Urgent: need help removing lug bolts 05 V50
    Results 1 to 20 of 20
      Sep 2015
      Ohio
      Working on swapping rear brakes. Most of the 19mm lugs come off no problem, but a few on each axle seem swollen. Tried to lightly pound the socket on one, but it started to warp when I turned it. Any ideas?!
      Sent from my Pixel using Tapatalk
      06 V70R Magic Blue
      Junior Member RYJS60's Avatar
      Sep 2015
      US
      Heat it up if you can using a torch. very carefully
      Sep 2015
      Ohio
      Soaked them all down heavily with Seafoam Deep Creep. Apparently there is an outer chrome shealth that eventually broke loose. Back in action.
      06 V70R Magic Blue
      Sep 2015
      Ohio
      Is there a cover on these that needs to come off before removing the lug?
      06 V70R Magic Blue
    7. #5
      Member GRat9717's Avatar
      Jan 2013
      NJ, USA
      Quote Originally Posted by komatiite View Post
      Only on newer Volvos. The lug nuts that Volvo put on the P1s are two (one) piece.
      Garage Queen - 2010 C30 R-Design Vrooooooom
      Daily - 2016 V60 T5 Drive-E Vrooooooom
      Zichrona Livracha - 2004.5 S40 T5
    8. #6
      They are 2 piece nuts, with a cap over the nut. You can pry it off carefully and use probably an 18mm to get it off. I would replace with 1 piece lug nuts, but the caps aren't essential for reassembly or anything.
      Sent from my HTC M9 using Tapatalk
    9. #7
      Sep 2015
      Ohio
      Quote Originally Posted by Ou2mame View Post
      Something like this perhaps? http://www.ebay.com/itm/20-Lug-Nuts-...tWq-rm&vxp=mtr
      06 V70R Magic Blue
    10. #8
      Jan 2013
      NJ, USA
      Yeah, but don't go so cheap. Look for McGuard or Gorilla. I wouldn't put 14$ nuts on any wheels (or aluminum nuts).
    11. #9
      Sep 2015
      Ohio
      What size are they? 12x1.5?
      06 V70R Magic Blue
    12. #10
      Jan 2013
      NJ, USA
      Bingo.
    13. #11
      I've used the ebay lugs before.. Had them on my audi, xc90, jeep, s40.. Never had an issue. The only issue is with them getting surface rust on them so I just give them a good polish with some chrome polish and they're good to go.
    14. #12
      Jan 2013
      NJ, USA
      I'd spend the extra so I don't have extra work to put on my list
    15. #13
      Sep 2015
      Ohio
      I've seen a few different types of 12x1.5 with different size flanged ends. Is there a certain type that will fit the factory rims?
      06 V70R Magic Blue
    16. #14
      Jan 2013
      NJ, USA
      60 degree conical/acorn style seat, non-tuner - should work. Someone correct me if I'm wrong.
    17. #15
      Junior Member Raphmass24's Avatar
      May 2015
      Canada , quebec
      Quote Originally Posted by GRat9717 View Post
      It'S 60 degree conical indeed. The problem I found when I was looking for replacement nut is not the angle but the diameter of the cone that is much bigger on our OEM than any aftermarket nuts I found. The only alternative that I found was DORMAN 611307 but they weren't very cheaper than the OEM ones.
      If anybody finds a good suitable cheap replacement I'd be interested to know.
    18. #16
      Sep 2015
      Ohio
      Quote Originally Posted by Raphmass24 View Post
      regarding the diameter, is this for aesthetics, or will it just not fit within the rim hole?
      06 V70R Magic Blue
    19. #17
      Sep 2015
      Ohio
      FCP has several 12x1.5 lugs. some on-sale this week, although its still like $65 for a full set: https://www.fcpeuro.com/products/vol...g-nut-31329645
      06 V70R Magic Blue
    20. #18
      May 2015
      Canada , quebec
      From what I've tested they will fit but barely. I mean that the cone will be seated on a small part of the rim cone that is very thin. It seemed sketchy to me at the time.
    21. #19
      Sep 2015
      Ohio
      I found a used set of 12x1.5 Gorilla lugs for pretty cheap. I'm hoping they will work.
      06 V70R Magic Blue
    22. #20
      May 2015
      Canada , quebec
      Yes keep us updated and post pics please!
    23. Remove Advertisements
