NEW PRODUCT Release: Volvo pCRV Upgrade, Volvo T6/Drive-E
    Results 1 to 15 of 15
      Banner Advertiser Connor @ ViVA's Avatar
      Feb 2015
      Massachusetts
      ViVA Performance has released a mechanical Compressor Bypass Valve Upgrade for the Volvo 3.0L T6 and 2.0L Drive-E Engines.
      To address the multiple design and functional flaws present in the factory electronic compressor valve (eCRV), ViVA Performance designed a pneumatic compressor re-circulation valve (pCRV) as a 100% direct replacement for the factory eCRV. The pCRV is 100% designed and manufactured in the USA, using a high-quality rubber diaphragm, heavy-duty spring, and N-butyl, oil resistant o-rings.
      The Volvo SI6 3.0L 6-cylinder turbocharged engine and 2.0L 4-Cylinder Drive-E engines use a simple, eCRV to recirculate boost pressure when the throttle body plate is closed. Over time, the factory eCRV unit is prone to mechanical failures, such as ripped diaphragms or a stuck/ seized piston. They are also not designed to handle higher boost pressures on heavily modified vehicles. The ECU is designed to release boost through the eCRV like in an “on/off” switch, requiring the turbocharger to spool back up to full boost pressure when required. There is also a delay between when the throttle plate closes and the eCRV releases pressure. This can result in decreased performance and a pesky check engine light (CEL). To top it off, when your factory eCRV fails, Volvo does not sell this part separately, and you would have to purchase an entire new turbocharger unit.
      pCRV Product Highlights
      • 0.25 second faster response time at high boost / low RPM
      • 0.40 second faster response time at low boost / low RPM
      • Heavy duty components
      • 100% CNC machined for superior quality
      • Black anodized finish for extreme corrosion protection
      • Comprehensive Kit developed for easy installation
      pCRV Product Benefits
      • Reduced Turbo Lag
      • Increased Throttle Response
      • Fully Serviceable Components
      • Designed to outlast the life of your car
      • Supports 40+ psi of boost pressure
      pCRV Kit Contents
      • (3) Button Screw
      • (3) Black Top Hat Button Screws
      • (1) Top Hat and Spacer Plate
      • (1) Vacuum Nipple
      • (1) Electrical Resistor
      • (5) Feet of Black Silicone Vacuum Hose
      • (1) Vacuum Tee
      • (1) O-Ring
      • (1) Compression Spring
      • (1) Rubber Diaphragm
      Vehicle Fitment Guide
      • 2010+ S60/V60 T6 AWD, R-Design (6-cylinder turbo)
      • 2015-2016 S60/V60 Polestar
      • 2017+ Volvo S60/V60 Polestar
      • 2007+ Volvo S80 II T6
      • 2008+ Volvo V70/XC70 III T6
      • 2010+ Volvo XC60 T6
      • 2015+ Volvo S60/V60 B4204T11, B4204T12, B4204T9, Drive-E
      • 2015+ Volvo XC60 B4204T11, B4204T9, Drive-E
      • 2015+ Volvo S80 B4204T11 Drive-E
      Sale Details
      Start Date: Today, April 11th, 2017
      End Date: April 21st 11:59 PST
      Discount Amount: 10% OFF (Calculated once you apply the coupon code in your shopping cart)
      Coupon Code: TEESIX
      Volvo pCRV Upgrade can be found here
      Should you have questions about the Volvo pCRV Upgrade, please contact us at any time. We can be reached via:
      Email: parts@vivaperformance.com
      Phone: 1-877-878-8646 Monday-Friday 10:30am-5:30pm EST
      Online Chat: Monday-Friday 10:30am-5:30pm EST
      Junior Member Spyder999's Avatar
      Feb 2017
      Vancouver
      Ordered
      2005 S40
      2010 C30 R Design
      2012 XC60 R Design
      Feb 2017
      Vancouver
      Installed.
      Jan 2017
      Ohio
      Quote Originally Posted by Spyder999 View Post
      Installed.
      Excited to hear your review of both installation and any real or perceived change in performance.
    7. #5
      Junior Member tunedxc60's Avatar
      Oct 2016
      USA
      Can you hear the turbo blow off when you lift off the gas?
      2016 XC60 T6 AWD Platinum/Inscription - Full bolt ons (Snabb air intake & turbo pipe, Do88 Intercooler, Viva Hybrid Turbo, Ferrita downpipe, IPD exhaust catback, H&R Springs), Stage 3 Hilton Tune: Dual JL Audio 10" stealth subs & 750Watt amp
    8. #6
      Feb 2017
      Vancouver
      I've only been driving a couple of days with this part installed but believe that there is definitely a power boost. I hear the turbo spool up quite distinctly but haven't heard a blow off yet... Although it's been raining and the windows have been closed. I'll give it a couple of weeks for a better report.
    9. #7
      Feb 2017
      Vancouver
      Quote Originally Posted by AschMan View Post
      Installed.
      My go to mechanic installed the item and it came with a clear 30 step process PDF of instructions. He said that it wasn't hard but it took some time.
      Sorry, my personal mechanic skills are not that high so I can't really report more.
    10. #8
      Member Ocean Racer's Avatar
      Oct 2009
      Melbourne / Australia
      Anyone else have any experience with this upgrade?
      02 XC70 R PROJECT TERRÄNGKÖRNING LANDVAGN
      04 V70R PROJECT LANDBARGE
      11 XC60 R-DESIGN PROJECT HEICO
    11. #9
      Feb 2017
      Vancouver
      After two weeks, well more power perceived. Buy it.
      2005 S40
      2010 C30 R Design
      2012 XC60 R Design
    12. #10
      Junior Member Stewie5148's Avatar
      Jun 2015
      Saskatchewan Canada
      Pity you haven't been able to do a before and after Dyno to see if there are any actual measurable gains to this Mod. Is anyone else thinking of installing this? If so are you willing to do a before and after Dyno, I am sure lots here would be very interested in the results.
      2014 XC60 Platinum Package, W/Polestar Optimization, Polestar suspension + Feritta down pipe & Kpax GT6 Exhaust, IPD Sway bar and HD end links, Snabb Intake & K & N drop in and a bunch of other aesthetic if not expensive little goodies.
      2015 BMW 428i Xdrive Cabriolet W/Executive, Driver Assistance, Premium Packages and Dinan power tune.
    13. #11
      Oct 2009
      Quote Originally Posted by Stewie5148 View Post
      Im interested but require a bit more convincing reports than what's been provided so far.
    14. #12
      Does this void the warranty on a new car?
    15. #13
      Aug 2015
      Bellevue, WA
      Hi Spyder,
      Can you elaborate more on the behavior of the unit? Where do you feel the added power or increased responsiveness?
      2014 XC60 T6 - P* Tune, K-Pax Exhaust, DO88 FMIC, Ferrita DP, TSW Bathurst w/ Conti DWS06, R-Design Suspension, IPD Rear Sway, Morimoto D2S 4.0 HID Projectors, Skeletonized Airbox, Intake Resonator Delete, Powerflex Bushings, Colder NGK Plugs
      2007 XC90 V8 Sport - IPD Sways/Subframe Inserts/Strut Bar Conversion, Stoptech Rotors
      For Sale: CHEAP! 2007 XC90 V8 Sport Sway Bars / XC60 T6 parts as replaced above
    16. #14
      Feb 2017
      Vancouver
      I am going to say that I feel that the throttle response has increased. I really should have gauged the vehicle more before I added the part to see the contrast but I had only had the vehicle for a couple of months before adding the part. I am constantly street racing the vehicle so since the install I feel it has more response than previously. I do hear a high pitched whistle sound when accelerating with the windows open that I dont remember hearing before the installation. It isnt an expensive upgrade, so just knowing that the part fixes the flaw that is there and you get more response from it seems like it is worth the effort of getting it.
      2005 S40
      2010 C30 R Design
      2012 XC60 R Design
    17. #15
      Subd for more feedback.
      2011 S60 T6 with Polestar tune
      13.1 at 101 mph
      Current mods: KW V3 coilovers, DO88 fmic, Ferrita downpipe, Powerflex "race" torque mount inserts, more to come...
    18. Remove Advertisements
