Cars to flat tow behind a motorhome
    Results 1 to 19 of 19
      Anyone familiar with what cars can be flat towed (all four on the ground) behind a motorhome? My folks are looking for a tow vehicle and apparently not many cars are recommended for flat towing.
      thanks.
      Re: Cars to flat tow behind a motorhome (Chris@Swedespeed)
      Most cars should be towed with the drive wheels off the ground, at least in an ideal world. Most 2WD cars can be flat-towed, but it's not ideal. Flat-towing is a big no-no for vehicles with full-time AWD/4WD.
      Jeeps can be flat towed, as can just about any SUV/truck with a Neutral position on the transfer case. You can tow a FWD or RWD vehicle, but ideally you'd want to disconnect the driveshaft(s) to guarauntee no transmission or differential damage will occur.
      Re: Cars to flat tow behind a motorhome (anony00gt)
      it seems the Saturn and Chevy Lumina are popular choices for flat towing. RWD trucks are not listed as towable but 4WD are. None of the Subarus, Volvos (FWD or AWD).
      My dad is looking to keep the total weight under 5000lbs. With a 2000lb trailer (4 wheels off the ground), the car would have to be under 3000 lbs, tough these days. They plan on traveling out west with hills and the V10 Ford is what he'll have in the motorhome.
      Some light cars that might be fun to do some tootling around in are, Mazda miata, RX-8, Nissan sentra (spec V ), Subie impreza TS and RS are just under 3000, Honda del sol. You never said what the goal was, if they want a small comuter and how much $$$, all of the above are quite reasonable second hand, even RX-8's down there are under 20 now. Mid nineties miata's are cheap.
      2004 V70R, red/atacama with a stick and pretty much totally stock.
    7. #5
      Senior Member JRL's Avatar
      Apr 2003
      Devon PA
      Re: Cars to flat tow behind a motorhome (vintagemilano)
      People DO tow a lot of Saturns.
      Just today saw a Honda Element behind a motor home
      Email: jrl1194(at)aol.com
      If the subject is car purchase related please use jrl1194(at)gmail.com
      2007 V70 2.5T White/Oak 108K miles, new daily driver
      2000 V70R wife's. Won't sell, now near 141,000 miles and still near perfect!
      2000 S70 GLT SE 30,005 MILES, A time capsule! JUST SOLD.
    8. #6
      Re: Cars to flat tow behind a motorhome (JRL)
      Lately i've seen a lot of mobile homes pulling honda accords here through the smokies............
    9. #7
      Re: Cars to flat tow behind a motorhome (Maynard)
      Dad has got bad knees from his time in the military so a low sports car is out, he'd like something sporty but too much of a hassle for him.
      I'll let him know about the Honda Element, that might work, they talked about a small four door pickup.
      thanks.
    10. #8
      Member Our R's Avatar
      Jul 2003
      Minnesota
      Are you sure it wasn't just a flat sided trailer????
      Life's journey is not to arrive at the grave safely in a well preserved body, but rather to slide in sideways, totally worn out, shouting "Holy ****, what a ride!"
    11. #9
      Senior Member 2k2S80t6's Avatar
      Dec 2004
      Center of Democracy
      That explains my sighting yesterday. It was a convoy of 6 RV's. Different manufacturers all towing a Saturn of different models.
    12. #10
      Re: Cars to flat tow behind a motorhome (2k2S80t6)
      I'd get one of them clown car looking things - that Scion that looks like a four door Mini. Seems like a neat car to haul along behind a motorhome...
    13. #11
      Member Wayne T5's Avatar
      Nov 2002
      Russell Twp, OH
      My parents tow a 4WD Mazda automatic pick-up behind their Monaco. He has the drive shaft interlock thingy that allows it to freewheel and a brake buddy to help with stopping. Seems a little heavy to me but they like it. I also see a lot of Saturns being towed and I think there is something unique about their automatic transmissions.
      Past Volvos: '94 854, '99 S70 T5 SE, '99 S70 GLT, '04 S60RM, '12 S60 T5, '13 S60 T5, '15 S60 RD
      Present Garage: '16 MX5 Club, '95 854 T-5R, '05 V70RGT, '15.5 XC60 T6, '16 V60 P*
    14. #12
      Quote, originally posted by vintagemilano »
      It's safe to assume goal is basic transportation while on vacation, nothing more. Subarus and other AWD cars can not be flat-towed. I also don't know how you'd get a front hitch on a Miata or RX-8.
      A Saturn would be an ideal car. The reason 4WD trucks are listed as flat-towable and 2WD trucks aren't, is because the 4WD models usually have a Neutral position on the transfer case for this purpose.
    15. #13
      Quote, originally posted by anony00gt »
      True, from his original post he was also looking for basic transportation that weights less than 3000lbs that could be put on a small four wheels off the ground trailer. In that case all my idea's would have made for fun tooling around.
    16. #14
      Apr 2003
      Devon PA
      Do the Saturn.
      (Happen to have a very nice 97 for sale CHEAP )
      JRL
    17. #15
      Saw an RV flat-towing a Suzuki yesterday on the freeway. I believe it is a late model (Grand) Vitara.
      Freddy
    18. #16
      Senior Member
      Aug 2004
      Temple, Texas, USA
      Re: Cars to flat tow behind a motorhome (radioflyer)
      Last-year Fiero V6 GT.
      George Dill
    19. #17
      Re: Cars to flat tow behind a motorhome (gdill2)
      Just today i saw two motorhomes, both pulling new chevy silverado club cabs.
    20. #18
      Moderator Shomare's Avatar
      Jan 2004
      Fayetteville, NY
      How about a Ford Focus ZX3?
      Reasonably priced car new or used and it's fun to drive.
      Gets decent gas milage and has seating for up to five adults so long as you like each other.
    21. #19
      Moderator nobbe3728's Avatar
      Mar 2005
      Green Bay WI
      Re: Cars to flat tow behind a motorhome (Shomare)
      I have some friends that towed an Acura Integra behind their RV, then upgraded to an RSX S that tows just as well. Be careful with who you have install the towing equipment.
      I have heard many say that Saturns are good for towing, I believe they even come pre fit with some of the towing parts.
    22. Remove Advertisements
