Just bought a 2001 V70 for $400 - Page 3
    Page 3 of 3 FirstFirst 1 2 3
    Results 71 to 94 of 94
    1. #71
      Member MadeInJapan's Avatar
      Aug 2003
      Knoxville, TN
      I have 2 of the outside part of the inside door grab handles in fair shape. PM me your address and I'll send them to you.
      I haven't heard much about transmission issues or any shifting tails at all but make sure you put the right fluid in it...has to be JWS-3309 compliant. Cheapest may be Mobil-1 but you can also use Toyota Type IV (they're the same thing). I would not trust any of the "for all transmissions" type fluid at all! Also considering the miles on the tranny, I would not do any power flushing at all...personally I would do several drain and fills but there are differing opinions on how to replace the fluid that's already in there.
      -MIJ
      '98 S70 T5 Emerald Green IPD and other Upgrades/ '07 S40 T5 M-66 MT Mystic Silver Metallic, Heico Sports Suspension & Cone Air Filter, OZ 18" Wheels, Elevate Dual Exhaust Intake Manifold BOV & Stage 1 Tune, 27mm Racing Beat Rear Sway, Proforged Rear End Links, Ultra Racing Strut Tower brace & E-Focus Mount/ '04 V70 2.5T Ruby Red - IPD Upgrades (wife's car)/ '07 S60 2.5T Barrent Blue (son's car) All: Mobil-1 synthetic @ 5K miles.
      Feb 2017
      Floriduh
      Okay. I'm kinda frustrated RN.
      I've been having some throttle response issues since I bought Project LongRüf, and I can't seem to make a dent in it(so to speak).
      Car starts on the first crank, runs quiet and smooth. No stumbling at idle or stalling issues. But. While idling in P, the throttle response is mushy. Blipping the throttle results in a lazy acceleration, and I can't get it to rev above 2500. I disconnected the MAF sensor recently to see if that would temporarily resolve the issue. No real change except I got the CEL to light up and an Emissions msg on the panel. So I plugged it back in and moved on to other parts of the project. Next time I started it up, the throttle response was spot on. Revved strong all the way thru the powerband. Figured it was the MAF sensor. Moved on to other parts of the project.
      Fast forward to Yesterday
      In an effort to not spend $100 every time I buy stuff, I spent $5 on some CRC MAF cleaner. Pulled the MAF out, and hit it a bunch with the spray. Let it sit for a few hours, just to make sure it dried thoroughly. Plugged everything back in and still craptastic throttle response.
      Currantly The car's only throwing 1 msg on the panel(airbag) and the SERVICE light lights up for a short time after starting the car then goes out. Oil level is spot on, coolant level is spot on. AC blows cold, heat blows hot.
      Before I get into replacing the ETM(lots of $$$), I'm going to look at spark/fuel delivery.
      When I got the car the tank was basically empty so I poured abt 5gal of regular gas in it. After doing some internet research, I read that I should use 91 or better. Also that the fuel filter should be replaced at about half the miles the car currently has.
      All things being equal, if the plugs and coil packs are OK, and the filter isn't super gummed up, it may be just a matter of the computer retarding the spark to avoid knock which could (partially, at least) be a cause of my crappy throttle response.
      Thinking back now, I remember my first cross country road trip in my 81 Toyota Celica Sunchaser. I was on a Native American reservation in SD and NEEDED fuel. Only gas was 85 octane. I normally ran 87. The car ran like absolute **** till i was able to get some 91/93 to dilute the 85 and bring the overall octane rating back up.
      So here's hoping it's just cheap gas. I doubt that's the who;e solution, but it may be a big part of it. *fingers crossed
    4. #73
      Member ZZZZZZZ's Avatar
      Aug 2005
      Northern MD
      Throw in some additive and let it run with that mixed in. Those bump octane up don't they?
      Can you get an CAM2 racing fuel? Let it run for a bit, and burn some of that tank down.
      Quote Originally Posted by L. Chupacabra View Post
      My initials - IPD - ZZZZZZZ's thread
      Now: 2007 vRgt, red & gobi - 2005 s60 2.5t AWD, silver & tan - 2002 xc70, silver & black
      Past: 1999 v70, tropic blue/green & oak and Mom started this in 1975 with a 1974 164e, maroon & maroon
      Feb 2017
      Floriduh
      Quote Originally Posted by MadeInJapan View Post
      -MIJ
      LOL been doing a BUNCH of part number crossreferencing lately. Yeah, the toyota stuff is SIGNIFICANTLY cheaper than Mobil 1 or the Volvo branded stuff. All I'm gonna do is drain it, measure what comes out, and replace with the same amount. A full on flush might have some bad side effects. At least it did on my old 75 Caprice I had in HS. Not quite an apples to oranges comparison, maybe an apples to pears, if you follow. I'll drop you a PM. Thanks. That's much appreciated. Bonus points if they're not beige. It all of a sudden seems like I'm trying(not on purpose) to have trim of a bunch of different colors.
    7. #75
      Junior Member rich1068's Avatar
      Apr 2015
      UK
      Throttle body clean? Swine to get to but our V70 runs much better for it.
      2005 Volvo V70 2.5T SE AWD
      2014 Volvo XC90 D5 Executive
    8. #76
      Feb 2017
      Floriduh
      Quote Originally Posted by rich1068 View Post
      on my list.
      I have a sneaking suspicion the tweeker I got it from prob never ran 91 or better. So, crap gas, (probably) old/fouled plugs, (probably) gummed up injectors, and a general laissez-faire attitude towards maintenance along with an old MAF sensor are to blame.
      I figure if I drop $100 to do a fuel/spark delivery tune up and it improves the issue a little is money I can part with.
      I'm basically trying to do everything BUT an ETM.
      Also a neighbor has a similar vintage S80 auto with an exhaust leak for sale. So there's that. Someone please talk me off that ledge.
    9. #77
      Feb 2017
      Floriduh
      All Righty Then
      Picked up some 108 octane booster, 5gal of 93 and 5 new Bosch Dbl Plat plugs.
      Also there's apparently a leak in my windshield washer tank on my Jeep.
    10. #78
      Feb 2017
      Floriduh
      Welp.
      Changed the plugs. Used Bosch Dbl plat. The old plugs were Autolite platinum. At least they were platinum plugs.
      All 5 looked the same.
      And of course the coil boot on cyl2 was boogered. Just gonna pick up a whole coil pack cuz it includes the boot.
      And the windshield washer pump on my Jeep is shot. Luckily I've done this before. it'll take me longer to get to the store than to actually change it out.
    11. #79
      Feb 2017
      Floriduh
      And of course I moved the wagon into pretty much the exact middle of my driveway so I'd have room to wrench. And now that it's immobile...
      oh well. Looks like I'm off to Autozone AGAIN
    12. #80
      Aug 2005
      Northern MD
      Uber!
    13. #81
      Feb 2017
      Floriduh
      a. F#$% Uber
      b. I'll just drive my DD
    14. #82
      Aug 2005
      Northern MD
      I have never used it.
      I'd assumed the middle of the dw meant the other car couldn't get out.
      Progress? Does it rev normally now?
      a. F#$% Uber
    15. #83
      Junior Member TrstnBrtt's Avatar
      Oct 2013
      Vancouver, BC
      [QUOTE=rich1068;5153489]Odd. I've just looked on our V70 and I've got one too, never noticed it before. Just covered with a blanking plate. Could be for one of those roof mounted screens maybe? Or on my '14 XC90 there's some sort of alarm sensor cluster or somesuch. Could be movement sensor?
      It's an alarm module of sorts. Part number 8622636
    16. #84
      Welp.
      so terrible.
      and nice photobucket username.
    17. #85
      Feb 2017
      Floriduh
      Status Update
      108 octane booster and 5 gal 93 dumped in the tank. New plugs, #2 coil. Still starts up just fine, and idles fine. Throttle response is a little better and I can get it to rev to 3k now. and it would sit at 3k then vroom up to about 6k. So I figure the "tune up" had an effect. Granted I only ran it for about 5mins. Gonna start it up today and let it run for a good while to try to get everything circulated.
      Next option is new fuel filter and MAF sensor. I can with certainty say the fuel filter has never been replaced.
      I think cleaning the MAF sensor helped, but with a bit over 200k on the clock, it just needs to be replaced as well.
      Bought some Plastidip to touch up the grille, and also sprayed a section of bumper molding just to see how it looks.
      Still gotta get some trim rivets for the top of the bumper and slap on the lower air dam.
      Might swing by the local indie shop on my lunch break, get some info, and maybe ride it dirty down there some time before dawn next week just to get it plugged in and get some definitive answers.
      And I keep forgetting to get a few of those funky festoon style dome light bulbs.
      So once all that's done I can move on to suspension/brakes/tires.
      Still need to find another 15" wheel, either a steelie or similar to what are on the car to use as a full size spare.
      And the windshield washer pump was $17 from Autozone. So now I can see thru the Jeep windshield again.
    18. #86
      Oct 2014
      Seneca SC USA
      Here are my thoughts as a fellow 2001 XC owner. Sorry if I missed some posts, I only skimmed through.
      1) ETM: There is no way in hell you are going to avoid replacing this. The issue is not that they get gunked up. The issue is that the throttle position sensor uses a resistive wiper to sense position, and this wears out over time. Even if you buy a new one, it will fail in the exact same way. To me, the ONLY thing to do here is replace it with the Xemodex rebuild that uses a magnetic TP sensor. This is what is causing your throttle issues. You're just throwing darts at it with the MAF stuff.
      2) While you have the intake off to replace the ETM, also do the PVC system, as it is mounted on the bottom of the block below the ETM and is impossible to get to without removing the intake and ETM. The PVC system eventually clogs (and with 200K, yours is clogged) and it ends up filling the plug wells with oil, among other things.
      3) The engine should not exceed 4k while in park. At least, mine appears to have a rev limiter in park.
      4) 87 octane (US) fuel is FINE for the 2.4 Turbo. The manual calls for 87 AKI, which is what is printed on US gas pumps (the average of RON and MON). In areas where RON is printed on pumps (Europe), the minimum is 91.
      5) Congrats on your purchase! I love my V70 X/C and though it may now have died, I will certainly look for another one.
      Engineer, Cyclist, Pilot, Geek
      eric(dot)hidle(at)gmail
      2001 V70 X/C, 2005 XC90 T6, 2002 V70
    19. #87
      Member Antherzoll's Avatar
      Dec 2013
      Toronto, Ontario, Canada
      Quote Originally Posted by ehidle View Post
      Impossible you say
      http://forums.swedespeed.com/showthread.php?p=3715321
      2005 XC70 Crystal Green | Hilton | 16T | 110k mi
    20. #88
      Feb 2017
      Floriduh
      Appreciate the advice, but-
      1. Non-turbo, base V70
      2. Owner's manual says 91 octane
      3. Yeah, I'm throwing darts, but I'm going to rule out the simple stuff before I throw a bunch of money at what may or may not be the issue. I know the ETMs fail on the regular but since I'm not experiencing and stumbling, stalling or other textbook symptoms, I'll leave that as a last resort.
    21. #89
      Feb 2017
      Floriduh
      Status Update:
      Project LongRüf is on a bit of a hiatus as now that spring is here in FL. Yardwork is probably my least favorite thing to do, and when the weather gets warm around here EVERYTHING grows at a significant fraction of the speed of light. All that brush you cleared and pruned back in Feb? LOL. Didn't I just mow my lawn 3 days ago? LOL.
      BUT- somehow the sunroof started working again. I started the wagon up a few days ago to let it run and get the juices flowing, rolled down the windows to let that horrible air-freshener smell dissipate, and just pushed the sunroof button on a whim. HOLY CRAP! I about peed myself when it started moving. Then it made a bad noise and wouldn't move. And of course it was open more than where it was.
      Then yesterday, I started it up to move it and hit the sunroof button again. HOLY CRAP! This time I had enough presence of mind to get it closed.
      Remember when your parents told you not to do something and you wanted to do that more than anything? Yeah. That's me wanting to play with the sunroof.
      But for right now it's closed, and I'm super stoked.
      The wagon is starting to remind me of my old 78 Buick I owned in HS. It had what my GF at the time called "character". Lots of "Will this part work today?" type stuff going on. At least it's nowhere near the "character" my other cars had.
      MG, Fiat X/19, Alfa Spider, and BMW 2002. Good lord those cars were characterful. I almost forgot the 75 Caprice that was basically held together by the paint and my sheer willpower. God I loved those cars.
      please don't show me cool/neato oddball Italian coupes for sale. They're basically Kryptonite to me.
    22. #90
      Apr 2015
      UK
      I recently enjoyed reading this. Particularly the comments.
    23. #91
      Feb 2017
      Floriduh
      Yeah that made me smile when it popped up in my twitter feed. Just nice to know I'm not alone and other people proudly share my disorder
    24. #92
      Aug 2005
      Northern MD
      Good read, LC. Got a good laugh.
      https://youtu.be/h4UqMyldS7Q
      Status Update:
    25. #93
      YIKES. I really want an '82 bosch L Spider, but then these threads keep on popping up.
    26. #94
      Apr 2015
      UK
      Jalopnik is good for this stuff. I enjoyed their bit about Spitfires too http://thegarage.jalopnik.com/heres-...h-s-1794326920 Though being British none of that surprised me. I lived through the dark days But none of that would worry me about a Triumph because as they point out, the cars are so basic. Unlike the Italians they never thought "Hey, let's do this in a completely different way to every car manufacturer on the planet."
    27. Remove Advertisements
