Well the time has come to make it official! In 4 years i've managed to collect three R's; one blew up, the other was murdered by a truck and the third treated by the former owners like a read headed orphan during the depression... God willing, third time will be the charm. For the last 2 years i've been buying and squirreling parts for this day. Hopefully you guys will be able to see her in her full glory for Carlisle. Without further suspense I present to you Omar's build parts list, taaadaaaa:
IPD:
Endlinks (4)
Front and Rear Sway bars (25mm)
Strut Mount
Rear Chassis Brace
DEM Cover
ThrottleBody Spacer
SS Brake lines
Offset Camber Bushings
Toe Control Arms
DefĂ Gauges (52mm Racer Series):
Oil Temp
Water Temp
EGT
Oil Pressure
Fuel Pressure
Voltage
Innovate:
Innovate PowerSafe Boost & Air/Fuel Ratio Gauge
CF Works:
Gauge Pod
Inner Mirror Cover
VIVA:
Lower Front and Rear Braces
Triple Gauge Pod
AC Vent Gauge Pod
Winglet Splitter
Competition Valve Spring/Retainer Kit,
Stainless Steel Intake Valve Upgrade
Inconel:
Exhaust Valves
SPEC:
Clutch 3+
Flywheel
Quiffe:
LSD
PDV:
HD Collar Gear
BorgWarner:
EFR 7064 Turbo
TurboSmart:
Waste-gate
Kaphlenke Racing:
Lower Suspension Bushing Kit
BC Racing:
Coilovers (DR)
R1 Concepts:
Slotted & Crossed Drilled Rotors (4)
Pads
Wiseco:
Forged Pistons
Darton:
Sleeves
ARP:
Main Stud Kit
K1:
Forged H-Beam Connecting Rods, 143mm
Mishimoto:
3-Port Baffled Oil Catch Can
ENEM:
Performance Camshafts
Snabb:
ULTIMATE BIG VOLVO INTERCOOLER KIT
S/VR HIGH FLOW INTAKE KIT WITH 4" MAF BODY
PERFORMANCE TURBO INTAKE PIPE (w/ all the extras)
Milletech:
Intake Manifold
Fuel Rail
Leviathon (Cody Halm):
Exhaust Manifold
Downpipe (3.5)
Exhaust (3.5)
Water Line
Oil Lines
Oil Temp/Pressure Gauge Sensor Adaptor
RAY'S VOLK:
GT-C 17 X 8.5
SNOW PERFORMANCE:
EFI Gas Engines Stage 3 Boost Cooler Water Injection
Safe Injection Unit
Flow Meter
OneEighty:
Custom Projector E-Code Headlights
TWM:
M1 Abrams Shift Knob
AEROMOTIVE STEALTH:
Fuel pump
Speedish Carbon:
A- Pillars
Dash Cowel
Center Console
Gauge Cluster
Inner Door Trim
Mirror Caps
Head Unit Assembly
Brembo:
Completely stripped and refinished in Brembo Red.
RedLineGoods:
Custom Steering Wheel
Powerflex:
Lost track of all the ones I bought.
I will periodically update parts as to be honest i'm sure there are some parts missing or in the mail . Also I know some of you offered to help out on the build with small things here and there. I would love nothing more and if you want to help; please let me know in advance. I will post w/e i'll be at the garage (watertown) working on her. Free food, drinks, smokes etc to anyone who comes.
IPD:
Endlinks (4)
Strut Mount
Rear Chassis Brace
DEM Cover
ThrottleBody Spacer
SS Brake lines
Toe Control Arms
Oil Temp
Water Temp
EGT
Oil Pressure
Fuel Pressure
Voltage
Innovate:
CF Works:
Gauge Pod
Inner Mirror Cover
VIVA:
Triple Gauge Pod
AC Vent Gauge Pod
Winglet Splitter
Inconel:
Exhaust Valves
SPEC:
Clutch 3+
Flywheel
Quiffe:
LSD
PDV:
HD Collar Gear
BorgWarner:
EFR 7064 Turbo
TurboSmart:
Waste-gate
Kaphlenke Racing:
BC Racing:
Coilovers (DR)
R1 Concepts:
Pads
Wiseco:
Forged Pistons
Darton:
Sleeves
ARP:
Main Stud Kit
K1:
Mishimoto:
ENEM:
Snabb:
Milletech:
Intake Manifold
Fuel Rail
Exhaust Manifold
Downpipe (3.5)
Exhaust (3.5)
Water Line
Oil Lines
RAY'S VOLK:
GT-C 17 X 8.5
SNOW PERFORMANCE:
Safe Injection Unit
Flow Meter
OneEighty:
TWM:
AEROMOTIVE STEALTH:
Fuel pump
Speedish Carbon:
A- Pillars
Dash Cowel
Center Console
Gauge Cluster
Inner Door Trim
Mirror Caps
Head Unit Assembly
Brembo:
RedLineGoods:
Powerflex:
