SRS Light
    Results 1 to 8 of 8
    Thread: SRS Light
      SRS Light
      Hello all. I'm having a problem with my 2006 XC70 airbag system where the "SRS light" is on continuously and the "passenger airbag off" light is on regardless of someone sitting on the passenger seat or not.
      I had the code scanned by my mechanic and the code is SRS-0251 Occupant Weight Sensor, Configuration Fault. Has anyone had this code and found a way to repair it? Please share.
      Senior Member JRL's Avatar
      Apr 2003
      Devon PA
      Real PIA, it's buried in the seat bottom and I mean buried
      Email: jrl1194(at)aol.com
      If the subject is car purchase related please use jrl1194(at)gmail.com
      2007 V70 2.5T White/Oak 108K miles, new daily driver
      2000 V70R wife's. Won't sell, now 139K miles and still near perfect
      2000 S70 GLT SE 30,005 MILES, A time capsule!
      I'd check the harness under the seat first. It's more likely that something slid up under there and damaged it.
      I'm going to check the harness shortly.
      Is there a way to bypass the sensor so the airbag will deploy at all times? The only passengers I carry are large/heavy adults.
    7. #5
      Apr 2003
      Devon PA
      No
      It has to be working as designed
    8. #6
      Quote Originally Posted by Orjinal View Post
      if you knew the resistance of the sensor it would be trivial to duplicate it and fool the computer to think that the seat was occupied at all times.
    9. #7
      Member Antherzoll's Avatar
      Dec 2013
      Toronto, Ontario, Canada
      Check out this link, it may be helpful.
      http://www.volvoxc.com/forums/showth...er-Air-Bag-Off
      2005 XC70 Crystal Green | Hilton | 16T | 110k mi
    10. #8
      It ended up being couple of damaged wires on one of the sensors underneath the seat. It took me a good few hours to find and repair them but I'm happy. Thank you to all that helped!
    11. Remove Advertisements
