OEM rim from 2004 xc70 2.5T fit on a 2014 XC70 T6 ?
    Results 1 to 2 of 2
      Hi
      Anyone know if i can fit an OEM rim from my 2004 xc70 2.5T on a new-to-me 2014 XC70 T6?
      I've already figured out that i would need a ring to adjust hub bore from 65.1 to 63.4. I was wondering whether there will be an issue with the rim fitting over calibers etc. Tirerack shows 16" rim options for the T6, so i want to assume it will fit, but hoping someone has already "broke trail" on this..
      Thanks in advance
      Eric
      Member Penguin's Avatar
      May 2006
      Reno, NV
      You are correct about the differences in center bore and the need for an adapter ring. There is only 1 mm difference in offset between the models so there should not be a problem with the earlier model wheel fitting over the calipers.
      2015.5 V60 Polestar BSM #46 (SOLD)
      2014 XC60 R-Design Passion Red/Off Black, OSD, Savini BM7, lowered, swaybar, Koni FSD
      2006 V70R 6M
      ElecSilver/Nordkap, 18" Pegs, Bell FMIC
      2004 S60R 6M TiGrey/Nordkap, 18" Ti Pegs, Bell FMIC, IPD Stage II, Eibachs, Quaife LSD
    4. Remove Advertisements
