1998 Pewter Silver/Light Taupe V70 AWD - Page 2
    Page 2 of 4 FirstFirst 1 2 3 4 LastLast
    Results 36 to 70 of 113
    1. #36
      May 2014
      Colorado Springs, CO
      I picked up a bunch of parts at the pull and pay. I still need to get a carpet.
      Used Parts I Need (revised)
      o Light in drivers door (purchased)
      o cup holder (purchased)
      o windshield washer Sprayer 99 or newer
      o headlight wiper arms (purchased)
      o taillights
      o plastic under tray
      o alarm horn (purchased)
      o electric fan (purchased)
      o grill (purchased)
      o drivers doors Seal (purchased)
      o roof trim
      o front ash tray (purchased)
      o carpet
      o insulation under rear seat
      o hood insulation (purchased)
      o heater control knob
      o shift knob
      o owners manual (purchased)
      Used upgrade parts
      o '98 16T turbo (purchased)
      o '98 T5 Auto ECU (purchased)
      o fog lights (have everything but the lights themselves)
      o Dash top with center channel speaker (purchased)
      o 901 radio, amp, Dolby processor, wiring
      1998 Volvo V70 AWD
      1984 RX-7 GSL-SE
      1964 Ford Galaxie 500XL 2 dr fastback, 390 thunderbird, auto, AC
      1970 Ford F250 Custom Explorer Camper Special 390/C6
      My Car Blog
      Member JaredR's Avatar
      Jan 2014
      Boston, MA
      Quote Originally Posted by galexie64 View Post
      I'd pick up a '99+ angle flange exhaust housing and dp while you're in there.
    4. #38
      May 2014
      They didn't have any. Also they ruin the dp's because they don't sell the cat so basically they cut it apart with a sawzall.
      Sent from my KFFOWI using Tapatalk
      1998 Volvo V70 AWD
      1984 RX-7 GSL-SE
      My Car Blog
      May 2014
      Quote Originally Posted by ScottishBrick View Post
      Remove the angle gear and replace the collar sleeve/coupler as preventative maintenance and good insurance against a failure destroying the angle gear splines.
      Where is the best place to get the collar sleeve? Are there any seals you recommend changing at the same time?
      1998 Volvo V70 AWD
      1984 RX-7 GSL-SE
      My Car Blog
    7. #40
      May 2014
      I went to the junk yard on Friday and pulled some parts out of two clean V70 XC's.
      What I picked up:
      o taillights
      o roof trim with rails
      o carpet
      o 99-00 passenger side map pocket
      o driver's side front fender
      o painted trim for rear windows (mine had no clear coat)
      o latch phase 1 anchors (Top Tether Straps)
      The one thing I hadn't planned on getting was a full set of seats. After I pilled the carpet out of a really clean car, I took a second look at the seats and realized they looked a ton better than what I had. The seats are a little dry but they are hole and crack free. I've already cleaned and conditioned the seats. I also now have a power passenger seat.
      The drivers seat looks better in person than it looks on in the picture. All the other seats look even better than this.
      I also took a picture of the rear carpet area after cleaning:
      The cleaned headliner:
      1998 Volvo V70 AWD
      1984 RX-7 GSL-SE
      My Car Blog
    8. #41
      Jan 2014
      Boston, MA
      The map pocket isn't exactly plug and play. You'll have to delete the passenger knee bolster to install it. Whether or not this is a safety problem is debatable. I'm not sure UN market cars had it at all; if this is the case, I would be pretty comfortable deleting it.
    9. #42
      May 2014
      Quote Originally Posted by JaredR View Post
      There seems to be quite a few debates on the knee bolster. I really don't care, I'd rather have the map pocket. If it was really a huge safety concern, I doubt Volvo would have added it.
      1998 Volvo V70 AWD
      1984 RX-7 GSL-SE
      My Car Blog
    10. #43
      Jan 2014
      Boston, MA
      ME7 cars don't have the same airbags as m4.x cars. That's why the knee bolster went away. The NHTSA writes the safety reg's under the assumption that the occupants are not wearing seat belts whereas the UN market safety reg's assume that occupants are wearing seat belts. I have a strictly enforced seat belt policy in my cars, so I'd have no issue deleting mine, and probably will if I can figure a way to put a map pocket in an 850.
    11. #44
      May 2014
      Didn't know that, good info. I also have a strictly enforced seat belt policy in my cars.
      1998 Volvo V70 AWD
      1984 RX-7 GSL-SE
      My Car Blog
    12. #45
      May 2014
      I cleaned the new (to me) carpets as well as the rear seat backs and the liftgate. I started the carpet and seat install. The rear seat backs are installed, they really didn't make that easy to do. I also installed the front carpets. I would have had it all back together but I ran out of time.
      I install all the relays, etc associated with the fog lights. The passenger side under dash map pocket is also installed. I probably have about 2-3 hours left to complete the interior. Once I'm done with the interior, I'm going to work my way through the used parts I acquired including the roof rails, front fender, headlights, taillights and grille. Pics to come.
      1998 Volvo V70 AWD
      1984 RX-7 GSL-SE
      My Car Blog
    13. #46
      May 2014
      The replacement carpet and seats are installed. I don't mind sitting in the car now.
      1998 Volvo V70 AWD
      1984 RX-7 GSL-SE
      My Car Blog
    14. #47
      May 2014
      I need to finish up a installing the plastic covers for the front seat bolts and the dead pedal. I would have had it all done if it wasn't for us all getting the flu.
      I'm considering trying to vinyl wrap the dash trim. I figure if I really don't like the look, I could always pick up a set of wood dash trim. All the wood trim in the junk yard has been trashed and I'm not really sure that I'm ambitious enough to pull the entire dash in the junk yard either.
      The two vinyls that I'm considering are either 3M Di-NOC Carbon Fiber or Ebony.
      http://www.topvinylfilms.com/wood-gr...in-wrap-vinyl/
      http://www.topvinylfilms.com/carbon-...er-wrap-vinyl/
      1998 Volvo V70 AWD
      1984 RX-7 GSL-SE
      My Car Blog
    15. #48
      Member SonicBlueR's Avatar
      Jun 2010
      Newtown, CT
      Just have to pull the dash top to get the center one out. The other two pieces take minutes.
      06 Sonic/Nordkap MT SR with 18" Anthracite Pegs |63K Miles
      00 Laser/Charcoal 2 Tone AT VR 16" Anthracite Satellites/ 17" Pegs |201K Miles
      99 S70 N/A
    16. #49
      May 2014
      I'm going to start digging into the car sometime in May. I have to do some work to my old F250 first but once that is done, I'm starting on the V70. First order of business is going to be getting the head pulled so I can have it rebuilt.
      1998 Volvo V70 AWD
      1984 RX-7 GSL-SE
      My Car Blog
    17. #50
      I got mine wrapped by Gatorwraps and I am very satisfied! They have a lot of wraps, with lots of types and colors to choose from. You should also check Gatorprints.
    18. #51
      May 2014
      Thanks for the info
      1998 Volvo V70 AWD
      1984 RX-7 GSL-SE
      My Car Blog
    19. #52
      Member ScottishBrick's Avatar
      Dec 2014
      Connecticut
      Ebony would be nice. What about a Kevlar weave or birch?
      1999 V70 T5 - Emerald/Graphite M56H - 119k - The Garage Queen
      1999 V70 T5 - Pewter/Graphite AW42 - 241k - The Daily
      1995 945 Turbo - 425k, 1994 945 Turbo - 234k, 1993 945 Turbo - 318k
    20. #53
      May 2014
      I messed with the car on Friday. I installed the replacement tail lights and the roof rails. I didn't want them to get broken sitting around my garage.
      I also got the car running so I could move it and my pickup around. I pulled the plugs and gave them a quick clean. Two things were confirmed, the PCV system is clogged and the car is burning coolant. One thing that makes me happy is the motor is firing on all cylinders. I'm also happy that the car went into drive and reverse without a problem but I didn't take the car above 5mph.
      Things observed:
      -There was quite a bit of oil under the spark plug cover including 3 of the plug holes filled with oil.
      -Plugs were very oil fouled.
      -PVC system very clogged, oil was spraying out the oil cap.
      -Coolant cloud out exhaust.
      -Coolant on ground when system pressurized, I didn't have a chance to investigate. I'm sure it is related to the reason the head gasket blew.
      -Turbo is spooling and boosting.
      -Coolant was low and oil is chocolate milk. I already knew this.
      -Car tries to stall at idle.
      -Car has check engine light (obviously).
      -ABS/ Trac lights are on.
      One weird thing that I've never seen before is the hazard switch is jammed and making a horrible noise. At first I thought is was the tape deck because it sounded a little like that but louder. I'm going to try and pull it and see if I can clean it, if not I'll pull one from the junk yard. I'm assuming it can be pulled once the radio is out?
      I have not checked the codes yet, I still need to get a cable for my laptop. Once I get that done, I'll post the list of codes.
      1998 Volvo V70 AWD
      1984 RX-7 GSL-SE
      My Car Blog
    21. #54
      May 2014
      One more question. How do I remove the side molding from the front fender? The replacement fender is from an XC so I need to swap the pewter molding from one fender to the other.
      1998 Volvo V70 AWD
      1984 RX-7 GSL-SE
      My Car Blog
    22. #55
      May 2014
      Picture of the replacement tail lights and roof rack installed:
      Anyone able to answer my questions above?
      1998 Volvo V70 AWD
      1984 RX-7 GSL-SE
      My Car Blog
    23. #56
      Jan 2014
      Boston, MA
      If you are replacing the fenders it's easiest to remove from behind after you get the fender off. 50/50 that you'll break the clips removing from the outside via any method I've found. Maybe someone else has come up with a better way to do it that reduces that probability.
    24. #57
      May 2014
      I am removing the fender so I can pull it while it is off. Is it just held on by those two plastic clips? can I squeeze them from behind?
      1998 Volvo V70 AWD
      1984 RX-7 GSL-SE
      My Car Blog
    25. #58
      Jan 2014
      Boston, MA
      Exactly. It's the best way. Don't squeeze too hard or you'll break them; done that, too........
    26. #59
      May 2014
      Thanks, that is a big help.
      1998 Volvo V70 AWD
      1984 RX-7 GSL-SE
      My Car Blog
    27. #60
      Senior Member JRL's Avatar
      Apr 2003
      Devon PA
      I believe it also has tape but that's so old now, it should pop right off
      Email: jrl1194(at)aol.com
      If the subject is car purchase related please use jrl1194(at)gmail.com
      2007 V70 2.5T White/Oak 108K miles, new daily driver
      2000 V70R wife's. Won't sell, now near 141,000 miles and still near perfect!
      2000 S70 GLT SE 30,005 MILES, A time capsule! JUST SOLD.
    28. #61
      May 2014
      Quote Originally Posted by JRL View Post
      Okay, thanks. So I when I reinstall, I'll get some more. I may have some 3M tape somewhere in the garage already.
      1998 Volvo V70 AWD
      1984 RX-7 GSL-SE
      My Car Blog
    29. #62
      Jan 2014
      Boston, MA
      I've never seen tape behind one of those pieces but all of the ones I recall pulling have been on an 850 so it could be different on the x70s.
    30. #63
      Member beachnut's Avatar
      Jan 2004
      SW Florida
      Probably don't have to say this since you seem to know your way around cars, but I would soak all your head bolts down several times over the course of several days before pulling the head. I broke a bolt on my '98 when I pulled my head and it was not fun, finally got it out of the block though after hours of cursing lol.
      2010 S80 T6 Silver/Anthracite, Odysseus, Dynaudio, Climate, BLIS, PCC, PA 80k
      2004 S80 2.5T Pearl White/Sand, Chrome Tucana, Dynaudio 128k
      2005 S40 T5 Passion Red/Quartz, Serapis, Dynamic Package 77k
      Previous: 2005 S60 T5, 1998 V70 T5, 1996 854 Platinum
    31. #64
      May 2014
      Quote Originally Posted by beachnut View Post
      I was planning an using PB Blaster on everything days before I start taking it about. I've always had luck with it on the old cars. I'm hoping this car doesn't give me too much grief being a Colorado car and not having any corrosion on the motor. I'm not going to get my hopes up though. I'm going to try and be really easy on the head bolts.
      1998 Volvo V70 AWD
      1984 RX-7 GSL-SE
      My Car Blog
    32. #65
      May 2014
      I went to the pull and pay today and I got some good finds.
      -S60R manifold with heat shield
      -sc-901
      -center channel with processor
      -99 side markers with wiring
      -na throttle body
      -hazard switch
      -fog light
      I still need to get an under seat amp with wiring and bracket.
      1998 Volvo V70 AWD
      1984 RX-7 GSL-SE
      My Car Blog
    33. #66
      May 2014
      I picked up the manifold and heat shield for a total of about $30 so I figured I might as well do it.
      They have a '93 850 GLT in the junk yard with a complete motor. I was reading that they have a good cam but I didn't have the time to pull the motor apart and snag them. I'm not sure I would even want to deal with installing them.
      1998 Volvo V70 AWD
      1984 RX-7 GSL-SE
      My Car Blog
    34. #67
    35. #68
      May 2014
      Did you take the dash pad?
      I already had the dash pad that I pulled from another car.
      1998 Volvo V70 AWD
      1984 RX-7 GSL-SE
      My Car Blog
    36. #69
      Apr 2003
      Devon PA
      I could not find a tan speaker when I installed a 901 in my T5M so I painted the black one I bought. It turned out GREAT!
    37. #70
      May 2014
      I picked up a really nice leather wheel at the junk yard and it cleaned up nicely. I also got a set of dynaudio dash speakers.
      I also picked up a 960 throttle plate. Pictured with the na throttle body.
      Sent from my SM-G920V using Tapatalk
      1998 Volvo V70 AWD
      1984 RX-7 GSL-SE
      My Car Blog
    38. Remove Advertisements
