2002 S60 T5M Baltimore, MD
    Results 1 to 6 of 6
      2002 Volvo S60 T5 Manual Sedan
      Mileage: ~141,000
      2.3-liter turbocharged five-cylinder engine
      M56 five-speed manual transmission
      $5,500
      Call/text 410-245-3811
      Baltimore, MD
      https://www.flickr.com/gp/152324875@N04/4JUoN2
      Long time lurker and follower. I owe many of you a beer for the helpful threads over the years. Works says I need a car
      2002 Volvo S60 T5 Manual Sedan Mistral Green. I purchased this car in March of 2013 from previous owner with ~83K miles, the car was garage kept with all scheduled maintenance performed at Keystone Motors until 66,042 miles. Since then, all required maintenance has been completed with routine oil changes every 5,000 miles with premium synthetic oil. Car has also been tastefully modified to improve handling and performance, details below. Mechanically car is in excellent condition. Exterior is in above average condition for the year with some scratches on corners as noted in pictures. Interior is in very good condition for model year of this car, no rips in leather, even the center cup holder flap functions. There are no warning lights; all electric windows, seats, seat warmers, sunroof work perfectly. Clutch is strong with zero slippage. Car is ready to be picked up and driven anywhere. This car has been my daily driver with a 180-mile daily commute for the last 6 months and it has performed flawlessly.
      Car comes with binder of maintenance and modifications. Also original owners manual and service records book. All Maintenance and performance parts are OEM or Better!
      Clean AutoCheck vehicle history report from 2/28/17
      Engine
      Volvo timing belt & water pump Kit OEM (Tensioner and idler pulley included)
      IPD PCV Kit- flame trap / crank case ventilation system
      IPD Poly engine mounts
      IPD poly lower transmission bushings
      SNAAB turbo intake pipe
      OBX downpipe
      Hinton Stage 1 Tune
      Suspension
      Bilstein HD Front Struts- Lowered Height Cars
      Bilstein HD Rear Shocks- Lowered Height Cars
      Eibach Sport Lowering Springs Set
      IPD Anti-Sway Bar Kit
      IPD Rear Adjustable Toe Links
      OEM Volvo Shock Mount- Rear
      OEM Volvo Control Arm Kit- Front
      OEM Volvo inner & outer tie rod ends
      Lemforder Ball Joints
      OEM Suspension Stabilizer Bar Link – Front
      OEM Suspension Stabilizer Bar Link Kit- Rear
      OEM Volvo Upper Strut Mount Bearing
      Xc90 Upper Spring Seat
      SKF (Volvo Original Equipment) Front Wheel Bearings
      ^ @106K All suspension front and rear was completely refreshed down to the last nut and bolt with OEM/Lemforder or better components. All receipts/ records in maintenance binder.
      Transmission
      SNAAB Short Shift Kit (shifter is very stiff, clicks in and out of gear but can be tricky at first. Can be adjusted or set back to stock.)
      Delrin Bushings to Firm up Shift Gates
      TWM weighted shift knob
      Brakes (all brake work done @141K)
      IPD stainless steel brake hose kit IPD
      Replaced Front Rotors and Pads (3/12/17)
      Chassis
      Ultra Racing Upper/Lower Front & Rear Chassis Brace
      IPD Strut Bar Conversion
      IPD Sub Frame Bushing Poly Insert
      Interior
      GROM USB3 Android/iPhone Adapter Kit with Bluetooth
      IPD Boost Gauge & Pod Kit
      Door Lock Pin & Bezel Set – Silver
      Black Molded Front Floor Mats
      Pop Out Dash Cup Holder
      Custom fit Neoprene Wet Okole Front Seat Covers
      Exterior
      Projector Style Headlights with R8 Style Daylight Running Lights
      “Tethy” wheels professionally painted satin black
      *Additional very clean set of “Amalthea” wheels currently plastic dipped black (will peal off easily) for second set of tires
      Tires
      Sumitumo HTRZ III – Max Performance summer (8k miles)
      S60 T5M
      Bilstein SP, Eibach lowering springs, IPD Sways, Upper/lower/front/rear ultra chassis braces, IPD Tune, Snabb Inlet hose, VIVA short shift kit and Delrin bushing kit.
      $4,500 obo
      S60 T5M
      Feb 2009
      Dead Center, CA
      Is this still available?
      Sure is
      S60 T5M
    7. #5
      Feb 2009
      Dead Center, CA
      Great. Thank you. I'm helping a friend find a car, so i'll send this to her.
    8. #6
      Still available
      $4,250
      Very well sorted car, ready for a new home.
      S60 T5M
    9. Remove Advertisements
