1998 Pewter Silver/Light Taupe V70 AWD - Page 4
    Page 4 of 4 FirstFirst 1 2 3 4
    Results 106 to 113 of 113
    1. #106
      Junior Member Saffron-R's Avatar
      Aug 2008
      Portland, Oregon
      Aren't there "hidden" eq adjustments on the sc 901? Maybe if you can get into that menu you can fine tune the settings for the center channel. I'm not familiar with how to access these menus, though.
      Member ScottishBrick's Avatar
      Dec 2014
      Connecticut
      Quote Originally Posted by Saffron-R View Post
      L and R individual speaker adjustments. I screwed with everything but ended up going back to stock v70 sound stage with rear speakers turned up.
      1999 V70 T5 - Emerald/Graphite M56H - 119k - The Garage Queen
      1999 V70 T5 - Pewter/Graphite AW42 - 241k - The Daily
      1995 945 Turbo - 425k, 1994 945 Turbo - 234k, 1993 945 Turbo - 318k
    4. #108
      Member JaredR's Avatar
      Jan 2014
      Boston, MA
      Quote Originally Posted by ScottishBrick View Post
      It's hard to dial in a custom EQ without getting distortion. Takes a lot of playing with it and I still haven't found one that's completely distortion free on everything I want to listen to.
      Yea that's not the case for me. Tried that, doesn't seem to make much difference. I know that the speaker works, the head unit is functional and the harness has proper power. So weird.
      For anyone who's added a center channel, was your center speaker harness just two wires? Blue and blue with white stripe?
      I wouldn't call mine "quite loud," either. It is loud enough to notice that it is working properly. I should have listened to your system when I was there..............or just bring that car to Mystic if you come by land and we can compare to my T-5R.
      Mine is two functional wires but there is at least one more that has been cut. idk what it is supposed to go to.
      May 2014
      Colorado Springs, CO
      Quote Originally Posted by galexie64 View Post
      I tried to scan for codes using for 1.3 and 1.7 but I couldn't get the cable to connect. I picked up a VAG-COM KKL 409.1 OBD2 serial port cable.
      http://m.ebay.com/itm/KKL-COM-port-R...%257Ciid%253A1
      Am I missing something? Do I need a driver?
      I'm running Windows xp.
      I'm still stuck on this.
      1998 Volvo V70 AWD
      1984 RX-7 GSL-SE
      1964 Ford Galaxie 500XL 2 dr fastback, 390 thunderbird, auto, AC
      1970 Ford F250 Custom Explorer Camper Special 390/C6
      My Car Blog
    7. #110
      Senior Member JRL's Avatar
      Apr 2003
      Devon PA
      Amp and harness for sale in the Classifieds
      Just what you need.
      Try to find the correct speaker harness for the center speaker
      Email: jrl1194(at)aol.com
      If the subject is car purchase related please use jrl1194(at)gmail.com
      2007 V70 2.5T White/Oak 108K miles, new daily driver
      2000 V70R wife's. Won't sell, now near 141,000 miles and still near perfect!
      2000 S70 GLT SE 30,005 MILES, A time capsule! JUST SOLD.
    8. #111
      May 2014
      So I figured the problem out with the scan program. When I reinstalled the center console, I forgot to plug the port back in. I try not to make dumb mistakes like that.
      I also installed the amp and the radio is now working great.
      1998 Volvo V70 AWD
      1984 RX-7 GSL-SE
      My Car Blog
    9. #112
      May 2014
      List on codes:
      GAL-610
      ECC-322
      ECC-414
      CI-113
      CI-211
      ABS-433
      AT-232
      EFI-121
      EFI-666
      1998 Volvo V70 AWD
      1984 RX-7 GSL-SE
      My Car Blog
    10. #113
      May 2014
      Not a Volvo but I did some work on my old pickup so I can get ready to sell it. The motor runs great but it leaked oil and looked bad. I pulled the valve covers and intake to take care of the oil leaks. I still need to reseal and paint the oil pan, replace the plugs and points.
      Before:
      After:
      1998 Volvo V70 AWD
      1984 RX-7 GSL-SE
      My Car Blog
    11. Remove Advertisements
