Indicator LED In The Vehicle's Charging Socket Does Not Light Up
    Results 1 to 5 of 5
      Junior Member RayD's Avatar
      Mar 2002
      South Florida
      Hello swedespeed,
      I recently purchased a 2017 XC90 T8. All is well with the following exception: the LED indicator light located in the vehicle's charging socket never lights up while charging or when charging is completed (nor does it light up when unlocking the vehicle). Also, when plugging in the charging cable, the XC90 does not lock it's doors; after about 5 minutes or so, I manually lock the doors.
      The instrument panel and the charging cable's indicator both light up during charging. While I don't think there is anything serious going on, I am curious to know why the LED indicator light located in the vehicle's charging socket never lights up. Has anyone else observed these conditions? Any suggestions/recommendations in regards are greatly appreciated?
      I am using the TurboCord that was supplied with my XC90; it is plugged into a 6-20R 240 volt outlet.
      Junior Member bren213's Avatar
      Jan 2016
      Southern California
      Quote Originally Posted by RayD View Post
      Hello swedespeed,
      Never seen that before (and I'm on my 2nd T8 now)... I would recommend taking it in for service.
      Member phillipu's Avatar
      Nov 2016
      United States
      Hello swedespeed,
      My T8 does not lock its doors automatically when charging either. I think this is normal, but there should be lights in the charging port indicating status. Sounds like you need it serviced.
      Junior Member tillsbury's Avatar
      May 2016
      New Zealand
      No, the doors don't lock when you plug the charger in. The charger cable itself locks (so you can't remove it). The doors are up to you. However, the charger cable can only be removed for a few seconds after you unlock the car. Thus, if you're using the sport key, you need to lock and then unlock the doors to release the charger (if you left the doors open).
    7. #5
      Global Moderator GrecianVolvo's Avatar
      Nov 2001
      Southern California
      Quote Originally Posted by tillsbury View Post
      Exactly.
      2001 Volvo V70 T5 M SR, Classic Red/Graphite Lthr, TME Stage II ECU, 3" Downpipe w/ Cat-back exhaust from MTE, Volvo Roadholding & Lowering Kit w/ Nivomats, 17" PEGASUS, Rear Spoiler, Dolby Surround Sound
      2016 V60 Polestar Electric Silver
    8. Remove Advertisements
