Steering fluid
    Results 1 to 9 of 9
    Thread: Steering fluid
      Steering fluid
      2013 S60. Power steering fluid low. I have no access to a dealership, but need to top fluid up. What is fully compatible that I can purchase in a parts store ? I will be near a dealership in 5 days, but need to top it up NOW.
      Member Veefifty T5AWD's Avatar
      Feb 2009
      Lakes Region NH
      From the manual: Power steering fluid WSS M2C204-A2 or equivalent product
      Not sure if that helps?
      Logan
      2015 S60 T6 AWD R-Design Polestar
      2008 S40 2.4i - hers
      2013 C30 Polestar Limited Edition #87/250 - (former) | 2005 V50 T5 AWD (former)
      Where and why is it leaking? that's a pretty new car for leaks!
      Jan 2008
      Norwalk, CT
      Believe Pentosin CHF11 will work. In CT it is sold in Auto Zone and Advanced.
    7. #5
      It goes to the Dealer on Tuesday...under warranty. I just don't want to let it run low until then. Have no idea why it's leaking...it's 20 degrees and ****ty out...too cold to crawl under.
    8. #6
      Member
      May 2013
      Eastern Tennessee
      Ours was low once. Not sure why. No leaks. Top up and monitor before making a trek to the dealer.
      2013 S60 T5 AWD, Premier Plus, Beechwood Leather, Climate, BLIS, NJORD Rims Caspian Blue Metallic, Pirelli P7 Cinturato Plus
      Previous: 2009 Audi A4 Quattro 2.0T & 2000 Mitsubishi Eclipse GT
    9. #7
      Mine was low and a leak was found. New steering rack under warranty. Level has been right in the succeeding years.
    10. #8
      I recently drained and filled with Pentosin CHF202. In NH, O'Reilly has it but in some stores, they keep it out back and you need to ask for it.
      The CHF202, I believe, satisfies the "lifetime" requirement of the fluid if you buy into that.
      Den
    11. #9
      You can use the prestone fluid. Use the one specified for European vehicles. No need for the expensive pentosin stuff. I only use pentosin for brake fluid because of its higher boiling point and DOT 4 certification.
      I dislike wagons, and don't particularly care for Volvo's in general. I'm not a fan of any one brand.
      Currently trying to pilot the fastest P3 S60.
    12. Remove Advertisements
