Power Steering Pump options on 2005 V8
    Results 1 to 9 of 9
      My pump is starting to whine and lose fluid, so I'm looking to replace it this weekend.
      I'm finding conflicting reports about which pumps fit.
      Some places say the 2.5 and V8 will fit the same pump; others say not.
      (http://www.partsgeek.com/gbproducts/...ad=47584901292)
      Any help appreciated before I pull the trigger on a pump that doesn't fit.
      Matt
      2005 XC90 V8
      2006 Volvo S60R - 6MT
      2012 Volvo XC60 T6 R-Design
      1993 S13 - 2JZGTE, 600rwhp
      Aug 2012
      Edmonton, AB, Canada
      Make sure it's not just the hose.
      2006 XC90 V8
      Quote Originally Posted by nascenta View Post
      No, it's the pump w/ pulley. But I'm concerned about fitment. I need help clarifying this.
      Matt
      2005 XC90 V8
      Junior Member alexpa's Avatar
      Feb 2014
      Panama
      The V8 pump p/n is 36000748.
      It's only listed to fit the V8 XC90s.
      2013 Ice White XC90 2.5T AWD R Design w/Polestar Optimization-The Family Hauler
      2013 Passion Red S60 T6 AWD R Design
      2011 VW Tiguan 2.0T 4Motion Tiptronic - APR Stage 2 "The Grocery Getter"
      2003 Nissan Patrol TD42 - AXT Turbo Kit, ARB Lockers, 5" Lift, 35s... Too many mods to list anywhere
    7. #5
      May 2016
      Virginia
      I may have to do this on my '06. I would very much appreciate if you could take a few pics during the process!
      2006 XC90 V8 - 130k miles
    8. #6
      Quote Originally Posted by jimmybionic View Post
      Sure thing. Not a problem.
      Matt
      2005 XC90 V8
    9. #7
      Member ggleavitt's Avatar
      Jun 2005
      Seattle
      The V8 PS pump is made by Denso (vs ZF for the 5 and 6 cylinder vehicles) and I have yet to find a suitable lower cost reliable alternative in this space. The PN referenced seems quite specialized to this vehicle application. I don't have any issues currently with my PS pump but it seems inevitable so I'm looking to find any and all options to OE. So far nothing, but I continue to search...
      While you have the intake off, ought to do a quick check of the valve cover gaskets, see if any are leaking. Way common at >100k, especially the back bank. And 100k is also a good time for a serp (aux) belt replacement with new idlers and tensioner.
      If for some odd reason you might consider doing VC gaskets (since you're about 1/2 way there anyway) plus PCV plus FPS, a good read on the job is here: http://forums.swedespeed.com/showthr...et-Replacement.
      Good luck!
      Last edited by ggleavitt; 03-21-2017 at 05:17 PM. Reason: Fix comment, guy with 14k posts does not need me to tell him how to do this.
      2005 XC90 B5254T2 175k
      2008 XC90 B8444S Sport 110k
    10. #8
      My valve cover gaskets seemed fine when I had the intake manifold off a few weeks ago. Although I'm replacing that upper PCV hose and will be doing the serp. belt, too, as a precautionary.
      I also have some heat shield rattles that make themselves present around 2k rpm. I'll address all this Monday.
      Matt
      2005 XC90 V8
    11. #9
      Jun 2005
      Seattle
      If not too late, might consider PCV as well, to match the life of the hose. Gets hot in there.
    12. Remove Advertisements
