Another axle question - Page 2
    Page 2 of 2 FirstFirst 1 2
    Results 36 to 46 of 46
    1. #36
      Member GRat9717's Avatar
      Jan 2013
      NJ, USA
      Quote Originally Posted by mercdude View Post
      Btw, when you buy 'new' OEM axles, they are also remanufactured.
      I'm not sure this always true if you go the dealer route. Also, they're the same cost or less than other sources.
      Garage Queen - 2010 C30 R-Design Vrooooooom
      Daily - 2016 V60 T5 Drive-E Vrooooooom
      Zichrona Livracha - 2004.5 S40 T5
      Jan 2009
      Breckenridge
      Well, yes, that is what i was thinking (the reason i said the rear driveshaft is spinning but not being driven, I just didn't say it as clearly as you did- and it's ability to take some acceleration front the front therefore masking a CV issue). We're on the same page.
      my concern is i replaced both CV, and have no play (old RF had lots of looseness and LF had a dead boot). Regardless, I had vibration before replacing my CV with the Heri units, so I'm not sure if it's worth it to rebuild what i took out. I don't know if the previous owner replaced the CVs, (in which case i'd be rebuilding some other version of a cheap aftermarket) or if my OEM have 182k on them and might be beyond the point of rebuilding. I feel all my vibration in the wheel, with only a little in the chassis.
      2005 v50 T5 AWD M66
    4. #38
      Member T501's Avatar
      Mar 2005
      Florida
      OEM axles should have a white label with the manufacturer's logo "GKN" printed on it.
      David - '01 S60 T5 GT 177K+ miles OWNED SINCE DAY ONE - Bilstein Sport + TME, ipd sway bar + endlinks, UR chassis braces (upper F+R), Powerslot /Akebono pads, Snabb Intake, HD coils, iMIV Original engine, transmission replaced at 79k miles
      Wife -'13 C30 T5 R-Design Dad - '98 S70 T5 160K + miles, Bilstein TCs, IPD HD rear springs, SAS delete Mom -'10 S80 V8 Executive Sis - '02 S80 T6 Backup car -'13 S60 T5
      Oct 2010
      Olympia, WA
      Wait, so GKN was the OEM manufacturer? Because for my 2006 FWD auto, I can buy GKN axles pretty easily: https://www.eeuroparts.com/Parts/161...de-New-304743/
      They can be had for less elsewhere, $175 range.
      If this is the case, HECK YEAH. Daddy needs new axles, the boots are done on mine.
      2006 Volvo V50 T5 FWD - My first Volvo
      2000 V70XC - dear god what a mess
      1999 S70 GLT - work in progress
    7. #40
      Jan 2013
      NJ, USA
      Quote Originally Posted by leroy_sunset View Post
      Not bad if true. Looks like all FCP sells for the P1 are re-manufactured axles - even Volvo branded ones. It wouldn't hurt to try GKN.
      Looking at prices on FCP or other sites I am amazed. I got my set of axles from the dealer brand new for around $900 for the pair. I still have receipts somewhere... Maybe the higher price is factoring in the core charge they don't look forward to getting back?
    8. #41
      Mar 2005
      Florida
      Yes GKN is the manufacturer of Volvo axles. Let us know if the parts match up exactly or not. It's kind of strange that the picture shown on e-europarts doesn't have a balancer on the shaft like the Volvo axles do but it could just be a generic axle picture.
    9. #42
      Jan 2013
      NJ, USA
      Quote Originally Posted by T501 View Post
      Cool and yep, probably a stock photo.
    10. #43
      Jan 2017
      Central Valley, CA
      So the manual and auto driveshafts are the same? I'm trying to get my driver CV axle replaced but there's 2 choices; one with 26 splines on the brake disc and one with 36 slides on the same side as well. Are surtrack or a1 cardone reliable brands?
    11. #44
      Member
      Dec 2013
      Northern CA
      ^ NO, they are not. And, the right side awd axles are different than their manual/auto counterparts. But the left side appears to be the same regardless of awd or not.
      2005 V50 T5 AWD M66
    12. #45
      Jan 2017
      Central Valley, CA
      very intersting, that will dramatically cut down on my searching
    13. #46
      Member
      Dec 2013
      Northern CA
      Since you're close-ish to Sac, I would recommend contacting Volvo and Saab auto wreckers. They have low mileage oem axles that will cost you around $120 OTD.
      2005 V50 T5 AWD M66
    14. Remove Advertisements
