Full LED interior/exterior light swap, 2013 S60 - Page 2
    Page 2 of 2 FirstFirst 1 2
    Results 36 to 46 of 46
    1. #36
      Jun 2012
      Pittsburgh, PA
      Quote Originally Posted by v0lky View Post
      how did you change the puddle lights. i tried hard but i couldnt.
      I carefully pulled out the mirror glass.
      I then used a flat head screw driver to push on the tab and release the light housing. One side was easy the other a little stubborn.
      2012 S60 T5 Savile Gray/Beachwood
      Jun 2012
      Pittsburgh, PA
      I got the interior LEDs I ordered from Superbright.
      I'm glad I ordered all new bases as well because the old lights were either going to be too hard to pull out or the original bases not work with the new light.
      I replaced all the ceiling lights and what a difference! I love them. Natural while is what you want. Great color and tons of light.
      I'll do the foot wells sometime this weekend.
    4. #38
      Quote Originally Posted by Almaz View Post
      Search for these on Amazon. They are the ones I got:
      OSRAM - Night Breaker Unlimited H11 Halogen Bulbs Germany (Pair)
      Sent from my Nexus 5 using Tapatalk
      I assume yours are the non hid lights ?
      2003 mustang COBRA ( SVT 10th anniversary ) born on 6-26-03/ 4634 of 5082 of verts & 955th of 2003 SVT 10th ANNIV edition`s
      2006 s40 2.4i fwd
      my new baby!!! black on black 2012 s60 T6 awd
      Jun 2012
      Pittsburgh, PA
      Quote Originally Posted by mmustangsrus View Post
      Correct. I have the regular headlights.
    7. #40
      AMAZING! How did you replace the footwell bulbs?
    8. #41
      Jun 2012
      Pittsburgh, PA
      I, for one, was not able to crack open the footwell light housing. I didn't try too hard since it seemed they were easy to break.
      If there is a trick I'd love to learn it since I still have two LEDs waiting to be used.
    9. #42
      Junior Member DrFraserCrane's Avatar
      Mar 2016
      Towson, MD
      I removed the clear plastic faces of both the pass. and drivers' side lights, then removed the footwell panel on the passenger side when doing the cabin filer and did the passenger side at that time. The driver's I reached up under the kick panel from the back/pedal side and had enough room to fish the light assembly out. installation was the reverse of removal -- put the assembly back in after leds are in place, then snap the clear plastic faces back on when the assembly is in place
      fiddly and contorted position to do it, but it wasnt too terrible.
    10. #43
      its a bit difficult to understand. is it possible that you can take some photos with explaination?
      that would be very helpful.
      Thanks.
    11. #44
      Mar 2016
      Towson, MD
      I doubt Ill be able to snap any photos any time soon, but maybe this cabin filter thread with photos can offer some help -- you can see the footwell light clearly in many of the photos
      http://forums.swedespeed.com/showthr...er-Replacement
    12. #45
      Thanks. i think i understand now. on the passenger side i need to open the screws and pull the panel down right?
    13. #46
      Mar 2016
      Towson, MD
      I believe so, I do not know how the driver's side releases, but I had enough room to sneak in from the back/pedal side and fish the assembly out
    14. Remove Advertisements
