XC90 transmission
    Results 1 to 8 of 8
      Junior Member Magnus Cars's Avatar
      Sep 2015
      Wasington D.C.
      XC90 transmission
      I have 3 questions.
      1: How much power can the XC90 V8 Tranmissions take?
      2: Would it not be impossible to put the XC60 turbo in my XC90?
      3: How much WHP does the V8s make?
      Thanks
      2011 Volvo XC90 V8 AWD Executive. Electric Silver, It's Bone STOCK!!!!
      2011 Volvo XC60 T6 AWD Inscription. Electric Silver, Bone STOCK Too!!!!
      My Instagram: https://www.instagram.com/magnus_cars/
      Junior Member V50R's Avatar
      Nov 2014
      Rochester Hills MI
      I think the following.
      1. They say its rated for 325lb.ft of torque.
      2. By the Turbo do you mean the T6 or the T5? If so the XC90 did come wiht a 2.5L T5 so a swap can be possible. Not sure if the P3 will swap into P2 electronics wise though.
      3. General rule of thumb 18-20% Drivetrain loss... so 311hp (20% loss) = 248AWHP.
      2006 V50 T5 AWD AW55, 320mm FR Brake upgrade, Elevate Intake, OBX Exhaust.
      2010 XC90 V8 Executive Latest Addition.
      2008 XC90 V8 Executive Edition, w/Muffler Delete.
      2005 XC90 V8 Black, VB replaced, S60R Brake Swaped
      2013 Jetta Sportwagen TDI 6spd. Malone S2 tuned 200hp/350tq.
      Sep 2015
      Wasington D.C.
      Quote Originally Posted by V50R View Post
      Thanks, but most cars I thought could have more power(Because my friend have a ls swapped 944 and hes running 400 whp and thats all the trans can take.)
      While this isn't an xc90, it should be fairly close. http://rototest-research.eu/popup/pe...p?ChartsID=622
      2010 s80 v8 magic blue
    7. #5
      Quote Originally Posted by Magnus Cars View Post
      Transmission torque handling varies, especially automatics some stock manual Getrag BMW transmissions can handle a ton of torque - I've seen e36's with 500 RWHP and the stock 5 speed, they are tough ... can't say the same for the XC90 V8 tranny, it's right at its peak torque handling and is known to be a weak link in the XC90 drive train
    8. #6
      Nov 2014
      Rochester Hills MI
      Quote Originally Posted by 10v8 View Post
      So according to this article, the XC90 V8 makes around 269hp and 287lb.ft of torque.
      If we go back and calculate that it appears that the engine makes around 333hp not 311.... HA! SHOCKER!
      http://www.mk5cortinaestate.co.uk/calculator4.php
    9. #7
      Sep 2015
      Wasington D.C.
      Another car that has lied about its power lol
    10. #8
      Junior Member Jersey John's Avatar
      Jul 2010
      New Jersey
      I have 3 questions.
      Thanks
      I've asked the same question to Volvo techs and one answer I got was that the engine wouldn't fit in the compartment. Even though the trans is the same and the block is the same as the 3.2, I was told the turbo engine wouldn't fit.
      I wanted to know because I ended up replacing the engine in my 3.2 due to a mysterious oil consumption issue.
      If winning isn't everything, then why keep score?
    11. Remove Advertisements
