Front Strut Stuck
    Results 1 to 32 of 32
      Front Strut Stuck
      Hi Everyone,
      I'm replacing my front struts and the strut is stuck in the hub assembly (not sure the actual name, but it's where the bottom of the strut is attached). The bolt was easy enough to loosen, and I think I was able to pry the strut up maybe 1/16-inch, but I can't get it any further. It's soaking in penetrant fluid as I type, so hopefully that will work some magic overnight. If not, any tips on how to get this to come out?
      2007 Volvo S40 T5 AWD Geartronic - Passion Red
      Blinding flash of the obvious...
      Does the bolt that secures the bottom of the strut have to come all the way out?
      Member GRat9717's Avatar
      Jan 2013
      NJ, USA
      I like to keep the strut attached at the top so I can whack on the knuckle with a 2 ton hammer
      Quote Originally Posted by LittleRedRidingHood View Post
      Might as well back it all the way out.
      Garage Queen - 2010 C30 R-Design Vrooooooom
      Daily - 2016 V60 T5 Drive-E Vrooooooom
      Zichrona Livracha - 2004.5 S40 T5
      May 2013
      Colorado
      Like GRat said, just whack the sh*t out the knuckle with a heavy hammer. Mine took a good bit of force to remove. And an air hammer made it so much easier to install- especially since I did mine on jackstands and couldn't get a full hammer swing while laying on the ground.
      2007 S40 T5 AWD
    7. #5
      Member AutoGeek's Avatar
      Jan 2008
      MD, Howard Co.
      Try to spread the top of the knuckle where the strut slides in with a pry bar. If that doesn't work, start whacking. Actually, on the strut there should be a hole in the tab that slides into the gap in the hub. You can stick a screwdriver or something in there to pry the strut up... then start whacking.
      2005 V50 T5 FWD M66 Passion Red (Radio Flyer)
      1998 V70 NA - Sold, 2002 S40 1.9T - R.I.P., 2005 V50 T5 - RIP
      Remember kids, Speed doesn't kill ... impact does!
    8. #6
      Jan 2013
      NJ, USA
    9. #7
      Member thefisch33's Avatar
      Mar 2011
      Aurora, CO
      Make sure all the tension is off. Did you disconnect the control arm? I used a block of wood to hammer on but be careful not to damage the abs sensor in the hub. Use pb blaster or other lube. It should hammer out 1mm at a time. Rubber Mallot worked for me.
      That stage 2/3 black&yellow m66
      2010 s40 T5 AWD M66 R1 Slotted Rotors&EBC Red Stuff, straightpipe, eibach springs
    10. #8
      Jan 2013
      NJ, USA
      Should be able to do it with the control arm attached at the ball joint. I think removing that would make it harder because you don't have something to support the knuckle while you whack.
    11. #9
      Finally got it off (without detaching the control arm). I think it was more difficult because of the spacer on the AWD struts. Lots of whacking - what a pain!
      One of the bolts sheared off in the spacer, so I'm wondering if it's possible to not use them when I put the struts back on. Should only be 1/2 inch difference at most. Lowering springs would probably have much more of an effect. Any reason not to remove them?
    12. #10
      Jan 2013
      NJ, USA
      I actually added them to my C30 on my previous setup because it was too low in the front. It doesn't hurt to remove them.
    13. #11
      Member pczeilon's Avatar
      Jun 2011
      Apple Valley MN
      Yes, the spacer is why it was harder. More downward tension against the control arm. Broken spacer bolt is very common, no problem to to remove for a lower ride.
      Note that you will need to rotate the upper spring perch tabs 180 with no spacer. The tabs should now line up with the metal tab at bottom of the strut. You can follow the How To as written now that you are effectively FWD suspension.
      2007 V70 5 Speed
      2005 S40 2.4i 5 Speed
      1995 855 5 Speed SOLD
    14. #12
      Quote Originally Posted by pczeilon View Post
      Thanks for the info, PC. Yes, those are the instructions I was following. "7. Use a screwdriver and slowly pry the strut away from the knuckle. It will come off without much effort." is the step that made me question what was going on. Took me well over an hour to get the strut out of the knuckle...
      I think I'll go with removed spacers. I'm envisioning a mean looking stance with a lowered front! 50% off alignments at a shop nearby, so I will be taking advantage of that.
    15. #13
      Jun 2011
      Apple Valley MN
      Written by a Southern Gentleman.
      If you want to help the alignment shop & yourself get the tie rods & locking nuts free right now while you have good access. Clean & grease the threads. It will make their day & ultimately get you a better result as they don't need to waste time freeing frozen parts.
      2007 V70 5 Speed
    16. #14
      Member
      Dec 2013
      Northern CA
      Just did this job on my AWD. Next time do this to help facilitate the removal: Take a 10-12" cut 2X4 and place one end at the middle of the knuckle. Angle the other end out away from the assembly. Now take a 5lbs sledge and smack it hard. You'll see the knuckle slowly break away. Installation is tougher than removal. Make sure you put never-seize on the inside of the knuckle prior to assembly and then use a jack to force the knuckle up into the strut assembly. You will have to jiggle the strut assembly fairly vigorously to get it to slip. You may have to slowly increase jack pressure until it slips on. At some point, however, you will bind the knuckle on the strut and then you'll have to release jack pressure and start over. DO this until the strut is completely into the knuckle.
      2005 V50 T5 AWD M66
    17. #15
      Great tip. I've read that only the toe is adjustable - is that right, or can camber be adjusted as well?
    18. #16
      Quote Originally Posted by mercdude View Post
      Thanks for the info - I still have one more strut to do so I will try using this method.
    19. #17
      Member
      Dec 2013
      Northern CA
      Yeah it's not fun, but doable. Another tip, make sure you install the top strut bolts first. That way, the strut assembly isn't flopping around on you and you jack the knuckle onto the strut. If you can, make sure the bottom strut tab (that goes between the knuckle pinch points) is facing the right way before you try to re-assemble the knuckle and strut.
      2005 V50 T5 AWD M66
    20. #18
      Jun 2011
      Apple Valley MN
      Yes, only toe is adjustable. If you clean & grease the knuckle your strut will slide in fairly easily. Some new struts may have excess weld or paint. This can hang them up also. Definitely bolt the top up as Merc suggested, much easier to wrangle.
      2007 V70 5 Speed
    21. #19
      Member
      Dec 2013
      Northern CA
      ^ You're back!!!
      2005 V50 T5 AWD M66
    22. #20
      Well, that job's done. I had to use the spring compressors to get the strut back in even without the AWD spacer on the strut mount.
      As a note, my front right LCA had a sensor attached to it - seems like a ride height sensor, with a servo attached to the body and a miniature end link connecting it to the LCA. My knuckle had dropped so far that when lifting it back up, the arm on the servo spun around to the wrong side. Even after bolting everything back up, I was able to rectify it by disconnecting a bracket that connects the LCA to the 'end link' and move it to the correct (left) side, where the 'end link' is more vertical. This could easily have gone unnoticed by me, so I'm glad I took a good look around before putting the wheel back on. Seems like not all cars have these from photos I've found online.
      I forgot to take a photo but will see if I can snap a picture sometime soon. I can't find the part in any parts diagrams.
    23. #21
      Jun 2011
      Apple Valley MN
      That's the sensor for your Xenon headlamps. HERE
      2007 V70 5 Speed
    24. #22
      Ah, yes - that's the one.
    25. #23
      Ugh yea I'm dealing with this right now
      2003 mustang COBRA ( SVT 10th anniversary ) born on 6-26-03/ 4634 of 5082 of verts & 955th of 2003 SVT 10th ANNIV edition`s
      2006 s40 2.4i fwd
      my new baby!!! black on black 2012 s60 T6 awd
    26. #24
      Junior Member nathanlevang's Avatar
      Mar 2016
      Santa Clarita, CA
      Quote Originally Posted by mmustangsrus View Post
      Did you try using some penetrating fluid? That's what broke mine loose.
      Sent from my Nexus 6P using Tapatalk
    27. #25
      I did use penetrating fluid. It wasn't so much an issue of breaking the strut free from the knuckle, as it was getting the knuckle and LCA to come down low enough to get the strut out of it. The extra half inch of the AWD spacer made a big difference. I didn't put it back in on either side, so hopefully it will be easier to take out next time (which will hopefully be a long time from now!).
    28. #26
      Quote Originally Posted by nathanlevang View Post
      I did with no luck.
      That's exactly my issue right now !!!
      2006 s40 2.4i fwd
    29. #27
      Once it is most of the way out of the knuckle, you have to wiggle it very hard from the top until one side of the strut starts to slip out of the knuckle. There's more movement in the LCA/knuckle than you think - it's just very stiff.
    30. #28
      Jan 2013
      NJ, USA
      Hammer.
    31. #29
      Mar 2016
      Santa Clarita, CA
      I remember I had to hammer the sh*t out of mine and do a ton of wiggling from the strut as well. Just be persistent and don't give up!
    32. #30
      Jan 2013
      NJ, USA
      Be careful not to smash your ABS sensor :P
    33. #31
      Member
      Dec 2013
      Northern CA
      Use a 12" 2x4 as an extension and wail on it with a sledge - it'll pop free
      2005 V50 T5 AWD M66
    34. #32
      Jan 2013
      NJ, USA
      Alright I'll admit it...you need more than a hammer. This is great advice so nothing gets damaged by the hammer directly.
    35. Remove Advertisements
