Alternator / Voltage Regulator Replacement
    Results 1 to 7 of 7
      Feb 2012
      Texas
      So a couple of weeks ago my wife got a low battery warning message in her 2012 XC60 T6 RD. I checked the battery and it read 12.4 volts at rest (car not running) - a couple of tenths lower than expected. The alternator showed to be putting out about 14 1/2 volts or so and, as a result, I decided to just "watch it". Last night, driving home from dinner I got a charging warning message. We pulled in to the driveway, left the car running, and I checked the voltage at the battery terminals - 11.6 Volts. Alternator was not charging.
      Anyway, I went ahead and pulled the alternator today. I am going to try to replace just the Voltage regulator since, a.) I have seen them often be the culprit in years past, b.) Volvo actually issued a technical journal (TJ 26897) in Jan of 2014 indicating most alternator replacements they were seeing were really just bad voltage regulators, c.) It is $200 instead of $600 and d.) when I pulled the alternator and spun the pulley I don't hear any sign of a bad bearing, etc. This may be a fool's errand, but we'll see...part is ordered.
      Anyway, I don't think there is a DIY on hear about how to replace it so I'll toss a few comments and pics out there.
      Removal:
      The alternator is in the front directly underneath the big plastic intake manifold. Unlike most cars it is sort of "direct driven". It faces the left side of the car and the serpentine belt drives a shaft which the alternator pulley is coupled too with a ribbed rubber coupler. You have to remove the intake to get it out, but unlike 99% of cars this is actually a piece of cake on the Volvo so don't let that freak you out. The basic steps are:
      1. Disconnect the battery - seriously you will be removing the positive cable at he alternator so this isn't "optional" on this job. The battery is under two little plastic panels toward the cowl. Pop them off and it is right there (one has clips and the other a little philips head plastic screw to release it).
      2. Pop off decorative engine cover (note: there are not screws, it just pulls straight up - pull on each corner). You will note a decent amount of sound deadener under there.
      3. Disconnect various connectors and hoses going to upper part of intake.
      4. Remove the electrical connector to the throttle body.
      5. Remove the big air intake hose going into the throttle body underneath the intake. There is a big hose clamp on it. You may need to pry the lip away from the throttle body a bit and pull (while wiggling) downward.
      6. Remove the 7 or so 10 mm bolts holding the upper intake on and free the intake...since you are leaving the heads/valves exposes, do yourself a favor and stick some paper towels in the intake openings so that you don't drops something in there!
      7. There are two wires going to the alternator. Pop off the nut center cap of the middle one. This is from the positive battery cable - you did disconnect the battery right - 13mm nut, unscrew it. The second is to the voltage regulator whcih is an "internal" style on the alternator. It has a fiddly clip.
      8. The alternator is held on with 4 10mm head bolts. you can remove all 4 and it will just hang there. The two bottom bolt holes on the alternator have little spacers in them. These are to line up the alternator PERFECTLY to the drive pulley. You will need to wiggle the alternator back and forth to get it to free up. I used a stubby screwdriver to pry just a hair at the bottom alternator to block joint. Took a couple of minutes, but no biggie. The alternator will free up and you can pull it to your left (right side of car) and it will slide out of the coupler.
      Since I haven't replaced the voltage regulator yet or reinstalled, I don't have any more than that yet. Saying a prayer the Voltage regulator does the trick! A few pics (hopefully these will show up for you guys):
      Removed Alternator
      Intake Removed - just sitting on top of engine (note throttle body is still attached at top of pic):
      Intake on floor of garage - you can see the one electrical connector that goes to the throttle body
      This is where alternator goes...the rubber coupler is seen here that the "toothed" pulled on the alternator slides in to...
      The two pronged plug is actually the Voltage regular on back of alternator
      2012 XC60 R-Design - Passion Red / Off-black/Cream Accents, Platinum, Polestar, & Climate
      2013 Tesla Model S P85+ - Multicoat Red / Black
      1997 M3 - Alpine White/Black
      Junior Member Spyder999's Avatar
      Feb 2017
      Vancouver
      I have the exact same vehicle. Thx for the detailed description of the symptoms and the fix. I'll keep my eye out on my vehicle for this.
      Feb 2012
      Texas
      Just an update - So, I made the mistake of ordering the voltage regulator and THEN pulling the old voltage regulator off the alternator. There are two little spring loaded brushes mounted in the voltage regulator and they ride up against the shaft running through the alternator. The "top" brush was practically stuck in the bore in the voltage regulator and the surface of the shaft it rides on was all torn up. Ironically, it looks just like the picture in the Volvo TSB where it states "if the shaft looks like this - replace the alternator". Anyway, I ordered the alternator yesterday and a special tool to remove the clutching pulley. If it gets here Saturday I may be doing it all over the weekend...if not, next week some time. More pics when I get it all wrapped up.
      Feb 2012
      Texas
      OK, got the alternator installed last night. A few more items:
      1. The Reman Volvo Alternator does NOT come with a pulley, the little sleeves that go in the two lower mounting holes, the Postive wire nut or plastic nut cover - you will need to re-use those from your old alternator.
      2. You can press out the two little sleeves with a small socket on an extension and a few taps of a hammer. I pressed them in by lining them up against the holes and pressing them with my benche vise.
      3. You will need a special tool to get the pulley off the old alternator. See here: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
      4. My original alternator was stamped FoMoCo (Ford Motor Company). The replacement from Volvo is stamped Volvo and looks a bit different. I am assuming some items changed since 2012 and this is just the latest incarnation. Hopefully, they won't give me any grief on the core exchange.
      Pics below:
      Pulley transferred to new alternator
      Outer part of special tool
      Special tool in action (note: tightening pulley on new alternator at this point...removal is the same)
      New alternator in place
    7. #5
      Junior Member BellevilleV70's Avatar
      Mar 2006
      Belleville,Ontario
      Great info!!!
      02 V70 2.4T - EST exhaust/Elbrus 18x8s/Conti DW/Eibach/Koni FSD/Polk Audio/Boston Acoustics/Infinity ---- for sale
      13 XC60 T6R-Design-Ice White-IPD exhaust-Soon:do88 intercooler
      15 Chrysler 200c ---- Mopar Tech
    8. #6
      Reverse threads to remove the pulley, correct?
      2007 S40 T5
    9. #7
      Feb 2012
      Texas
      Quote Originally Posted by qaz996 View Post
      Actually, I don't think it was. I believe it was the normal righty, tighty lefty loosey. To be clear I was turning the INNER shaft and holding the outer. See here: https://www.youtube.com/watch?v=p52VTAnLptI
    10. Remove Advertisements
