S60/V70 R BREMBO Brake SWAP :: HOW TO - Page 2
    Page 2 of 3 FirstFirst 1 2 3 LastLast
    Results 36 to 70 of 85
    1. #36
      Global Moderator R-Pow3R3d's Avatar
      Apr 2015
      Pittsburgh, PA
      Definitely looks good. If I find a spare set for the XC maybe I'll try painting them.
      2004 Volvo V70R MT TiGray/Nordkap - Replica 18" Pegs - Handbrake Mod
      2006 Volvo S60R GT TiGray/Gobi - '06-'07 Transmission Valve Body Info
      2007 Volvo XC90 V8 Sport Passion Red/Off-Black - Serpentine Belt, Tensioner & Idler Pulleys - Spark Plug Replacement
      VIDA/DICE Owner - SS Lurker Since 2009
      Junior Member V50R's Avatar
      Nov 2014
      Rochester Hills MI
      Front and rears finally painted, now got to get some R decals.
      Fronts
      Rears
      2006 V50 T5 AWD AW55, 320mm FR Brake upgrade, Elevate Intake, OBX Exhaust.
      2010 XC90 V8 Executive Latest Addition.
      2008 XC90 V8 Executive Edition, w/Muffler Delete.
      2005 XC90 V8 Black, VB replaced, S60R Brake Swaped
      2013 Jetta Sportwagen TDI 6spd. Malone S2 tuned 200hp/350tq.
    4. #38
      Apr 2015
      Pittsburgh, PA
      Quote Originally Posted by V50R View Post
      https://sweetgfx.com/product/caliper-r/
      have you had a chance to drive in heavy rain? Any issues with the braking? I remember when my R was on the road that in times of decent to heavy rain, I had to pump the brakes to make sure they caught before actually needing to use them. I haven't had to do that with the stock XC brakes.
    7. #40
      Apr 2015
      Pittsburgh, PA
      Quote Originally Posted by mugen910 View Post
      Really?! That sounds bad. I've never had that in either R.
    8. #41
      Member oneofakind's Avatar
      Mar 2015
      West Yellowstone, MT
      My stock brakes do it badly. Slush is the worst, I clear my brakes every 3 miles or so, otherwise my brakes won't kick in for 2 or 3 seconds.
      Sent from my SM-N920V using Tapatalk
      2007 XC90 V8 Sport (R-Design), Passion Red, Large Iron Mark Grille, Satin Black Metallic Powder Coated Rims, 2013 Smoked Tail Lights, Lighted Upper Tail Lights, Chrome Executive Inlets, 32" Light Bar, Full Roof Rack w/ 36" Tri-Row Bar, 20" Light Bar, 4 7" Side Light Bars, 2 6" Back Up Light Bars, Full Sized Shovel, Full Sized Axe, Hi-Lift. S60R Brembo Brakes Front+Rear, 25mm Spacers, EBC Rotors+Pads.
    9. #42
      Nov 2014
      Rochester Hills MI
      Drove in heavy rain no issue but the fronts are slotted so that probably helps but I know what you mean the rotors are wet so it takes a second or two before the pad can scrub that off.
    10. #43
      May 2014
      Hyattsville, MD
      I PM'd you about the calipers you pulled off during this swap. Could you measure the piston diameters for me? Thanks!
      2006 xc90 2.5t - 115kmi - Hilton Tune - R Design Supension : Family Wagon
      2009 v50 2.4i 75kmi - Bone Stock : Wifemobile
      2011 c30 RD : Moms
      2012 s60 t5 : Pops
    11. #44
      May 2014
      Hyattsville, MD
      Quote Originally Posted by R-Pow3R3d View Post
      Anyone know if 19" Vulcanis will clear R calipers without spacers?
      I can tell you in the next couple of weeks. I plan on doing this swap (have the calipers) and am currently running Vulcanis. I will do a test fit, but it will probably be 6 months before I really get all the parts and the time together LOL...
      2011 c30 RD : Moms
      2012 s60 t5 : Pops
    12. #45
      Apr 2015
      Pittsburgh, PA
      Quote Originally Posted by audeo03 View Post
      I can tell you next week. I plan on doing this swap and am currently running Vulcanis. I will do a test fit as it will probably be 6 months before I really get all the parts and the time together LOL...
      If you don't want to do an entire test fit, you can use this spacing template he provided:
      https://docs.google.com/file/d/0B7R6...lXekozNXc/view
      Can't wait to find out if they fit!
    13. #46
      May 2014
      Hyattsville, MD
      I am going to just bite the bullet and buy pads and rotors. Then when I'm swapping to the r-design struts in the next week or two, I can just lay the front and rear rotor/caliper/pad combo onto one of the wheels when I take them off.
      2011 c30 RD : Moms
      2012 s60 t5 : Pops
    14. #47
      Nov 2014
      Rochester Hills MI
      Bought some cheap Brembo decals to finish up the swap. Some day I want to get R decals but for now these will do!
    15. #48
      May 2014
      Hyattsville, MD
      V50R: How does the brake balance feel? This swap moves the XC90's brake balance more towards the rear. Can you tell that there is less front end dive? Have you locked up the rears?
      From just running the basic calculation, the actual braking force appears to be a little less for the R setup versus the stock calipers (~ .90/.98 ((R/XC90) @ F/R)). This takes into account the rotor sizes, total piston areas, and the slight difference in pad width (in radial direction).
      BUT, it may require less brake fluid to generate the same force at the caliper (so that the pedal feels firmer), the pads have more uniform pressure on the disc, the brakes are better at dissipating heat, and they reduce the un-sprung mass (better vehicle dynamics).
      I plan on doing this swap sometime soon (hopefully), but first doing measurements of braking distances and rotor and caliper temperatures using a fluke IR gun, and then after the swap and proper brake bed-in time... I will keep pad selection constant (Akebono ceramic).
      2011 c30 RD : Moms
      2012 s60 t5 : Pops
    16. #49
      Nov 2014
      Rochester Hills MI
      BUT, it may require less brake fluid to generate the same force at the caliper (so that the pedal feels firmer), the pads have more uniform pressure on the disc, the brakes are better at dissipating heat, and they reduce the un-sprung mass (better vehicle dynamics). This then probably raises the effective braking force to be on par or greater in the front versus stock, and definitely greater in the rear versus stock.
      This is some great Info right there.
      I know math may say that the swap is highly unnecessary but I've owned 7-8cars in my life and I've upgraded every single one with OEM parts bin stuff usually bigger rotors etc.
      I can tell you one thing the XC90 never really had that firm pedal with lots of control over the amount of brakes you apply they just weren't linear and the pedal always felt very soft with way too much travel. Both my XC90 V8s are exactly the same one is 05, the other 08 different wheels etc same brake feel.
      Wth the S60-R brakes I like how the pedal is very firm, it reacts very quickly maybe 1/4" travel before you get solid brake feel and from there it's very easy to control hard breaking because it doesn't take any movement to modulate the pressure, feels a lot like my R32 brakes on the Golf.
      This right there makes all the difference in the world to me not to mention the budget upgrade in my book this is something I will do to every other XC I own from here on.
      Over the weekend I had to come to sudden stop a few times and I continue to amaze myself of how well they work, to be honest I have to worrry about the guy behind me more than myself.
    17. #50
      May 2014
      Hyattsville, MD
      Excellent! My initial calcs are from dimensions found online (and from you). I will edit this once I have all parts in hand and obtain some empirical data.
      I have calipers and am ordering rotors and pads today. Do you need to remove the rear hub to change to a S60R splash guard? Also, the stock XC90 brake hoses work with the R calipers? I want to order stainless lines, but might wait until after the swap. That way the second bleed can also take care of the ABS section as well...
      BTW, bigger rotors always help with total braking torque, but here the front rotor is the same size...
      2011 c30 RD : Moms
      2012 s60 t5 : Pops
    18. #51
      Nov 2014
      Rochester Hills MI
      So as far as the lines I used the OEM XC fronts and rear left. Rear right my hose was twisted 180 and i couldnt get it to align so i ended up swapping it with the S60R one since it was a tad bit short and i was getting a bit of a stretch at full suspension droop.
      Now this could have been resolved by loosening the hose and twisting it 90deg but i ended up damaging it and so i decided to replace it with one of the longer ones i had in hand.
      If you go stainless steel ones deff go with XC90 ones since they are longer due to increased suspension travel.
      on the fronts during full suspension droop and tire turned all the way out the hose does stretch but not to a point where it will snap it just takes all the slack out of it. I thought it would be ok since I never reach that condition where the tire is turned to max and the wheel is fully extended.
    19. #52
      Mar 2015
      I sent you a message about sizing. Thanks!
    20. #53
      Mar 2015
      Well, pulled the trigger on the rears. Waiting for an eBay seller to get back to me on the fronts. Paying steeper than I'd like to, but I got told I have 1 mm left on my rear pads, and I'm not buying pads just to replace them. Getting drilled/slotted rotors front and rear because I tow a lot and drive in snow constantly. Nothing fancy though, not high carbon this time. Now to the hardware store for bolts!
    21. #54
      Mar 2015
      http://www.ebay.com/itm/262699788740?ul_noapp=true
      For anyone interested in upgrading just the front calipers, here is a cheaper set.
      I had to do an emergency braking this morning and i was shocked of how quickly the XC came to a complete stop, it does nose dive but no different than before.
      I just bought these... he took $200 for them. Not too bad. It's coming together!
      Edit: That brass sleeve, could you take a picture of where it goes please? That's the one part I'm not sure about. And where you got it too?
    22. #55
      Mar 2015
      Ok, well looking at rotors and pads, and I stumbled across these. Anyone have experience with the company EBC? They have pads and rotors for all 4 corners for just under $600. Not a great price, but they're performance (hopefully). I'm going to wait till Friday to order anything (Black Friday!), and hopefully I'll get a better deal ($500).
    23. #56
      Apr 2015
      Pittsburgh, PA
      Quote Originally Posted by oneofakind View Post
      You could get Brembo rotors for $278:
      http://www.new-part.com/product/volv...ake-rotors-kit
      And Akebono pads for $120:
      https://www.amazon.com/gp/product/B00199FXQM/
      https://www.amazon.com/gp/product/B008721AQQ/
      Those will be plenty.
    24. #57
      Mar 2015
      Awesome, thank you! You guys save my bacon a lot!
    25. #58
      Junior Member Tythew19's Avatar
      Aug 2016
      Federal Way, WA
      EBC brakes are big in the motorcycle world. They make good stuff. The above deal looks way better though!
      2006 XC90 V8 in Black with Navigation, RSE, Third Row, Curt Tow Hitch (the Work-In-Progress and Daily Driver)
      2004 XC70 in White, Tow Hitch (The Cream Puff and Wife's Daily Driver)
    26. #59
      Apr 2009
      VA
      Cool
      I just received my calipers for this swap and can't wait to execute but I have a question about the rotors. I see the sites and prices and stuff but the question about bore size was not talked about. The factory hub bore size on our XC's is 67.1mm and the S60/V70's are 65.1mm. Is this a factor when ordering the rotors? Or did you guys swap out your old hubs for the 2014 XC90 63.4mm hubs? Need to know before I purchase rotors in a couple weeks. Wife gave me the go ahead to get the calipers now I have to wait.... one thing at a time right..
      1991 Nissan Skyline R32 GTR
      1999 Lexus GS300
      2005 Volvo XC90 V8 Executive
      2012 Cadillac Escalade Premium
    27. #60
      Nov 2014
      Rochester Hills MI
      Quote Originally Posted by ericherm1 View Post
      They use the same hubs so the S60R rotor is 67.1 at the rotor interface and tapers down to 65 after for the wheel spot. The rotors are a direct swap so get the S60R rotors and you will be good!
    28. #61
      Apr 2009
      VA
      Awesome, thanks!
      1999 Lexus GS300
    29. #62
      Nov 2014
      Rochester Hills MI
      So in case you are all wondering what the Brembo brakes can do here is the math.
      2010-up Volvo Dual Piston Front Caliper
      44mm (2) 3040mm
      2008 Volvo Single Piston Caliper.
      60mm (1) 2827mm
      Rear Single Piston Caliper ALL
      44 (1) 1520mm
      S60R Front
      42 (2) 2717mm
      38 (2) 2268mm
      TOTAL 4985mm vs 2827mm ~56% increase in surface area.
      S60R Rear
      30 (2) 1413mm
      28 (2) 1231mm
      Total 2644mm vs1520mm ~57% increase in surface area.
      Mind you the S60R and V70R use the same master cylinder size and P/N.
      So with increase in pad surface area and pressure area with the larger caliper you can see why the breaking can increase substantially.
      FRONT BRAKE CALIPER PISTON DETAILS:
      Leading Piston Size: 42mm (2 of each)
      Trailing Piston Size: 38mm (2 of each)
      REAR BRAKE CALIPER PISTON DETAILS:
      Leading Piston Size: 28mm (2 of each)
      Trailing Piston Size: 30mm (2 of each)
      http://www.vivaperformance.com/brake...ons-s60r-v70r/
    30. #63
      May 2014
      Hyattsville, MD
      44mm (2) 3040mm
      60mm (1) 2827mm
      44 (1) 1520mm
      S60R Front
      42 (2) 2717mm
      38 (2) 2268mm
      S60R Rear
      30 (2) 1413mm
      28 (2) 1231mm
      So, I think that your math is wrong... It is the total surface area of the pistons in the calculation, irrespective of a fixed or sliding caliper design. I have the ideal clamping force ratios to be 12% greater in the front and 15% greater in the rear for the XC90 than for the S60R:
      xc_pis_fr = 60.0
      xc_pis_rr = 44.0
      r_pis_fr1 = 42.0
      r_pis_fr2 = 38.0
      r_pis_rr1 = 28.0
      r_pis_rr2 = 30.0
      xc_fsa = 2*!pi*(xc_pis_fr/2)^2
      xc_rsa = 2*!pi*(xc_pis_rr/2)^2
      r_fsa = 2*!pi*(r_pis_fr1/2)^2 + 2*!pi*(r_pis_fr2/2)^2
      r_rsa = 2*!pi*(r_pis_rr1/2)^2 + 2*!pi*(r_pis_rr2/2)^2
      print, (xc_fsa)/(r_fsa)
      print, (xc_rsa)/(r_rsa)
      % Compiled module: BRAKE_CALCS.
      1.12219
      1.14964
      2011 c30 RD : Moms
      2012 s60 t5 : Pops
    31. #64
      Apr 2009
      VA
      Received my rotors and pads from RockAuto Friday and I just finished the rear install but stuck on the fronts for now. I'm trying to find the M12x30 bolts and the 1mm sleeves. Where did you find yours?
      Done with the rears, waiting to finish the fronts before I brake them in.
      1999 Lexus GS300
    32. #65
      Nov 2014
      Rochester Hills MI
      Don't worry about the sleeves you can always add them on later!
    33. #66
      Mar 2015
      I've had my brakes on for a bit now, no sleeves. I don't feel any difference driving, and if the sleeve I have doesn't fit, I'm just going to leave them out.
    34. #67
      Nov 2014
      Rochester Hills MI
      Lucky us the clamping force of the m12 bolt is enough to keep the caliper from ever shifting! If torqued correctly!
    35. #68
      Apr 2009
      VA
      Done but I need the go with larger spacers. I'm 0.1mm shy on the very bottom edge so now the paint is rubbed off the bottom edge of the front calipers. I'll just go from 10mm spacers to 20mm. That should do the trick. lol.
      1999 Lexus GS300
    36. #69
      Nov 2014
      Rochester Hills MI
      That looks awesome! I'd say go with 15mm if you can find some. Otherwise it's good to know that those brakes and wheels almost work great!
      Looks stunning!
    37. #70
      Nov 2014
      Rochester Hills MI
      Check Ebay i saw spacers that were 15mm and 20mm for the S60R guys. You may have to machine them from 65.1 to 67.1 to fit them on your car though but this will make the stance and wheels sit perfect with the fender flares and the braeks.
      Have you thought about color change? Yellow or RED? or even Polestar BLUE?
    38. Remove Advertisements
