheap(ish), looks stock, and flows better than stock. Obviously there's room for improvement - enter engtech's porting service.
      2005 V50 T5 AWD M66
    13. #116
      Member GRat9717's Avatar
      Jan 2013
      NJ, USA
      I will have a matched Puma and lower inlet before the week is out courtesy of Mr.EngTech
      Garage Queen - 2010 C30 R-Design Vrooooooom
      Daily - 2016 V60 T5 Drive-E Vrooooooom
      Zichrona Livracha - 2004.5 S40 T5
    14. #117
      Member
      Dec 2013
      Northern CA
      I'm planning on sending him mine too - let me know how it comes out!
      2005 V50 T5 AWD M66
    15. #118
      Jan 2007
      Basically a Stage 1 Port Light with Light Polish of Outlets - with - Match Alignment .
      I also Clean up the Throttle Inlet Area . .
      Hope You like it _ I got Stuffed on the No Gasket Deal . .
      Just Packaged Up . .
    16. #119
      Jan 2007
      Forget to Mention above : I also do the Velocity Stack Increase on the Outlets :
      I Noticed on the Puma - the Design seem to Favor the Velocity Stack - Effect - as the Their -
      ( Puma Plume - is in itself a Velocity Stack )
    17. #120
      Jan 2013
      NJ, USA
      I received some art in the mail today...
      Dan cleaned up the Puma manifold I send him. He smoothed out the mating surface...
      https://goo.gl/photos/LoEcxrTC1JFvvWyB7
      Matched the Puma throttle body area and the ports to the lower he did for me (picture for inner port clarity)...
      https://goo.gl/photos/ncJ4Kbs8MFf1HBGg9
      and the finished stage 2 lower...
      https://goo.gl/photos/iD53pEUPUdbx9R1E7
      Absolutely awesome work. Can't wait to install. Aiming for Sunday!
    18. #121
      Member
      Dec 2013
      Northern CA
      Looks awesome. Keep us informed.
      2005 V50 T5 AWD M66
    19. #122
      Aug 2016
      South Pasadena, CA
      Quote Originally Posted by GRat9717 View Post
      Dan's the man. That's for sure. I have some art of my own that I've been sitting on for a while. I need to stop being lazy and share it soon.
      2005 Volvo S40 T5 AWD M66 || 1987 Toyota MR2 || 2002 Lexus IS300 [hers] || 2008 Volvo V50 T5 [Sold 2016] || 2001 Acura Integra GSR [Stolen 2010 lol]
    20. #123
      Member
      Dec 2013
      Northern CA
      It'd be sweet to see before/after shots.
      2005 V50 T5 AWD M66
    21. #124
      Jan 2013
      NJ, USA
      Upon opening from the UK. The plastic is from being tightly wrapped in bubble wrap: https://goo.gl/photos/uJs6pwHgr7otfpxH6
      Closeup of imperfections: https://goo.gl/photos/NPFNvSoMh5uyzyTX8
      Worked started on the ports: https://goo.gl/photos/Ctsq5zz1G5RggKEw5
    22. #125
      That's pretty sweet. I really enjoy working on rough cast stuff more than the already painted and polished stuff. Gives you tons of work room and you don't have to keep it pretty until you're totally done with the work.
      1996 HD Electra Glide - Big Bertha 10:1 Pistons; EV13 Cam: Ultima Digital Ignition; Buell Head Conversion; E85 Carb Tuned;
    23. #126
      Member
      Dec 2013
      Northern CA
      Any shots of the lower?
      2005 V50 T5 AWD M66
    24. #127
      Jan 2013
      NJ, USA
      No, but they're all the same - rough!
    25. #128
      Member
      Dec 2013
      Northern CA
      I was kinda interested in how much Dan opened up the throat of the runners to match up with the upper inlet's port.
      2005 V50 T5 AWD M66
    26. #129
      Anyone ever done some work with Flex-Hones? I planned on using one (a 1.5 or 2"er 400 grit one) on the intake manifold lower to remove some material and then a fine 800 grit one to polish it. Then I planned on using it to size match the holes on the upper too. and then when the head comes off...oolala.
      I was impressed when I used this to hone my harley cylinders, seems to be a great product.
    27. #130
      Member
      Dec 2013
      Northern CA
      Those are designed for cylinder honing - I doubt those are abrasive enough to remove a sizeable amount of material off the runners. Maybe I'm wrong?
      2005 V50 T5 AWD M66
    28. #131
      Some of them are for cylinder honing. They make smaller ones for stuff even down to gun-barrel size (.45ACP) ($30 or so). They actually have sizes going up by 1/4" starting at 1" so that's pretty sweet, and silicone-carbide and aluminum oxide as abrasives.
      The silicone carbide one is strong enough to remove material from the cast iron liners in my S&S cylinders, so I don't think abrasiveness is a issue, but I haven't played with the aluminum oxide ones. Going rate when I was honing them out was .01" for every 10 minutes of run time on a full speed clutch drill. My cylinders needed about .02" removed total to fit the wiseco's in there. After about 40 minutes they were both about 0.001" off from what I needed so just a few more zips and they were done and honed (did the ~130 grit from removal and the 300 grit for the oil trap hone.
      In my opinion, will beat the 3-4 hours to spent using them small grinding and polishing bits included in some of those kits. plus they're flexible so it'll go with the curve. easier and remove material conducive to a straight line rather than a curve considering the tension on the wire to straighten out, making your airflow path of travel slightly less 90-degree curvish.
    29. #132
      Jan 2007
      LOL - Try 15 Hours - can't wait to see those New Improved _ Units ya all Talking about . . Tell me what's the Perfect Sizing for those ..
      The Plenum came in with all Ports .01 difference on all and 2 Ports were .20 & .30 larger then the others .. Velocity Stack effect was almost Nil
      on Stock Top ..
      I used a String Held by a thin Rod and Blasted the Manifold with High Speed Fan & Compressed Air - Watched - Effect it Had on Fast
      Air coming Up into Plenum .
      1 Hr. of study & 1 Hr. of set up .. Puma is Different the Elevates :
      Reasons ? These Booger are Here : Look at that Fat Flat - one - Uuurrrraaa
      [IMG][/IMG]
    30. #133
      Jan 2007
      Make Sure You take Video's of this Work being done - I'm Ordering Pop Corn
      This 2nd Cutting : still Not Polished
      Issues with Excessive Polishing - Surface becomes Sticky - also the more You Polish ( Every Little , Little , Tiny , Line becomes Magnified )
      all of which is _ well into the 280 Finish Range .
      [IMG][/IMG]
    31. #134
      Jan 2013
      NJ, USA
      Quote Originally Posted by EngTech View Post
      Did you ever notice that those holes between the runners make a face?
    32. #135
      I'm probably going to use the gasket method. Draw the gasket size holes on the lower mani and then just keep running the spiralhone in and out until it's close. That way all 5 will be as large and as smooth as possible. That one in your photo with the face Grat commented on is a 70 series one isn't it?
      I'll post before and after pics of mine when it's done. Do we have to replace the head - manifold gasket or the manifold lower-upper gaskets when we take it apart or are they metal stamped bad boys? I get paid Monday so I should be able to order it without too much trouble.
    33. #136
      Jan 2007
      Haven't seen any Comments , Your ? about the Pic - No that's GRat's Lower Unit ! - - ( Garrett"s )
      Everyone has preferred methods and Tools - just as 1 Mechanic Tunes Rotors & Others Replace them ..
      Now , I might be able to do this for 1 yr. -
      ( Maybe ) My Wrist - were pretty Beat 3/4 way through , but it was
      Time to do the Lighter Stuff which takes 3 - 4 times longer .. Gripping so Long - Your Hand Locks up & get Stiff .
      ( Pace Yourself : 5 - 6 hr. Max @ a Time make sure to Step Back and Re-access Work done ! )
      INSPECT , INSPECT , INSPECTION
      I'll Add more Photo's and the Tools in the Pic's are there for a reason , It is very Hard to Turn Yourself into a Machine .
      Your Must Use -
      1. Consistent Pressure - most of the Time ..
      2. You must do Similar Moves and Passes to each Runner . ( Keep Tools Moving )
      3. Don't Over Heat Your Tools - so - Keep 3 Set Up's near by - Lay 1 down , Pick another Up .
      4. Measure Your Part : Before and After as You start to get a Feel or to Gage the Material Rate of Removal ..
      5. Light Oil could be used to help Keep Chips - Out of Your Carbides . ( Carbides come in Short and Long Shafts )
      6. Carbides Also come Designed for - Steel & Cast or Aluminum Alloys .
      7. Plan for Desired Air Flow to Application .
      8. Have all Tools to be Used in Place and Ready to Go . ( Investing Ahead of Time . ) & Different Types . .
      9. ( Battery Power , Electric Power , Air Powered ) some of Each . .
      10. Top Upper Plenum is Fairly easy - Lower Intake is more Complicated - Technical .
      11. There are Basically 2 Air Stall Points behind the Valves - looking @ Intakes Lower Runners & Upper Plenum .
      12. Air Speed is very Important , Profile , Sizing and then Volume .
    34. #137
      Jan 2007
      Cutting Must Keep the Tool Moving .
      You have to Feel the Material as it's being Cut to Vary Load You apply , so as You proceed TOO DESIRED Shape
      Always Heading toward the Design Plan - You started with .
      1. Adding Velocity Stack Effect
      2. Straight Out - Sharp Turns or High Pressure Points by Smoothing with Softer Radii .
      3. 2 Stall Area's - Air in Very Fast - Out Ever Faster !
      4. OE Factory's Idea is to FILL the Plenum FAST - They Open Up - Cly #5 Lower Intake Track & Last Plenum Outlet More then Others . .
      5. Puma does the same thing Only tried to have Slightly Decreasing Effect - by - Staging each Cly Outlet in Steps slightly smaller all the way back
      ( Throttle Body ) .
      . Elevate - does it Mostly on Cly5 and again with Large Radii sitting above Outlets and Volume . .
      My Take on this is to Increase Their Effects - By - Enhancing what they Started !
      Puma I gave Larger Velocity Stack Effect - Increased Throttle Body Match - Enhancing to Top & Sides - Increase Plenum Fill Rate .
      Increase Outlets also same % as Lower Unit . ( Air Stall in Plenum is in Micro _ Sec. ) Speeding the Exit Air - there - FIRES Pulses !
      When the Window is of Time is Open ..
    35. #138
      Jan 2007
      I Hope some of You found this Enlightening .
      I Broke it down ( Hoping this would be Guide )
      I Broke Out My Tools this Morning :
      [IMG][/IMG]
      Man this Thing Looking Ready !
      [IMG][/IMG]
    36. #139
      Jan 2013
      NJ, USA
      Busy night/morning...
      First cold start after Puma Upper and Dan's Lower - https://goo.gl/photos/nZ6GvvX7WYPd4ovK6
      Compared to a cold start two years ago no engine mods at all (different camera) - https://www.youtube.com/watch?v=mSUHyXBmoTw
      When I pulled the lower from the car there was some rust inside the runners. No good! Much cleaner and nicer sound now (and a little louder too).
    37. #140
      Jan 2007
      Two cold starts - One is way Smoother , little Deeper .. ( This one Lit the Cat - Fast )
      The Other one sound tinny and raw Fuel into Cat . .
      Nice - must be getting More Oxygen . . Why do all those Cars have Pumps ?
      Here You able to Tell amount of material Removal just Compare the Two Outlets . .
      Not Polished Yet and Velocity Stack Improve Not Done - Yet . . ( Just for Material Comparison )
      Puma Plays well with this as in - Itself - is a Velocity Stack - using Air Speed as it's Friend .
      All Intakes and Exhuast have Pulses - it's getting that Pulse into Plenum & Into the Lower Outlets .
      ( Stacking the Odds ) sort of Speak . .
      [IMG][/IMG]
    38. Remove Advertisements
